Old 08-09-2015, 10:58 AM   #295
Sgtfluffy16
Drives: White BRZ Limited
So I forgot to update here. But I bought the 17x9 titans in sports bronze and wrapped them in 255/40 continental DW's fit perfect and love the way they sit and look
Sgtfluffy16 is offline   Reply With Quote
The Following User Says Thank You to Sgtfluffy16 For This Useful Post:
mizzta21 (01-31-2016)
Old 08-09-2015, 11:02 AM   #296
Sgtfluffy16
Originally Posted by Pureinsanity View Post
Hello I'm going to buy some Rota grids for my car! 17's 9 inches wide should I go with 35 or 42 offset? Not planning on lowering the car anytime soon due to the harsh roads here in PA. So the main thing is I don't want to rub anything and don't want the handling to be disturbed. thanks!
Good luck I live in pa as well
Old 11-26-2015, 05:23 AM   #297
Shims
Shims's Avatar
Drives: GTS86
Hey guys, this is my current setup and I have a weird problem :c
The wheel caps I have on them are so ugly?
How would I go about removing them/making them look like this?
Shims is offline   Reply With Quote
The Following User Says Thank You to Shims For This Useful Post:
D_Thissen (02-27-2016)
Old 11-26-2015, 08:36 AM   #298
Cole
Not a troll
Cole's Avatar
Peel the stick off? Or get new wheel caps? Or take the cap off entirely?
Do you know how to take a wheel off? If you can do that, you can change the center caps.
Cole is offline   Reply With Quote
Old 11-26-2015, 09:48 PM   #299
wheelhaus
wheelhaus's Avatar
Center caps typically pop off easily, but instead of prying on them from the front and potentially gouging them, I'd recommend removing the wheel and pop them off from behind. Replacing them can be tricky because not all center caps are the same.
If the logo in the center is hard enough, you could tape off the edges and scuff it with a scotch brite pad and paint it. Or remove the sticker entirely like Cole mentioned. If the sticker removed leaves an ugly surface, you could buy some spare premade carbon panel and cut round discs to fit into them.
If you really want to do that but don't know how, I work with carbon every day, if you'd be willing to send me your caps I could bond some carbon discs into the centers.
Old 11-26-2015, 11:10 PM   #300
Shims
Shims's Avatar
Drives: GTS86
I see, I'd have to buy a torque wrench wouldn't I? What kind of torque specs would I need for these lug nugs? 90ft.lb? I just want to make sure I do it right.
Oh and thanks for the offer, but I'm probably going to buy some flat universal ones probably after popping these ones out (apparently the size of the rota caps are 63mm?)
Old 11-26-2015, 11:32 PM   #301
wheelhaus
wheelhaus's Avatar
Yep you got it, I think the manual states 89 lb-ft but 90 is fine. Torque wrenches can get expensive but the one from Harbor Freight works great for occasional garage use. Look for the 1/2" drive click type, you might need a 1/2" socket size that fits your spline drive key, I think it's a 19mm but I'm not sure... 1/2" refers to the square connector on the wrench. The 3/8 wrench doesn't go to high enough torque.
Old 11-27-2015, 01:18 AM   #302
Shims
Shims's Avatar
Drives: GTS86
Thanks! <3
I actually pulled the sticker off to see what it'd look like underneath, turns out there was a big hole in the middle. So I just got an L shape piece of metal and pulled it out, took a few minutes to get them all off.
(I still bought the correct torque wrench anyway for future usage!)
Old 11-27-2015, 05:21 AM   #303
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Rota RKR's in Hyper Black, 18x8.5 and 9.5 +44 all around. 225/40 and 255/35 tires. ST coilovers. Wheels are for sale, will post an ad today.
Old 11-27-2015, 07:32 AM   #304
Chad11491
Drives: 85.5 Porsche 944, '15 mustang GT PP
Rota has a new logo design that looks much better. You could try finding the new design center caps.
Chad11491 is offline   Reply With Quote
Old 01-30-2016, 09:14 PM   #305
2broke4turbo
Drives: '13 frs 6MT
Originally Posted by WheelDude.com View Post
Wheels: 17×9 Rota Titan - Flat Black (5×100/e42/73)
this may be a noob question, but in (5x100/e42/73) what does the "73" mean?
2broke4turbo is offline   Reply With Quote
Old 01-31-2016, 11:32 AM   #306
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
Pretty sure that's centerbore size.
Old 02-09-2016, 12:51 PM   #307
BostonDave91
Drives: 2016 frs
I'm wanting to get rota titans but wanted to know if this is a good set up for a DD/ drag strip car. 17×7.5 front and 17×9.5 for a rear
Tire size I'm thinking 235/35/17 front and 265/35/17 rear. This will be on stock suspension for now
BostonDave91 is offline   Reply With Quote
The Following User Says Thank You to BostonDave91 For This Useful Post:
evo8jpp (02-23-2016)
Old 02-09-2016, 01:26 PM   #308
brandonblt2
The Stig's African Cousin
brandonblt2's Avatar
Drives: 2014 wrb brz
It's going to suck not being able to rotate tires and I'm guessing your FI or have a engine swap so you can use all that tire.
Instagram: brandonblt2
Build Thread: http://www.ft86club.com/forums/showt...86#post2219386
Flickr: brandonblt567
brandonblt2 is offline   Reply With Quote
The Following User Says Thank You to brandonblt2 For This Useful Post:
Cole (02-09-2016)
The ROTA Thread WheelDude.com BRZ Photos, Videos, Wallpapers, Gallery Forum 47 02-28-2015 12:17 PM
Group Buy - Rota Slipstreams or Rota Grid davidsolarbell Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 25 12-17-2013 12:04 PM
Rota D wheel thread Mach V Dan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 03-05-2013 11:46 AM
Is there a thread for 'people doing stupid things in their brand new car' thread? Symbiont FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 36 02-18-2013 12:24 PM
Feeler thread: 18x8.5 +44 Rota DPT's JoeBoxer Wheels and Tires 4 09-10-2012 01:59 AM
