#29 |
Drives: DGM BRZ MT
It doesn't say anywhere whether he used the jack properly or not. The manual clearly says ONLY use it for the FRS/BRZ, and ONLY to be used to lift a single wheel off the ground at a time. This means you don't have to lift it very high, and there is minimal weight on the jack.
From the looks of the picture, I get a feeling he didn't follow those guidelines. It's for you to change a single spare tire in emergencies. Good idea to spread the word though. |
#30 |
Drives: 2015 Series.Blue
The lower arms are geared together, but it's quite easy damage that part. I'm better he was halfway in the ditch while he used it which means the car wasn't level. At that point no jack is really safe...
#31 |
That's exactly what I thought as well.
These types of jacks can be very dangerous if extended too high. The jack in the pic was extended too high. The damage to the screw happened when the car moved or fell over. No way that screw shaft bent from any kind of normal use. |
#32 |
Thanks
I had one of those jacks fail on me when I was changing a tire on a minivan. Fender hit my elbow but luckily I have threaded on 3 lugs so I was spared. I was gonna complain to honda about it but the car was 10 years old and I felt it would just waste my time...
And yea, the screw on mine actually just broke at the part where it threads through the hole, didn't bend or cross thread or anything like that.
#33 |
Drives: 2015 Subaru BRZ Limited
I just bought my BRZ a few months ago, so I'm headed into my first winter with it. I'm soon to be buying a set of winter tires and wheels. My question is, would you guys use the OEM jack for swapping the wheels off your car? Or is there a better jack I should buy?
#34 | |
Drives: 2016 Oceanic, "base" model
Frankly, I wouldn't wear out any emergency equipment because it might self destruct when I need it: in an emergency. It would be like using those little cigarette lighter socket powered air pumps you can buy in emergency roadside kits to maintain your tire's air pressure and then finding yourself in the middle of nowhere with a flat, but fillable, tire but a burned out pump. |
#35 | ||
#36 | ||
| $10 Jack Buddies | blalor | DIY (Do-It-Yourself) Guides | 24 | 10-20-2017 07:16 PM |
| usb/3.5 jack relocate + usb charger | BRZranger | Electronics | Audio | NAV | Infotainment | 22 | 11-13-2012 10:42 PM |
| Where ti jack car up at? | skatery1989 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 2 | 08-13-2012 01:53 AM |
| Parking/Emergency Brake - "Clunk" | EsoBOFH | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 06-24-2012 11:43 AM |
| Jack Spots? | feldy | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 8 | 06-11-2012 09:09 AM |
