Old 11-19-2015, 12:09 PM   #1
shantha
Drives: TOYOTA 86 GT LTD
Question Auto gear slippage on 2nd n 3rd gear
Hello every one I join only yesterday I have this problem in my Toyota Gt 86 LTD my car is a 6 forward auto I brought the vehicle from Japan from Jpn auction which was graded as auction grade 5AA manufactured in August 2012 brought to Srilanka in September 2014 with a mileage of 7500 km done and being running randomly in week ends with no issues at all as I left for overseas for about 3 months car was at my garage on my return the battery was all out and charged the battery n went for a ride after almost 3 moths n noticed that when the gear changes to 2nd gear engine rpm goes up and not speeding at all and when I deacclerate to about 1000rpm gear engages I think same problem when it shift 3rd gear afterwords it shift smoothly to 4th, 5th,6th there are no issues in gearbox according to dealer and so many experts and scanner did not find any fault either. Replaced the valve body as well and all shift solenoids even though scanner did not reveal any defect with them changed oil as well even though auto oil in it looked as good as new I can't understand this problem all clutch plates are ok according dealer is this problem occurs due to some problem with the gear box control unit which I have ordered from Japan programmed to be done with Toyota over here please if any one had this problem or any kind of idea feedback will be a big help for me thanks
shantha is offline   Reply With Quote
Old 11-19-2015, 05:12 PM   #2
stevesnj
stevesnj's Avatar
Could be a bad torque convertor
My 2016 Build thread
Old 11-19-2015, 07:26 PM   #3
shantha
Thank u StevesnJ i will check it up with the mechanic but he has striped the full gear box and found nothing wrong with clutch plates, replaced valve body, replaced all shift solenoids any way i will ask him about the torque converter
The Following User Says Thank You to shantha For This Useful Post:
stevesnj (11-19-2015)
Gear slippage from 3-4 zypher10 Engine, Exhaust, Transmission 0 10-18-2015 08:42 PM
is it possible to rejigger the auto manual mode shifter to flip gear up/down? chickdigger802 BRZ First-Gen (2012+) — General Topics 14 10-18-2013 08:17 PM
Top Gear Crashes Helicopter During Filming of "Top Gear Korea" Episode SteveH Other Vehicles & General Automotive Discussions 7 02-13-2013 12:08 AM
No more 1st gear thump or 2nd gear notchiness kc4mne Scion FR-S / Toyota 86 GT86 General Forum 28 09-06-2012 08:39 PM
Reverse gear on the first and second gear side randytindoggy Scion FR-S / Toyota 86 GT86 General Forum 50 01-29-2012 01:21 PM
