#15 |
#16 |
Drives: 2013 FRS
Thanks everyone for all the input. I realize that in the big scheme of things $160 isn't the end of the world, but it's just mega frustrating that this happened. Especially after coming off a 24 hour shift only to find out about this.
Might try a couple of the tips before deciding to throw in the towel and have a professional do it. ...and beers are always a great idea... Sent from my SAMSUNG-SM-G920A using Tapatalk |
#17 |
Who would try and steal factory 86 wheels???
| The Following User Says Thank You to funwheeldrive For This Useful Post: | DAEMANO (12-01-2015) |
#18 |
Drives: red 2014 FR-S
I would get this,
http://www.harborfreight.com/8-inch-...ers-39716.html and then this, http://www.autozone.com/greases-and-...st/515413_0_0/ you might need to grind down the tips of the pliers to make them thinner to get a grip on the nut. cover the wheel with multiple layers of painters tape to minimize scratching to the wheel. you could also use a cutting wheel on a dremel to cut a notch into the nut and knock the nut off with a hammer and chisel. if that doesn't work and you still want to remove it yourself, get a good drill bit the size of the stud and drill straight in until the nut falls off. (like DJCarbine suggested) |
#19 |
Drives: FRS
well get a heavy duty socket that would fit over the damaged nut -
hammer it on and try to loosen it that way. Or they sell one of those sockets designed to have better bite. That's how I got my damaged wheel lock nut off once I damaged the lug nut key.
'14 Scion FRS
Tein Flex TE37 |
#20 |
Drives: Black 2013 FRS
Lots of the advice here will result in damaged wheels. You need to buy a kit like this one:
http://www.princessauto.com/en/detai...et/A-p8320954e It's just a set of tapered sockets which have a reverse thread on the inside. Pick the one that fits and give it a few smacks with a hammer, then remove. One thing to watch out for when choosing the socket is this: The taper and ID need to match the nut pretty closely, otherwise the socket may bottom out in the hole before it gets a good grip on the nut. I find that a ratchet or breaker bar works best with these because you can feel if it's biting in. Alternatively, a socket around a 18 or 19 will probably hammer on over it as well. This will probably ruin your socket, or at least damage it but should extract the nut. I've used this method to remove 4 wheel locks from my bmw after a garage over tightened them to 300+ ft lbs. I can guarantee one of these two methods will work for you with no damage to your wheels if you can swing a hammer and not miss lol. EDIT: PeterFRS beat me to it! |
| The Following User Says Thank You to d1ck For This Useful Post: | GIMMICK (12-06-2015) |
#21 | |
Airborne at your service
Drives: '17 BRZ Series.Yellow
But at least it's rare
#22 |
My first idea is weld something on there to crank it off. Or just pay some one to fix it. Probably need to throw a die on that stud to fix the threading if not replace it
#23 | |
![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Tcoat (12-04-2015) |
#24 |
hey you, yeah you <3
Drives: 2014 37J FR-S
Thats not him lol random video. He followed the same procedure.
#25 | |
Drives: Moped
#26 |
Drives: 2013 FRS
It definitely could have been a lot worse. Guess the wheel locks were a good investment after all. I was skeptical at first since I never figured that anyone would want stock wheels. Good thing I got them. I'm just paranoid about getting a flat in the mean time.
#27 |
Shut up baby, I know it
Drives: 2013 BRZ DMG
Go to a well known family own garage shop. They'll do it for much less. Had one of my nut froze due to a bad tread. Had new stud replace plus new nut for only $80. $30 to remove $5 for stud bolt and lug nut. $45 to install stud.
#28 |
Drives: gt86
| enkei rpf1 17X7 wheels with wheel locks and tpms and tires | imartisfrs | Wheels and Tires | 8 | 05-31-2015 06:59 PM |
| Spacers, RS-R Springs, TPMS Sensors, Wheel Locks, Wheel Caps, Supercharged Badge | DAEMANO | Wheels and Tires | 4 | 07-09-2014 01:35 AM |
| (CA) wheel locks | robot | Wheels and Tires | 8 | 05-30-2014 01:22 PM |
| Wheel locks on stock wheels | TM | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 5 | 04-19-2013 03:21 PM |
| OEM wheel locks? | zex | BRZ First-Gen (2012+) — General Topics | 3 | 04-14-2012 11:08 AM |
