Old 11-30-2015, 08:54 PM   #15
Dake
Dake's Avatar
Yet again proving that locks are only for honest people.
Eh - it's more about the inconvenience.
If the thief had the time and inclination they would've removed the other four nuts and just broken the stud off.
Dake is offline   Reply With Quote
Old 11-30-2015, 09:04 PM   #16
Ryoung91
Ryoung91's Avatar
Drives: 2013 FRS
Thanks everyone for all the input. I realize that in the big scheme of things $160 isn't the end of the world, but it's just mega frustrating that this happened. Especially after coming off a 24 hour shift only to find out about this.
Might try a couple of the tips before deciding to throw in the towel and have a professional do it.
...and beers are always a great idea...
Sent from my SAMSUNG-SM-G920A using Tapatalk
Ryoung91 is offline   Reply With Quote
Old 11-30-2015, 09:21 PM   #17
funwheeldrive
Who would try and steal factory 86 wheels???
The Following User Says Thank You to funwheeldrive For This Useful Post:
DAEMANO (12-01-2015)
Old 11-30-2015, 09:38 PM   #18
fx1mark
fx1mark's Avatar
Drives: red 2014 FR-S
I would get this,
http://www.harborfreight.com/8-inch-...ers-39716.html
and then this,
http://www.autozone.com/greases-and-...st/515413_0_0/
you might need to grind down the tips of the pliers to make them thinner to get a grip on the nut.
cover the wheel with multiple layers of painters tape to minimize scratching to the wheel.
you could also use a cutting wheel on a dremel to cut a notch into the nut and knock the nut off with a hammer and chisel.
if that doesn't work and you still want to remove it yourself, get a good drill bit the size of the stud and drill straight in until the nut falls off. (like DJCarbine suggested)
fx1mark is offline   Reply With Quote
Old 11-30-2015, 10:06 PM   #19
PeterFRS
PeterFRS's Avatar
Drives: FRS
well get a heavy duty socket that would fit over the damaged nut -
hammer it on and try to loosen it that way.
Or they sell one of those sockets designed to have better bite.
That's how I got my damaged wheel lock nut off once I damaged the lug nut key.
'14 Scion FRS
Tein Flex
TE37
PeterFRS is offline   Reply With Quote
Old 11-30-2015, 10:18 PM   #20
d1ck
Drives: Black 2013 FRS
Lots of the advice here will result in damaged wheels. You need to buy a kit like this one:
http://www.princessauto.com/en/detai...et/A-p8320954e
It's just a set of tapered sockets which have a reverse thread on the inside. Pick the one that fits and give it a few smacks with a hammer, then remove. One thing to watch out for when choosing the socket is this: The taper and ID need to match the nut pretty closely, otherwise the socket may bottom out in the hole before it gets a good grip on the nut.
I find that a ratchet or breaker bar works best with these because you can feel if it's biting in.
Alternatively, a socket around a 18 or 19 will probably hammer on over it as well. This will probably ruin your socket, or at least damage it but should extract the nut. I've used this method to remove 4 wheel locks from my bmw after a garage over tightened them to 300+ ft lbs.
I can guarantee one of these two methods will work for you with no damage to your wheels if you can swing a hammer and not miss lol.
EDIT: PeterFRS beat me to it!
d1ck is offline   Reply With Quote
The Following User Says Thank You to d1ck For This Useful Post:
GIMMICK (12-06-2015)
Old 11-30-2015, 10:20 PM   #21
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
This is very true about almost everything unfortunately :/
But at least it's rare
MS, CSCS, TSAC-F, CPT
Old 11-30-2015, 11:03 PM   #22
Ashikabi
Ashikabi's Avatar
My first idea is weld something on there to crank it off. Or just pay some one to fix it. Probably need to throw a die on that stud to fix the threading if not replace it
Old 11-30-2015, 11:19 PM   #23
Originally Posted by Packofcrows View Post
24 ok?
all "haha's" asided, My dad had to buy a special nut remover tool that vibrated the whole wheel. He ended up bending one of the metal rods(?), but it worked! This was in his old trucker days.
Asked my dad and he says he cant remember tool but he had to deform the nut with a chisel first.
DANG! .......... he did it without beer ..........
Tcoat (12-04-2015)
Old 11-30-2015, 11:22 PM   #24
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Thats not him lol random video. He followed the same procedure.
The Following 2 Users Say Thank You to Packofcrows For This Useful Post:
humfrz (12-01-2015), Tcoat (12-04-2015)
Old 11-30-2015, 11:31 PM   #25
Lonewolf
Lonewolf's Avatar
Drives: Moped
It sucks for sure, but at least your car wasn't on bricks and you could drive it home. Another plus with having wheel locks and lazy thieves.
Old 12-01-2015, 12:00 AM   #26
Ryoung91
Ryoung91's Avatar
Drives: 2013 FRS
It definitely could have been a lot worse. Guess the wheel locks were a good investment after all. I was skeptical at first since I never figured that anyone would want stock wheels. Good thing I got them. I'm just paranoid about getting a flat in the mean time.
Old 12-01-2015, 12:20 AM   #27
BlackJesus
Shut up baby, I know it
BlackJesus's Avatar
Drives: 2013 BRZ DMG
Go to a well known family own garage shop. They'll do it for much less. Had one of my nut froze due to a bad tread. Had new stud replace plus new nut for only $80. $30 to remove $5 for stud bolt and lug nut. $45 to install stud.
BlackJesus is offline   Reply With Quote
Old 12-01-2015, 12:21 AM   #28
Cedars
Drives: gt86
http://www.ft86club.com/forums/attac...1&d=1448947146
Could it be them?
Cedars is offline   Reply With Quote
enkei rpf1 17X7 wheels with wheel locks and tpms and tires imartisfrs Wheels and Tires 8 05-31-2015 06:59 PM
Spacers, RS-R Springs, TPMS Sensors, Wheel Locks, Wheel Caps, Supercharged Badge DAEMANO Wheels and Tires 4 07-09-2014 01:35 AM
(CA) wheel locks robot Wheels and Tires 8 05-30-2014 01:22 PM
Wheel locks on stock wheels TM Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 04-19-2013 03:21 PM
OEM wheel locks? zex BRZ First-Gen (2012+) — General Topics 3 04-14-2012 11:08 AM
