#15 |
Resident Gear Head
WPC treatment of all the gears and rear diff good for 1-3% power increase from loss.
Additionally heat and friction wear items faster, break down gear lube ect. Part of the plan for my build
Subaru BRZ/FRS Facebook News and Tech Page
My FB Build page CLICK AND LIKE! Twitter and Instagram @misairubrz |
#16 |
Drives: 2014 GT86
FRSW12: > these TWS T66-F of 16" size - just 10.63lbs 4.82kg.
As for 17" .. AG Forged SMK Monoblock AG3-SMK26 17x7.5 9.5lbs 4.3kg Velox PG-Rev10 17x7 11.5lbs 5.2kg Watanabe F8 Magnesium 17x7 11.5lbs 5.2kg OZ Forgiata 17x7.5 13.2lbs 5.99kg J's Racing PR 6 17x7.5 13.2lbs 5.99kg Tom's Racing EP-02 +50 17x7 13.2lbs 5.99kg RAC Monolites RS110 17x8 13.3lbs 6.03kg Buddy Club P1 Racing QF 17x8 13.6lbs 6.17kg > Volk TE37 SL - should be lighter then CE28N Volk CE28N 17x7.5 13.8lbs 6.26kg or 12.32lbs 5.58kg? Racing Hart CP-035R 17x8 13.6lbs 6.17kg Toybox48 Hethel 17x8 13.7lbs 6.4kg Tehnicraft T6 +43 17x8 13.8lbs 6.26kg Velox PG-5S +42 17x7 13.8lbs? 6.26kg TWS T66-F 17x8 13.93lbs 6.32kg > Kosei K4R +50 Cast 17x7 14.0lbs 6.35kg Motegi MR221 Traklite 1.0 Cast 17x7 14.0lbs 6.35kg SSR Type-C +38 Cast 17x8 14.3lbs 6.49kg Velox VX-6R +42 17x7 14.5lbs 6.58kg Kosei K1 TS +50 Cast 17x7 14.6lbs 6.62kg Enkei RPF1 +42 Cast 17x7 14.8lbs 6.71kg .. most of forged lighter ones are discontinued. But at least Volk TE37 SL & CE28N you should still be able to buy. Or check from tirerack Kosei K4R. Yes, they are cast, but you can buy 3 sets of those Kosei-s for price of 1 forged set and they weight only very slightly (300gr) more then TWS T66F 17x8. |
#17 |
Drives: 13 mt fr-s
I just purchased an aluminum driveshaft, it's pretty fun.
Slight gear-y noise, kinda reminds me of a supercharger, but alot more quiet. I can definitely feel the improved throttle response. Carbon fiber one is 2x the price for 1 pound less. Dumbbb. |
#18 | |
#19 | |
#20 |
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
nobody said flywheel?
#21 |
...Just add nauseum
Drives: 2003 (AP1) S2000
Lose the entire stock drivetrain. Start over.
Wait, just kidding. The differential is fine. You can keep that. Throw the rest out.
There are many ways to displace.
-Spartarus |
#22 | |
Junior
Drives: a car
#23 | |
Resident Gear Head
Because of the price? PS some short shifters do not clear the aluminum shaft because the diameter is larger than stock
#24 | |
Dismember
Drives: FR-S & JSW
The fault lies not in our cars, dear Brutus, but in ourselves.
#25 |
Drives: 13 BRZ, 18 STI
I stand corrected. I forgot the driveshaft is 2 piece.
Racecar spelled backwards is racecaR, because RacecaR
#26 |
Drives: 2014 GT86
CSG Mike: You are sure about TE37 SL being heavier then CE28?
#27 |
Drives: gt86...among others
Others are more expert then me, but my basic understanding is anything that moves before the tires is taking energy. Get that torque to the wheels!
So pistons, bearings, gears, clutches, flywheels, driveshafts, rear-ends, CV-joints, axles all require power to rotate. All drivetrain to chassis mounts also absorb energy and they require it to hold everything in place. Reducing power loss through transfer = more power Simple and cheapest solution is attack the chassis first. So in a perfect world (where NHV doesn't matter) you could make all flexible mounts as stiff as possible. Solid motor mounts Solid tranny mount Single piece driveshaft Solid rear-end bushings Solid rear subframe bushings This set-up it would probably rattle your teeth out but it would reduce a lot of power-transfer loss for the drivetrain. Horsepower turns heads, torque wins races
racing gods live deep in corners
#28 | |
Drives: 2013 WRB Subaru BRZ
| Backfire + Loss of power | RavioliG | Issues | Warranty | Recalls / TSB | 2 | 11-16-2014 10:56 PM |
| Hi rev power loss? | lbroskee | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 09-29-2012 10:47 PM |
| CEL, Loss of Traction Light, Loss of Power | pituala | Issues | Warranty | Recalls / TSB | 19 | 09-05-2012 12:23 PM |
| Loss of power after gassin up HELP!!!! | Ad8707 | CANADA | 26 | 07-29-2012 07:24 PM |
| Dyno testing and "drivetrain loss" | serialk11r | Other Vehicles & General Automotive Discussions | 5 | 11-03-2011 09:55 AM |
