Old 11-24-2015, 11:33 AM   #561
twag4
Drives: frs
I can honestly say that I truly believe this car is faster with the stock cat back than it was with the Corsa very loud one. I am supercharged with the Jackson racing kit with a delicious tune, and even though the car was very loud compared to stock header, it felt very different, maybe not better just different. Now though, with the stock cat back, it is absolutely furious. Obviously the tune has become more optimal with ecu learning, but holy cow this car Just makes me giggle all the time now. I can perform second gear throttle induced slides at will at fairly low speeds. Plus I can hear the magical rushing flow of the header now. It is like an electric motor from 3000 rpm on now. It is seriously fast compared to stock and supercharged on the stock header. Plus, it is beautiful to look down in the front of the engine compartment and see that beautiful and very acute merge of the Type A. Also the two into one merge of the overpipe at the back right of the engine. Save your nickels lads, buy this header. You absolutely will not be unhappy, you will be a believer. It literally added 2000 more rpm of much improved pull to my already supercharged car.
twag4 is offline   Reply With Quote
The Following 3 Users Say Thank You to twag4 For This Useful Post:
AceHeader-MT (11-25-2015), CSG Mike (11-24-2015), Kotu100 (11-24-2015)
Old 11-24-2015, 11:44 AM   #562
twag4
Drives: frs
Originally Posted by churchx View Post
*) catless header
*) muffler delete.
It certainly WILL be loud. If it's TOO loud or not is too subjective thing, each has personal limits of what is acceptable and what will 'bleed his ears'.
My car with this header, JDL catted and resonated front pipe, and the Corsa cat back showed 118 decibels at 20 feet at about a 45 degree offset using an iphone6 app. I was truly concerned that I would hurt someone else's ears if they were next to me with a window down and I agressively got on the throttle. That is loud by anyone's definition. A magnaflow 22" straight through muffler replaced the Corsa resonator, but only helped a little bit. The stock cat back is nice and quiet, but has a wicked buzz at about 2000 RPMs.
Old 11-24-2015, 11:58 AM   #563
churchx
churchx's Avatar
Drives: 2014 GT86
Originally Posted by Stumpygt86 View Post
I currently have a catless UEL header with the muffler delete and it is okay, just a little drone.
And for some it wasn't, wasn't to extent that they installed back stock catback or bought other aftermarket that was quieter. To each his own i guess.
Stumpygt86 (12-04-2015)
Old 11-24-2015, 01:11 PM   #564
CSG Mike
CSG Mike's Avatar
So do you think the Type B 250, stock exhaust but with a muffler delete will bleed my ears?
If you mean stock front pipe, it'll be quiet. With a non-catted or Ace front pipe, it will be deafeningly loud.
Old 11-24-2015, 01:15 PM   #565
CSG Mike
CSG Mike's Avatar
Originally Posted by twag4 View Post
I can honestly say that I truly believe this car is faster with the stock cat back than it was with the Corsa very loud one. I am supercharged with the Jackson racing kit with a delicious tune, and even though the car was very loud compared to stock header, it felt very different, maybe not better just different. Now though, with the stock cat back, it is absolutely furious. Obviously the tune has become more optimal with ecu learning, but holy cow this car Just makes me giggle all the time now. I can perform second gear throttle induced slides at will at fairly low speeds. Plus I can hear the magical rushing flow of the header now. It is oike an electric motor from 3000 rpm on now. It is seriously fast compared to stock and supercharged on the stock header. Plus, it is beautiful to look down in the front of the engine compartment and see that beautiful and very acute merge of the Type A. Also the two into one merge of the overpipe at the back right of the engine. Save your nickels lads, buy this header. You absolutely will not be unhappy, you will be a believer. It literally added 2000 more rpm of much improved pull to my already supercharged car.
I think you have the same psychological problem I have. With loud cars, I'm much less inclined to step on the throttle, so the net result is that the car is "slower". I'm afraid of getting pulled over and attracting undue attention.
I can't wait for the silent muffler to be finished... cuz then I can just floor it everywhere stealthily.
This was verified for myself via datalogs of street driving; I step on the throttle a lot more with a quieter car, even for casual acceleration.
Also, on a side note, drone/resonance is a build of of sound energy, which is NOT escaping out the rear tailpipe, and can indeed actually cause a power loss, even though the exhaust setup looks to be freer flowing. Ideally, you want smooth flow, not turbulant flow. Two-stroke engine take advantage of this resonance to actually scavenge more exhaust out of the engine, and the same basic theory is how the Ace header works.
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
AceHeader-MT (11-25-2015), lamawithonel (11-29-2015), twag4 (11-24-2015)
Old 11-24-2015, 01:46 PM   #566
churchx
churchx's Avatar
Drives: 2014 GT86
Mike: i've seen that psychologically working other way - with some catback or other bolton owner liking sound/extra noise more, hence spending more in lower gears/higher rpms/more flooring accelerator "just to listen that sound" & braking instead of steady economical cruising. Of course it's not backed by logging but by my speculation/guess on reasons, as to why some seen MPG drop after bolt-on upgrade & tune when those should actually be more efficient and rather rise it .
Old 11-24-2015, 02:15 PM   #567
CSG Mike
CSG Mike's Avatar
You don't have to deal with socal cops
Old 11-27-2015, 08:02 PM   #568
07jazzrs5gt86
Drives: Firestorm 86
Just recently installed the type a 250 op and gotta say its fantastic.
I'm surprised is didn't get louder compared to my previous JDL el prototype. It sound very close to stock header until I punch it hard. Not I'm considering getting the ace FP to complete the exhaust but not sure how much louder would it get.
Any ideas how much louder will it get with the ace fp?
My current setup is ace type a 250 op and usdm TRD catback
07jazzrs5gt86 is offline   Reply With Quote
Old 11-29-2015, 12:47 PM   #569
PA-86
PA-86's Avatar
Drives: Scion FR-S Ultramarine, Triumph STR
Just ordered the Type B 250, can't wait to install!
PA-86 is offline   Reply With Quote
The Following 2 Users Say Thank You to PA-86 For This Useful Post:
AceHeader-MT (11-30-2015), DocWalt (12-16-2015)
Old 11-29-2015, 03:16 PM   #570
CSG Mike
CSG Mike's Avatar
Stock FP to Ace FP will result in a really, REALLY loud car; your stock front pipe is what is keeping you quiet.
07jazzrs5gt86 (11-30-2015)
Old 12-03-2015, 08:14 PM   #571
twag4
Drives: frs
*UPDATE*
So I sold my Corsa catback to another forum member. I got a stupid good deal on Black Friday on an invidia q300 cat back. I was able to buy it with the proceeds from the sell of the Corsa and two other items I sold in the classified section. It sounds amazing, and coupled with my JDL ultra quiet front pipe, the ace typeA with 350 over pipe is quiet and fierce sounding. It sounds sooooooo good now. I am highly impressed with this exhaust system now. It doesn't have the hiss of a more restricted exhaust, the buzz of the stock catback, or the insane loudness of my Corsa catback. The q300 has a very deep rumble below 2000 rpm, and shrieks quietly above 5000 rpm. Sounds really really good. Kinda like the 350z exhaust note maybe. My wife loves it and that is very important to me. I love it too and that is also important to me. I am still anxiously awaiting the ace quiet catback, really liking the looks of it so far. For now though, I am in love with this header. It really is beautiful to see it when looking down in the engine bay in front of and to the rear passenger side of the engine. It really has woken up the midrange when coupled with the Jackson racing sc.
The Following 10 Users Say Thank You to twag4 For This Useful Post:
AceHeader-MT (12-05-2015), Clipdat (12-03-2015), CounterSpace Garage (12-03-2015), Doozer (12-04-2015), Frogamazog (12-18-2015), jasonc (12-06-2015), Kotu100 (12-06-2015), ohmai18 (12-03-2015), ThatAsianBradah (10-31-2017), TofuJoe (06-05-2016)
Old 12-03-2015, 10:02 PM   #572
ohmai18
ohmai18's Avatar
Drives: Subaru BRZ
Is there any sound clip of the header paired with a Perrin catback and catted FP?
ohmai18 is offline   Reply With Quote
Old 12-15-2015, 11:08 PM   #573
twag4
Drives: frs
Just wanted to show you how good these look after a month and a half of use. Very pretty still...
The Following 8 Users Say Thank You to twag4 For This Useful Post:
2015firestormFRS (11-08-2017), AceHeader-MT (12-16-2015), CSG Mike (12-16-2015), Doozer (12-16-2015), Hawk77FT (12-16-2015), jasonc (12-16-2015), ohmai18 (12-15-2015), PA-86 (01-10-2016)
Old 12-16-2015, 08:18 AM   #574
bfrank1972
Drives: 2013 FR-S Argento
Try driving a winter up north
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? alanhung85 CANADA 6 10-21-2014 10:41 PM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 05:42 PM
Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! TopGearSolutions Engine, Exhaust, Bolt-Ons 82 04-14-2014 08:16 PM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 04:12 PM
Wanted: UEL header with Perrin header back and tune. skye67 Engine, Exhaust, Transmission 7 12-21-2013 10:34 PM
