Old 12-01-2015, 08:46 AM   #15
Northwest86
Drives: Velocity Orange 86 GT
That depends on the tuner and turbo design. If you didn't know better you could be excused in saying that my turbo kit was a supercharger. Especially with the different turbo sizes available. Not all kits are made equal.
Northwest86 is offline   Reply With Quote
Old 12-01-2015, 08:55 AM   #16
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
OP: Buy this. Read this.
[ame="http://www.amazon.com/Maximum-Boost-Turbocharger-Engineering-Performance/dp/0837601606/ref=sr_1_1?ie=UTF8&qid=1448978119&sr=8-1&keywords=maximum+boost"]Maximum Boost: Designing, Testing and Installing Turbocharger Systems (Engineering and Performance): Corky Bell: 9780837601601: Amazon.com: Books[/ame]
GSpeed is offline   Reply With Quote
The Following User Says Thank You to GSpeed For This Useful Post:
MisterSheep (12-01-2015)
Old 12-01-2015, 09:08 AM   #17
NotSoJDM
NotSoJDM's Avatar
Drives: '13 BRZ | '04 E55
If you still owe a significant amount of money on the car, your best bet is to use that S/C money to pay down the principal of the car. But if you don't care to do that continue reading.
Turbo vs. Supercharger is a never ending debate, both have their pros/cons. Given your limited knowledge, are you going to have someone else install the kit for you? How about general maintenance? These would be big deciding factors for me, as I would want a kit that is easy to maintain with the smallest amount of failure points possible. If you are not mechanically inclined (which is fine) even small quirks on a forced induction setup could leave you stranded. For example, if your belt breaks on a supercharger and you can't replace it on your own, or have a spare, this could result in the car being undriveable for a few days. Another example is if your intercooler piping blows off on a turbo setup, and the car dies. How will you know what to trouble shoot or fix? These are items that are relatively easy to fix for the average DIYer, but someone who wants to set it and forget it will have a harder time solving these issues if they arise.
NotSoJDM is offline   Reply With Quote
Old 12-01-2015, 04:27 PM   #18
Drifting86
Drives: 2013 FRS 10 Series
I have a basic knowledge of engines fuel fire combustion and how to fix something when it breaks diagnosis and problem solving on the other hand Im not to swell at me and a real good friend who has help me build a wiring harness from scratch are planning to do it I'm really not sure where I want extra power the most maybe a little lower in the Rev range hate not hitting my PowerBand until 5k rpms but I think I could also handle losing a little low end power for a stout power band I'm indecisive I know but my main thing is reliability I can work everything else out but I need reliability I can possibly get around the emissions issue if turbos are more reliable which from the sounds of things they are also who are good manufacturers of internals thanks guys I know I'm an idiot but most sites just have propaganda and "reviews" trying to sale there stuff
Drifting86 is offline   Reply With Quote
Old 12-01-2015, 04:37 PM   #19
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
I am going to give you some solid advise. If you are new to this and do not have a very good understanding of FI then I would stay away from it. If you don't know who the "good manufacturers of internals " are then you should not even be thinking about them haha!!
It is not as easy as justing bolting something on and going. You should learn the car before you jump onto the FI bandwagon. If you want reliability or this is your only car leave it stock or only stick to smaller mods.
However with all that said if you want to spend $$$ then you can pay someone to do it all for you, but to me thats not the same as when you build something.
Old 12-02-2015, 12:47 AM   #20
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
300-400whp pumpgas = ~$15000
>400whp pumpgas = ~$25000
<300whp pumpgas = $5000-7000
Personally, I'd just get an Edelbrock SC kit, keep it at 260whp and done.
hmong337 is offline   Reply With Quote
Old 12-02-2015, 08:32 AM   #21
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
I'm 9k with Turbo and supporting mods. I won't be entirely happy until I spend another 1k. Then I still need to build a motor, that's another 3k doing it myself. I haven't even touched my Prius rims and tires yet.
Someone else on the forums has a 400WHP BRZ/FRS with prius tires and rims and every gear is a spin out. I think it's his weekend around town car too.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 12-03-2015, 05:33 PM   #22
Scracho
Drives: 2018 Subaru BRZ
You need to ask what your ideal "end result" is for your car? Track? Daily? Garage Queen?
Modding in general is a slippery slope and as mentioned in a previous comment you can spend thousands just on forced induction and supporting mods before even touching anything else i.e. suspension, wheels, brakes, etc.
Automotive manufacturers spend millions of dollars in research and development to provide an overall good balance between performance, drivability and reliability. NO AFTERMARKET COMPANY will be able to provide the same expectations as OEM... However some companies do pretty good job and spend significantly more time and money on their product than others. Once you're okay with this and realize your vehicle may occasionally not run right, make weird noises, require countless tuning adjustments, modify parts that are supposed to be "bolt-on" and more importantly be ok if everything goes boom and cost you more money to get it running again, then you're ready to roll the dice!
I spent a significant amount of time doing the same sort of research and having owned 40+ cars in various configurations from turbo rotarys, to bolt-on N/A Hondas and a handful of boxer turbos I bought what I thought was a well engineered, reliable kit with good performance results and it was for the most part, but I found many "flaws" areas that where "not practical" and I ultimately got tired of the hassles, hiccups and the worries of "whats next?" to the point I parted out the car and nearly sold it.
My car currently sits stock as far as engine mods go with the exception of suspension, brakes and a good wheel/tire combo and honestly I enjoy the car far more now with the peace of mind knowing it will start everyday... Its amazing how much faster the car feels with other adjustments and more importantly track days working on driver mod first and foremost. Once "I can" personally squeeze everything available out of the car then I'll revisit forced induction again.
My advice: Buy the best quality, best engineered, from the most well known company for the most you can afford... You get what you pay for!
PS. The new Eldelbrock S/C looks well thought out and apparently comes with a engine warranty when installed by a pro... Thats as close to OEM you're going to get.
On my fourth 86... and everything in between
Scracho is offline   Reply With Quote
HKS Supercharger V2 vs. Greddy Turbo Kit vs. Crawford Turbo Kit Ogremair Forced Induction 27 09-10-2015 04:39 AM
Looking for a turbo or supercharger kit!! Anthony7515 Want-To-Buy Requests 11 05-16-2014 08:25 AM
Turbo or supercharger dparnell Southeast 7 11-07-2013 02:40 PM
HKS Supercharger / Avo Turbo Kit / Greddy Turbo Kit - All Available at Import DPS!! rickspecd Forced Induction 4 07-12-2013 11:50 AM
Looking for a Frs for R&D on a turbo and supercharger Toxic Forced Induction 38 10-23-2012 03:13 PM
