Old 10-01-2015, 12:40 AM   #71
AreteAuto
Racing Enthusiast
AreteAuto's Avatar
Drives: Bone stock 2019 BRZ manual
"Best" is subjective, as it varies by each setup, particularly the chosen tire compound and power output.
What is your setup?
My personal preference is for the Project Mu 999.
I am on PSS, with stock power. Primarily used at Road Atlanta with obvious hard braking zones, and I really thrash the car...
“$20 per diddle? I can diddle myself for free and do a fine job”
AreteAuto is offline   Reply With Quote
Old 10-01-2015, 01:45 AM   #72
CSG Mike
CSG Mike's Avatar
What pads are you on now?
ABS? Pedal dance?
Old 10-01-2015, 11:15 AM   #73
AreteAuto
Racing Enthusiast
AreteAuto's Avatar
ABS? Pedal dance?
HP+ currently, it's the first race pad I've put on my personal car.
I always do the pedal dance, but it doesn't turn off abs. I typically stay off abs, but every now and then it'll kick in while I'm trail braking.
Old 10-01-2015, 08:32 PM   #74
CSG Mike
CSG Mike's Avatar
Per Hawk's documentation, that's a 800F pad. You're gonna have a bad time; our entry level recommendations for a novice at the track *start* at 800C/1500F for stock calipers. I'm not surprised you're having fade issues.
Lets step you up to a real race compound, not a "hey we claim this does it all but it really doesn't" compound.
Are you comfortable swapping pads for track days with street pads, or are you going to be leaving the race pads on permanently?
Old 10-01-2015, 11:18 PM   #75
AreteAuto
Racing Enthusiast
AreteAuto's Avatar
Ouch, I can only imagine the pain those Hawks have endured over the past weekend.
I am comfortable swapping pads. Here is my plan so far:
Order the sprint BBK.
Get some high end pads for the BBK.
Get some street pads that fit in the BBK calipers.
Get a spare set of blank rotors for the BBK.
Drive daily on street pads and blanks. Swap to J-hooks and race pads for track.
Old 10-01-2015, 11:24 PM   #76
CSG Mike
CSG Mike's Avatar
Swapping rotors means you have to take the caliper off. I recommend you pick up a bottle of locktite red from Home Depot.
Let us know when you want to order!
-Mike
Old 10-02-2015, 12:47 AM   #77
CB390248
Drives: Asphalt FR-S
What would be the recommendation for the same scenario but where one is interested in keeping the pads on the track and off (and not swapping)?
CB390248 is offline   Reply With Quote
Old 10-02-2015, 03:36 AM   #78
CSG Mike
CSG Mike's Avatar
Race pads, but with the help of someone experienced who can help you bed it in properly. Noise can be minimized with proper bedding and compound choice, but fade cannot, so the only choice is to get a higher performance compound that can be bedded to silence.
Old 12-01-2015, 03:32 PM   #79
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
Hey @CSG Mike wondering if you've ever experienced this - I discovered some "ripples" on my rotors (can feel it when rubbing finger across the surface of rotor). I'm feeling that they're causing some slight vibration when applying moderate brake pressure when brakes are cold. Same issue on both rotors.
Using DS2500 pads.
1Cor10:23 is offline   Reply With Quote
Old 12-01-2015, 03:39 PM   #80
CSG Mike
CSG Mike's Avatar
Using DS2500 pads.
Radial grooves are normal. If the grooves are not radial, something is wrong.
Old 12-01-2015, 03:51 PM   #81
1Cor10:23
1Cor10:23's Avatar
@CSG Mike they are certainly radial, i've seen markings before but this is very "wavy" and you can feel smooth rolling "slopes", if you will, going from inside of rotor to outside. Should I make any change to maintenance or use or is this completely normal? Some has suggested perhaps sanding the pads flat?
Old 12-01-2015, 07:06 PM   #82
CSG Mike
CSG Mike's Avatar
Totally normal; you'll get larger grooves on the trailing edges of the J-hooks.
Old 12-06-2015, 10:46 PM   #83
Cybmx
Drives: 2016 Hyperblue Brz
Hi Mike, is the sprint kit designed to run with stock rear pads? Do I need to swap out the stock rear pads to match the front? Thanks
Cybmx is offline   Reply With Quote
Old 12-06-2015, 11:31 PM   #84
CSG Mike
CSG Mike's Avatar
You should be using the same pad compound front and rear. We have plenty of options
This is how much we like our AP Racing/Essex "Sprint" BBK... CSG Mike Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 05-06-2013 11:30 AM
Question about Long-Term "Garaging" arleewa BRZ First-Gen (2012+) — General Topics 25 01-12-2013 09:13 PM
Some FR-S "news" (pricing update) Sport-Tech CANADA 19 03-24-2012 10:31 PM
Hyundai Calls 2011 Sonata Turbo "Very Delicious," Reveals Near-Term Future Plans vh_supra26 Other Vehicles & General Automotive Discussions 1 02-19-2010 02:53 PM
