Old 11-30-2015, 07:05 AM   #15
VitViper
Drives: '15 FRS
My car(s) start reliably at freezing temps on E85.
Just takes a little work... lol
VitViper is offline   Reply With Quote
Old 11-30-2015, 07:51 AM   #16
steve99
Drives: FT86
What actual percentage e85, are we talking 90% or arround 70% ??
Old 11-30-2015, 08:44 AM   #17
VitViper
Drives: '15 FRS
80-82% off the flex sensor. Only time I had an issue when the car was on ECUTek is when it sat for a few weeks and I let the battery drain down. In fact, as I recall, it wasn't really all that hard to have the car start reliably every morning last winter -- it's been more work on the MoTeC since I had to start from scratch all over again, lol.
Some advice: all that extra fuel you're dumping in for cold starts during cranking isn't doing anything for you without the proper ignition timing during cranking -- which can be drastically different at high ethanol content than on pump gas.
Old 11-30-2015, 07:24 PM   #18
steve99
Drives: FT86
The e85 we have is a stable 90 plus ethanol, so were needing to add some extra . Unfortunatly it never gets below about 5C (about 40f i think) so cannot test below that but its firing first crank with e90+ down to those temps.
I would be pretty confident dropping the e percent down to 80 would see it firing reliably at lower temps, buy will look into the cranking timing
Old 11-30-2015, 08:54 PM   #19
VitViper
Drives: '15 FRS
Heh, E98 is what the race car drinks, starts just fine in 40-45* winter shop temps before we turn the heat on. It's quite cold out here in the winter and I don't have any problems firing cars up on any ethanol content :p
Old 12-01-2015, 12:54 AM   #20
DAEMANO
Time Traveller
Confirmed (for a while now) adding 1-2 gallons of CA91 to 9 gallons of e85 resolves any cold start issue. Will probably still update the cranking tables sometime or another.
Old 12-02-2015, 05:12 AM   #21
perry753
Drives: 2014 Subaru BRZ
It took me roughly 2 hours yesterday to fiddle with RomRaider and modify the OFT tune with the new cranking values. I was able to start my engine today in 40-50F with 1 crank. I've had to crank 3-5 times the day before. I highly recommend modifying your tune (it's super easy) and save you the troubles.
perry753 is offline   Reply With Quote
Random tip - cold starts Dammod AFRICA 34 09-22-2015 01:38 AM
Strange beep sound from engine on starts fanaticalz Issues | Warranty | Recalls / TSB 5 05-19-2015 01:10 AM
Did I damage or hurt my engine ? tonychet2 Engine, Exhaust, Transmission 32 03-11-2015 07:35 PM
Cold morning starts coldy CANADA 43 04-23-2013 02:30 PM
Issue: Cold starts jesseps CANADA 7 11-24-2012 11:26 AM
