Old 11-30-2015, 06:41 AM   #225
dkstylezz
dkstylezz's Avatar
Drives: 2013 Subaru BRZ
One question. I have been wondering if the 57xtreme 9.5 40 on our cars need a hub rings. 65 to 56 is what i found. Is it required for safety? Thanks!!! It seems there is a mixture of information which concerns me.
dkstylezz is offline   Reply With Quote
Old 11-30-2015, 08:27 PM   #226
jc0522
Drives: 2014 BRZ
Well...it's always better safe than sorry right? Think of it this way, you're spending at least $2K on wheels/tires, what's another $40-50?
And yes, 65 to 56 is correct.
jc0522 is offline   Reply With Quote
The Following 2 Users Say Thank You to jc0522 For This Useful Post:
dkstylezz (12-01-2015), opramwew (12-31-2015)
Old 12-01-2015, 04:00 AM   #227
dkstylezz
dkstylezz's Avatar
Thank you so much. Yes better safe than sorry.
Sent from my SAMSUNG-SM-N900A using Tapatalk
Old 12-02-2015, 03:09 AM   #228
BrzGp
Formula GP~/~
BrzGp's Avatar
Drives: 13' Brz Limited
Hey, just wanted to let ya guys know (even if you got them already) you do not need hub rings on these wheels. I have them also and another 57 model and they are made for brz nicely. Fits on the $ with the hub
BrzGp is offline   Reply With Quote
Old 12-02-2015, 03:42 AM   #229
BrzGp
Formula GP~/~
BrzGp's Avatar
Quick one in my cell..
- SP spec 18x9.5 Advan Neova ad08r 235/40
[IMG][/IMG]
Old 12-10-2015, 04:35 PM   #230
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
Would these fit on stock struts with lowering springs?
NVM found the answer.
Originally Posted by Mikey2style View Post
Thanks, I got my answers on FB.
So, I'll share the info I was told. For 18x9.5 squared, it will fit with trd springs but will rub in the front if you get big tires, 235/40 tire size recommended for the front if you're rocking trd springs. No problems with the rear with up to a 265 tire size.
I have the RS 1.0 so mine came with TRD springs, don't really wanna spend for coilovers.
I'm a really big fan of these rims so I'm glad I didn't HAVE to get coilovers.
Instagram: trevor.parque
Old 12-11-2015, 05:41 AM   #231
86 South Africa
POWER!!!!!!!!!!!!!!!!!!!!
Drives: White Toyota 86 (Scion FRs)
Originally Posted by Terran View Post
Wow, that looks amazing, especially with that color!! My previous car was a similar color, I miss it.
Updated photo taken with my DSLR:
Looks TIT (South African for AWESOME!)
I like driving!
86 South Africa is offline   Reply With Quote
Old 12-11-2015, 06:39 AM   #232
Mikey2style
Drives: FR-S Release Series 1.0
I suggest getting the 18x8.5 +42 for best fitment on stock struts. It has the same concave face as these.
Mikey2style is offline   Reply With Quote
The Following User Says Thank You to Mikey2style For This Useful Post:
derekbrz24 (04-21-2017)
Old 12-23-2015, 04:11 AM   #233
dkstylezz
dkstylezz's Avatar
Hello~ Just installed my 57xtreme sp spec 18 9.5 40 with RE11 255 35 18 lowered about an inch or slightly more...
My rears seem okay but i see rubbing marks on my front wheel. I have the RSR sports i club racer with camber plates. Haven't messed with the camber plates yet but would changing the front camber a little bit negative prevent further rubbing? and what degree would be ideal for camber in the front. Thanks for your help in advance!!! will post some pix once i adjust the front camber and a car wash.
Old 12-23-2015, 04:19 AM   #234
swarb
Be more specific. Marks on the wheel or tire? Where exactly? 1.3-3camber is good, depends on the driving style and depends on the rear, usually .5 or more in front than rear.
Old 12-23-2015, 04:27 AM   #235
dkstylezz
dkstylezz's Avatar
I saw lines close to the side wall of the tires as if it rubbed on the edge of my front fenders and the front fender edge had black marks like the tire rubbed on it sorry if I didn't explain well enough don't know how to exactly describe it.
Old 12-23-2015, 04:36 AM   #236
swarb
@dkstylezz It is probably the side marker or near it. Add camber and you are good. At one inch drop the rear will be about 1.5ish camber, I would say 2-2.5 is good in the front.
If you want to check, you can turn the wheel and look how close it is. You can also stiffen the shocks up a click or two.
The Following User Says Thank You to swarb For This Useful Post:
dkstylezz (12-23-2015)
Old 01-07-2016, 03:01 PM   #237
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
Originally Posted by Xerious View Post
You need 65mm to 56mm
Are these needed? When i ordered these wheels, i was told by the vendor they are not needed. I think in the original spec these maybe had a larger bore? Hard to get a caliper down into the center, but it appears to be around a 56 center bore on the wheels i got, so maybe the newere versions were made to the 56mm bore diameter for our vehicles.
gdrider77 is offline   Reply With Quote
Old 03-06-2016, 10:54 AM   #238
Lorne
Drives: 2013 Subaru BRZ, 1999 Dodge Neon
What lugs to use on these wheels? Would these work?
Lorne is offline   Reply With Quote
gramlights 57xtreme, toyo tyres
Wheel Directory: Gram Lights 57Xtreme 17x9.0 +40 L8Apex Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 71 08-05-2023 09:20 PM
Wheel Directory: Gram Light 57Xtreme: 18x8.5 +33 / 18x9.5 +40 jadewbj Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 378 06-26-2017 05:57 AM
Wheel Directory: Gram Lights 57Xtreme 19x9.5 +43 RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 31 12-04-2014 10:56 PM
Wheel Directory: Gram Lights 57Xtreme 17x7.0 +42 MVJ1975 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 10-05-2013 02:29 AM
Wheel Directory: Gram Lights 57Xtreme 18x7.5 +40 quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 09-05-2012 12:44 PM
