Old 11-20-2015, 01:26 AM   #29
dj2020
Originally Posted by dj2020 View Post
@xxscaxx Thanks for this DIY. It made the fuel pump install fairly straightforward.
I do have a few questions about my install and if I did everything correctly. I ended up installing the Denso 260lph from Chris over at Speed by Design and purchasing a DW adapter kit from Summit Racing. The wiring harness worked perfectly and I used the OEM white collar with 2 o-rings. Everything seemed to be plug in play except for the fuel sock. The DW adapter kit from Summit Racing came with a short yellow sock that had a rigid plastic backbone inside of it that prevented me from bending/fitting it into the fuel canister assembly. However it did allow for the metal barbed ring and rubber black end cap to be used to secure the sock to the end of the fuel pump as per this DIY. On the other hand, the longer, white sock that came with the actual Denso fuel pump allowed me to fit the fuel pump assembly back into the canister assembly because the sock was much more flexible. But this longer, white Denso sock did not allow me to secure it to the new Denso fuel pump with the barbed metal ring and black rubber end cap. It is simply pressure fitted into the hole at the end of the fuel pump. It seems secure because I had to push fairly hard to get it pressure fitted but I'm concerned that it will eventually work itself loose. Also, since we've removed the clipping mechanism that held the OE fuel pump to the fuel pump assembly, how does our aftermarket pumps stay secured in the fuel pump assembly? I just sent Chris an email to ask him his thoughts but I thought I'd pick your collective brains as well. How did everyone else do theirs?
Bump to @Sportsguy83, @spdbydesign or anyone else who can confirm my install above. I'm the most concerned how the aftermarket fuel pump stays inside the fuel pump assembly since the clips/stock sock combo has been removed. Does the longer aftermarket pump push up against the fuel canister basket bottom which prevents it from slipping out? As you guys can tell, I'm trying not to take out the entire basket again and reek like gasoline again.
dj2020 is offline   Reply With Quote
Old 11-20-2015, 07:28 AM   #30
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
The FP is held inside the canister and in place by the pressure of the pump pushing down and the canister pushing up to stay clipped with the canister top part.
You should be fine with your installation.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
dj2020 (11-20-2015)
Old 11-20-2015, 07:45 AM   #31
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
Originally Posted by weederr33 View Post
I have not, but I was considering upgrading it eventually.
I have the same plans and currently run an E85 tune on track days. It makes sense to me to install the new fuel pump first and keep any issues you may have isolated from other modifications. At least 2 of the higher boost supercharger kits require a higher flow pump and injectors even for pump gas.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
Old 11-20-2015, 08:34 AM   #32
nickmerronesucks
Ned flanders
nickmerronesucks's Avatar
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
Would I need a retune if upgrading my pump?
797Performance.com
nickmerronesucks is offline   Reply With Quote
Old 11-20-2015, 10:23 AM   #33
dj2020
DIY: Deastchwerks 265c Fuel Pump Install
And what do you think of me pressure fitting the above longer white stock that came with the aftermarket Denso pump? Is that secure enough? This sock does not allow for the metal barb locking ring or black rubber end cap to be used like in the OP's DIY. I believe the OP is using a DW pump. Also, in FA20Club's fuel pump install YouTube video, he only uses the metal barb ring but no rubber end cap. I don't know which fuel pump he's using but the fitment seems questionable after the video because maybe the pump is even longer than the DW and speedbydesign Denso pumps.
Old 11-20-2015, 11:02 AM   #34
Sportsguy83
Drives: Limited BRZ
No, as long as you only upgrade the pump, not the regulator.
As long as the pump does not move, which would allow fuel pressure to escape by the O-rings and would get you a lean condition, you will have no problems. The pump moving out of place or staying in place has to do with only one thing, the amount of force put into keeping it in place by the canister "tightness" itself.
dj2020 (11-20-2015)
Old 05-28-2016, 01:39 AM   #35
brianhj
Drives: 2017 Camaro 1SS
Ok so I got the 65c and installed it tonight and used OPs instructions not realizing the pump is different now. I ended up hammering on the white collar with a socket. I got it on there but holy shit now I'm scared I fucked something up or something will fuck up in the long run because it was a really tight fit. It seems to be running fine.
Sent from my LG-D851 using Tapatalk
brianhj is offline   Reply With Quote
Old 01-24-2018, 07:23 AM   #36
sam69
Drives: GT 86
Great write up found it to have lots of good tips as thinking I might have a go at putting in my 260 L pump
sam69 is offline   Reply With Quote
Fuel pump upgrade install (Visconti 290lph) jet86 DIY (Do-It-Yourself) Guides 44 01-04-2018 07:56 PM
PSA: Tips on what needs to be payed close attention on Fuel Pump install Sportsguy83 Engine, Exhaust, Transmission 34 04-25-2014 11:24 PM
Fuel pump issue. sevi21 Issues | Warranty | Recalls / TSB 13 02-01-2013 09:57 AM
Car fuel pump on... Genomaxter Engine, Exhaust, Transmission 5 11-29-2012 10:06 AM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 04:53 PM
