Old 10-21-2015, 01:29 AM   #337
iNcontroL
Drives: 2014 Scion FR-S Monogram (Whiteout)
Originally Posted by EzyBrzy View Post
It is referring to the offset of the wheel. The lower the number, the more the wheel will stick out. The higher, the more tucked it will look.
And +33 Front and +40 Back is the recommended setup?
iNcontroL is offline   Reply With Quote
Old 10-21-2015, 05:23 PM   #338
EzyBrzy
Drives: 2015 WRB BRZ
It depends on how you want it to look. Also depends on how wide the wheels are. An 8in wide wheel at +35 offset will sit differently than a 9in wide wheel with same offset. Stock wheels are 17x7 with an offset of +48 just so you get an idea.
EzyBrzy is offline   Reply With Quote
The Following User Says Thank You to EzyBrzy For This Useful Post:
iNcontroL (10-24-2015)
Old 10-24-2015, 01:35 AM   #339
iNcontroL
Would 225/40/18 or 235/40/18 be best for 18x8.5 +33 front wheels?
Old 11-26-2015, 05:13 PM   #340
Ryder86
Ryder86's Avatar
Drives: 2015 BRZ Limited
Originally Posted by shiumai View Post
Contributing pics of this set up for 57xtremes on DGM BRZ - 1" drop on swift springs, Front 18x8.5 +33, 235/40/18, Rear 18x9.5 + 40 265/35/18 toyo proxes T1 sport.
This looks great! No denying that! Many people I talk to tell me that when they lower and go to 18's the steering slows down and the car isn't as "quick through the turns as far as feeling goes. Would you recommend your suspension and tire/wheel setup to someone using this car for an aggressive street car? Did it lose it's good OEM feel?
Thanks
Ryder86 is offline   Reply With Quote
Old 11-26-2015, 05:40 PM   #341
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
Thanks
it's been so long since i had an OEM set up that i don't remember how it felt. i'm on tein flex Z coilovers now. with the swift springs, i felt that the rear end had too much lateral wobble when hitting bumps mid-curve. the tein flex Z's were a great choice for me.
i think that with wider tires and staggered setup, you do get some understeer, which is that 'slowness' that people talk about. but that can be dealt with in part with your alignment with more camber up front.
the bottom line is, i'm happy with the way it turns right now. it feels quick and responsive enough for me. i just drive street and canyons sometimes - no autocross.
shiumai is offline   Reply With Quote
Old 01-20-2016, 11:40 AM   #342
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
I can officially say I am almost part of the club! Only reason I say almost is because I havent mounted them yet.
18x8.5 +33 wrapped in 245/35 Michelin PSS
18x9.5 +40 wrapped in 255/35 Michelin PSS
Instagram: trevor.parque
HachiRo (01-20-2016)
Old 03-09-2016, 02:12 PM   #343
shaynek
shaynek's Avatar
Drives: BRZ Limited; GR86
Do you know the cap size that will fot these wheels?
shaynek is offline   Reply With Quote
Old 03-09-2016, 02:15 PM   #344
shiumai
shiumai's Avatar
Are you looking to put on caps other than what rays offers? rays offers at least 2 different caps.
Old 03-09-2016, 02:20 PM   #345
MisterSheep
Killed Scion
sorry.. wouldn't know I got them with the caps already on. I'm not sure why anyone would want to go with anything other than these rays caps. They're beautiful in person.
Old 03-09-2016, 02:32 PM   #346
shaynek
shaynek's Avatar
so the problem is people tend to steal these. i was going to go with something cheap so if someone decided to steal them i wouldn't care as much.
Old 03-09-2016, 05:21 PM   #347
shiumai
shiumai's Avatar
Might as well go with cheap wheels too, in case those get stolen.
Old 03-10-2016, 01:40 AM   #348
shaynek
shaynek's Avatar
much harder to steal wheels with locks
Old 03-10-2016, 08:57 AM   #349
shiumai
shiumai's Avatar
along the same lines, you might be able to replace the cap screws with torx screws or some other bit so they're harder to steal.
Old 03-10-2016, 09:20 AM   #350
shaynek
shaynek's Avatar
Yea I may look into that actually
Wheel Directory: Gram Lights 57Xtreme 17x9.0 +40 L8Apex Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 71 08-05-2023 09:20 PM
Wheel Directory: Gram Lights 57Xtremes 18x8.5 +45/18x9.5 +40 WorkoArt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 02-18-2017 06:46 PM
Candy Red Gram Light 57Xtreme 18X9.5 +40 ugadogs_11 Wheels and Tires 8 10-03-2013 09:04 AM
FS: Gram Lights 57Xtreme 18x8.5, 18x9.5 funcheung Canada Classifieds 7 09-16-2013 05:01 PM
