Old 11-13-2015, 08:12 AM   #1695
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by Astroboy View Post
Does anybody know where the oil passage goes behind the cam plate? If you look inside the block where the oil pump connects to, there's a sump going down and I was wondering where it leads to because I accidentally dropped quite a few of silicon down there when replacing the sealant on the cam plate after it started leaking again. I am hoping it will melt into the oil.
If you used appropriately rated silicone, it will not melt, as it should be rated for 500+F.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
CxG (03-07-2017)
Old 11-13-2015, 10:10 AM   #1696
Astroboy
Astroboy's Avatar
Drives: None
Do you know where that passage that's going down goes to? Because this happened back in march of this year I believe, and I am hoping it doesn't clog up any oil lines.
Sent from my LG-D850 using Tapatalk
Astroboy is offline   Reply With Quote
Old 11-13-2015, 10:16 AM   #1697
Sportsguy83
Drives: Limited BRZ
I really have no idea, but if that happened so many months ago and nothing has happened, I think you're clear.
Astroboy (11-13-2015)
Old 11-16-2015, 08:14 AM   #1698
Basket Case
Drives: 2013 Raven fr-s
Hey everyone, I have been doing a ton of reading of and on since this thread started. Now that we are at near 80 pages there is no way i can rea it all.
I think the AVO kit is the best option for me as I love the sound of the UEL header, not need to remove the oil pan, OEM style oil pump option, etc. My question is, how are the header/manifold holding up over time? I know i remember reading about leaking manifolds, warped flanges, etc. has that pretty much been taken care of now? I DD my car and DO NOT have time to have the car down constantly fixing minor issues, and thats why I have waited for 3 years to do any kind of power upgrades.
Basket Case is offline   Reply With Quote
The Following User Says Thank You to Basket Case For This Useful Post:
Astroboy (11-18-2015)
Old 11-19-2015, 12:46 PM   #1699
GremlinGSP
I've never had any issues with mine. I used the grimmspeed gaskets and the header flange was machined though. I bought my AVO kit from a member after he ran it for a bit.
It was exactly what the car needed.
GremlinGSP is offline   Reply With Quote
Old 11-23-2015, 12:41 AM   #1700
Dammod
Dammod's Avatar
Drives: .
Little exhaust clip from our recently Turbo'd GT86:
[ame="https://www.youtube.com/watch?v=tRVUOiurxP4"]https://www.youtube.com/watch?v=tRVUOiurxP4[/ame]
"Some will follow your footsteps, easier than they will your advice."
Dammod is offline   Reply With Quote
Old 11-29-2015, 05:34 AM   #1701
Jonde875
Drives: GT86
Talking
Hi everybody!
I have a question about Ecutek´s boost settings via map switching.
Do I need to add something to my setup like "separate boost controller and valve" to get it done?
If so can you guys give me advice "best valve" Im complete newbie about this thing.
My kit has 8 actuator and 3" AVO catted full exhaust.
Jonde875 is offline   Reply With Quote
Old 11-29-2015, 10:00 AM   #1702
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
Originally Posted by Jonde875 View Post
Hi everybody!
For ecu controlled boost you'll need a boost control solenoid that plugs into an existing harness (replaces the evap). You'll need to talk to your tuner about getting it enabled
You could also run a standalone boost controller, either manual or electronic. The problem with this route as a newbie is that the potential to blow something up is quite high
In my opinion, you should go with the ecu controlled boost setup because it will be easier to use and setup. Talk to your tuner, they probably have a solenoid for sale
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
The Following 2 Users Say Thank You to protpibe For This Useful Post:
Draco_PR23 (11-29-2015), Jonde875 (11-29-2015)
Old 11-29-2015, 12:16 PM   #1703
Jonde875
Drives: GT86
Yeah that Ecu controlled is what I was searching but wasnt sure what it needs to work.
Old 11-29-2015, 04:40 PM   #1704
Astroboy
Astroboy's Avatar
Drives: None
How's the winter treating you guys with the avo kit. Anybody still running oil coolers in the winter
Old 11-30-2015, 11:48 AM   #1705
Jonde875
Drives: GT86
Here works well! No problems
GT Rests in peace in the garage this winter!
The Following User Says Thank You to Jonde875 For This Useful Post:
Astroboy (11-30-2015)
Old 11-30-2015, 11:56 AM   #1706
Astroboy
Astroboy's Avatar
Drives: None
GT as in mustang GT?
Old 11-30-2015, 01:24 PM   #1707
Jonde875
Drives: GT86
GT86!
Old 12-19-2015, 06:33 PM   #1708
Astroboy
Astroboy's Avatar
Drives: None
What clutch Are you guys running with this kit? I think I might have smoked my stock clutch
avo, avoturboworld
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
OFF TOPIC: Spotted a Gallardo markmatley Hawaii 4 02-24-2013 04:26 PM
