#71 |
Racing Enthusiast
Drives: Bone stock 2019 BRZ manual
I am on PSS, with stock power. Primarily used at Road Atlanta with obvious hard braking zones, and I really thrash the car...
“$20 per diddle? I can diddle myself for free and do a fine job”
#72 |
#73 |
Racing Enthusiast
HP+ currently, it's the first race pad I've put on my personal car.
I always do the pedal dance, but it doesn't turn off abs. I typically stay off abs, but every now and then it'll kick in while I'm trail braking.
#74 | |
Lets step you up to a real race compound, not a "hey we claim this does it all but it really doesn't" compound. Are you comfortable swapping pads for track days with street pads, or are you going to be leaving the race pads on permanently? |
#75 | |
Racing Enthusiast
I am comfortable swapping pads. Here is my plan so far: Order the sprint BBK. Get some high end pads for the BBK. Get some street pads that fit in the BBK calipers. Get a spare set of blank rotors for the BBK. Drive daily on street pads and blanks. Swap to J-hooks and race pads for track.
#76 | |
Let us know when you want to order! -Mike |
#77 |
Drives: Asphalt FR-S
What would be the recommendation for the same scenario but where one is interested in keeping the pads on the track and off (and not swapping)?
#78 |
Race pads, but with the help of someone experienced who can help you bed it in properly. Noise can be minimized with proper bedding and compound choice, but fade cannot, so the only choice is to get a higher performance compound that can be bedded to silence.
#79 |
Drives: '13 Whiteout FR-S (M/T)
Hey @CSG Mike wondering if you've ever experienced this - I discovered some "ripples" on my rotors (can feel it when rubbing finger across the surface of rotor). I'm feeling that they're causing some slight vibration when applying moderate brake pressure when brakes are cold. Same issue on both rotors.
Using DS2500 pads.
#80 | |
#81 |
@CSG Mike they are certainly radial, i've seen markings before but this is very "wavy" and you can feel smooth rolling "slopes", if you will, going from inside of rotor to outside. Should I make any change to maintenance or use or is this completely normal? Some has suggested perhaps sanding the pads flat?
#82 | |
#83 |
Drives: 2016 Hyperblue Brz
#84 |
| This is how much we like our AP Racing/Essex "Sprint" BBK... | CSG Mike | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 05-06-2013 11:30 AM |
| Question about Long-Term "Garaging" | arleewa | BRZ First-Gen (2012+) — General Topics | 25 | 01-12-2013 09:13 PM |
| Some FR-S "news" (pricing update) | Sport-Tech | CANADA | 19 | 03-24-2012 10:31 PM |
| Hyundai Calls 2011 Sonata Turbo "Very Delicious," Reveals Near-Term Future Plans | vh_supra26 | Other Vehicles & General Automotive Discussions | 1 | 02-19-2010 02:53 PM |
