#295 |
Drives: White BRZ Limited
So I forgot to update here. But I bought the 17x9 titans in sports bronze and wrapped them in 255/40 continental DW's fit perfect and love the way they sit and look
| The Following User Says Thank You to Sgtfluffy16 For This Useful Post: | mizzta21 (01-31-2016) |
#296 | |
#297 |
Drives: GTS86
Hey guys, this is my current setup and I have a weird problem :c
![]() The wheel caps I have on them are so ugly? ![]() How would I go about removing them/making them look like this?
| The Following User Says Thank You to Shims For This Useful Post: | D_Thissen (02-27-2016) |
#298 |
Not a troll
Peel the stick off? Or get new wheel caps? Or take the cap off entirely?
Do you know how to take a wheel off? If you can do that, you can change the center caps. |
#299 |
Center caps typically pop off easily, but instead of prying on them from the front and potentially gouging them, I'd recommend removing the wheel and pop them off from behind. Replacing them can be tricky because not all center caps are the same.
If the logo in the center is hard enough, you could tape off the edges and scuff it with a scotch brite pad and paint it. Or remove the sticker entirely like Cole mentioned. If the sticker removed leaves an ugly surface, you could buy some spare premade carbon panel and cut round discs to fit into them. If you really want to do that but don't know how, I work with carbon every day, if you'd be willing to send me your caps I could bond some carbon discs into the centers. |
#300 | |
Drives: GTS86
Oh and thanks for the offer, but I'm probably going to buy some flat universal ones probably after popping these ones out (apparently the size of the rota caps are 63mm?) |
#301 | |
#302 | |
Drives: GTS86
I actually pulled the sticker off to see what it'd look like underneath, turns out there was a big hole in the middle. So I just got an L shape piece of metal and pulled it out, took a few minutes to get them all off. (I still bought the correct torque wrench anyway for future usage!) |
#303 |
Drives: Whiteout FR-S
Rota RKR's in Hyper Black, 18x8.5 and 9.5 +44 all around. 225/40 and 255/35 tires. ST coilovers. Wheels are for sale, will post an ad today.
#304 |
Drives: 85.5 Porsche 944, '15 mustang GT PP
Rota has a new logo design that looks much better. You could try finding the new design center caps.
#305 |
Drives: '13 frs 6MT
#306 |
A Demon
Drives: Raven GT86
#307 |
Drives: 2016 frs
I'm wanting to get rota titans but wanted to know if this is a good set up for a DD/ drag strip car. 17×7.5 front and 17×9.5 for a rear
Tire size I'm thinking 235/35/17 front and 265/35/17 rear. This will be on stock suspension for now |
| The Following User Says Thank You to BostonDave91 For This Useful Post: | evo8jpp (02-23-2016) |
#308 |
The Stig's African Cousin
Drives: 2014 wrb brz
It's going to suck not being able to rotate tires and I'm guessing your FI or have a engine swap so you can use all that tire.
Instagram: brandonblt2
Build Thread: http://www.ft86club.com/forums/showt...86#post2219386 Flickr: brandonblt567 |
| The Following User Says Thank You to brandonblt2 For This Useful Post: | Cole (02-09-2016) |
| The ROTA Thread | WheelDude.com | BRZ Photos, Videos, Wallpapers, Gallery Forum | 47 | 02-28-2015 12:17 PM |
| Group Buy - Rota Slipstreams or Rota Grid | davidsolarbell | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 25 | 12-17-2013 12:04 PM |
| Rota D wheel thread | Mach V Dan | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 0 | 03-05-2013 11:46 AM |
| Is there a thread for 'people doing stupid things in their brand new car' thread? | Symbiont | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 36 | 02-18-2013 12:24 PM |
| Feeler thread: 18x8.5 +44 Rota DPT's | JoeBoxer | Wheels and Tires | 4 | 09-10-2012 01:59 AM |
