Old 11-27-2015, 07:23 AM   #15
thambu19
Drives: Scion FRS
Originally Posted by bfrank1972 View Post
Aftermarket EL gets no love
How different should an EL cal be from an UEL? Were they mighty different in the past?
thambu19 is offline   Reply With Quote
Old 11-27-2015, 08:09 AM   #16
bfrank1972
Drives: 2013 FR-S Argento
Yeah if you look at the maps the intake & exhaust cam timing are significantly different - I'm no expert but reading up on it a bit. I figure part of it has to do with UEL has fewer issues with pulse interactions at the merge because of the different runner lengths. Lots of factors involved really - eventually I might just have Shiv do a custom tune
Old 11-27-2015, 08:50 AM   #17
Griever423
Drives: 2020 BRZ PP
WOW those are some serious gains! I can't wait to update my tune now.
Griever423 is offline   Reply With Quote
Old 11-27-2015, 01:48 PM   #18
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
@Shiv@Openflash
Your work is a piece of art. Total respect. I do have a question though. Why did you guys decide to keep the torque bump at 4800rpm? Since it is only a bump occurring at a short stretch of rpms most OEMs would have sliced it off to protect engine HW from peak cylinder pressures mostly because the torque isn't sustained over a larger engine speed.
The FA20 can handle way more power loads that we could ever achieve through sound naturally aspirated tuning. So with that in mind, our goal was to maximize torque at every RPM point. The OFH was designed to maximize average torque in the 4500-7500rpm range since this is where you run the engine when running aggressively through the gears. That extra bump in torque between 4500-5000rpm feels really nice when you grab the next gear. The tradeoff is the inverse dip centered at 3800rpm. But it's high enough that it's not felt during normal driving (2500-3500rpm) and low enough that it never comes into play when you rowing through the gears for max acceleration. Much of the dip could be subjectively "removed" by reducing torque bump in the 4000-5000rpm range but what's the fun in making a car slower?
Shiv@Openflash is offline   Reply With Quote
Old 11-27-2015, 03:28 PM   #19
thambu19
Drives: Scion FRS
Awesome!
Sent from my HTC One_M8 using Tapatalk
Old 11-27-2015, 04:22 PM   #20
malubawla
poor man's evora
malubawla's Avatar
Drives: Turbod BRZ
looking good as always man!
malubawla is offline   Reply With Quote
Old 11-27-2015, 04:33 PM   #21
jupillam
jupillam's Avatar
Drives: White out Scion Frs
any upgrades for stage 2 EL header?
jupillam is offline   Reply With Quote
Old 11-27-2015, 06:36 PM   #22
JB86'd
JB86'd's Avatar
Drives: JAWS
Will copying over the VVT tables you posted for the JDL UEL be compatible, or do VVT mapping changes require ignition timing/other changes?
@Shiv@Openflash
JB86'd is offline   Reply With Quote
Old 11-29-2015, 07:55 AM   #23
pl1ght
Drives: 2015 Alfa Romeo 4C
yes plz! Thanks Shiv! Cant wait for this.
pl1ght is offline   Reply With Quote
Old 11-30-2015, 11:37 AM   #24
bababooey
Drives: BRZ SWP Limited -6MT
i was really digging not having to wring the engine out to redline to feel the power after adding in the UEL headers with stage 2. cant wait to experience the improved driveability!
bababooey is offline   Reply With Quote
Old 11-30-2015, 11:49 AM   #25
D_Thissen
D_Thissen's Avatar
Do you think you can reach the elusive 200whp on 93? You are almost there, and that baseline dyno doesn't seem overly high either. With the stock tune running 94, Q300 and catless frontpipe, I had a baseline of 169.
I cant wait to get my car out of storage in the spring and try this along with my new borla uel! Keep up the great work!
Old 11-30-2015, 12:22 PM   #26
tato.valverde
tato.valverde's Avatar
Drives: Scion FRS RS1.0,Mazda MX-6 2.5i 4WS
Awesome!! Is it safe to run with JDL high flow 200 cell catted UEL header?
tato.valverde is offline   Reply With Quote
Old 11-30-2015, 12:59 PM   #27
kch
Senior Misanthrope
kch's Avatar
The OFT stage 2 tunes are designed for catless headers, so it's not really suited for your header.
Old 11-30-2015, 01:07 PM   #28
tato.valverde
Well, I know that, but it's been said before that it's safe with 200cel high flow cats. And i've been running the older maps with no trouble.
But i'm wondering if these new maps are too aggressive for the high flow catted headers...
Just how noticeable is OFT+OFH and stage 2 tune? BBYZILA Software Tuning 58 03-20-2018 11:56 AM
OFT 2.0 Stage 1 93 Tune MurderRider Software Tuning 57 03-21-2016 12:30 AM
Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 TopGearSolutions Engine, Exhaust, Bolt-Ons 90 04-14-2014 08:15 PM
FA20club.com Turnaround Times On Modified Tune Files FR-S Matt Software Tuning 103 11-13-2013 01:48 PM
So whate does stage 3 tune do? I already have 2 Frsexxxy Engine, Exhaust, Transmission 17 05-14-2013 06:30 AM
