| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#2297 |
Drives: 86 GTS
Then XXR 530 ook very Similar to the Works Emotion CR Kiwami. Which one are lighter in the 18"?
#2298 |
Drives: scion fr-s
someone rolls xxr 536?
#2300 |
Drives: Diamond White Scion FR-S
what body kit is that???
#2301 |
Drives: 86 GTS
#2302 |
Bang Bang
Drives: 2013 Raven FR-S
18x8.75 +35
235/40
Raven 6MT//Injen CAI//VDS UEL//Invidia N1//OFT//ST Coilovers |
| The Following 6 Users Say Thank You to trigger happy For This Useful Post: | BeRZed (11-26-2015), eurominican (04-17-2016), Here2rock (11-19-2015), oldlostcory (11-25-2015), Teseo (12-20-2015), ZOMFGAARON (11-19-2015) |
#2303 |
Drives: 86 GTS
| The Following 2 Users Say Thank You to Here2rock For This Useful Post: | Teseo (12-20-2015), trigger happy (11-20-2015) |
#2304 |
Drives: 2016 frs
So I just got xxr 527 17×8.25 +35 all the way around and I went to get a price for tires and they said no tire fits. What tires are you guys with this setup running, and do you have any problems rubbing? I'm still on stock suspension
#2305 |
Drives: 2015 Firestorm Scion FRS
I got mine a week ago with the exact size but haven't installed it. Planning to put the stock tires on it and the setup works since a few other members had the same set up. I rather not buy new tires yet since I still have lots of tread left on the primacys. I think any tire width from 215 to 235 should be fine.
#2306 | |
Drives: 2016 frs
#2307 |
Drives: 2016 frs
Srry for the newb questions but I went and talked to another tire place he said a 225 45 will work. I plan on lowering at some point. will I have a problem if I lower with that tire size?
#2308 |
SCBYD0
Drives: 18 BRZ (WRB)
Yea 225/45 will work, that's probably the minimum I would recommend. You shouldn't see any problems when lowering though.
#2309 |
Drives: 2016 frs
#2310 |
Drives: '08 MX5 6MT & '15 BRZ Premium 6MT
Skimmed through a lot of the pages of this thread but I couldn't quite find a definitive answer to a question I have.
I have a set of RCE Yellows (.8" drop) and am seriously considering getting a set of XXR 527 in 17x8.25 +35. I am looking at going with Michelin Pilot Super Sports in 235/45/17's or 245/40/17's. I am aware about the tire spec's and what not. Specs say, I should go with the 245/40/17's. If I go with those tires, should I go with the XXR 527's in 17x8.75 +35 instead? Would the 17x8.25 +35 be just fine? I have a set of SPC Camber Bolts and SPC Adjustable Rear LCA's that needs to be installed as well. I'm going for the alignment specs close to -2.0 Front and -1.5 Rear. Supposedly, using the SPC Camber Bolt on the bottom, and using the 14mm OEM bolt from the bottom and switching it with the top 16mm bolt will give me more camber than the -1.2 to -1.5 camber that the SPC Camber Bolt originally allows for when the instructions are followed....that is, replacing the bottom bolt with the SPC Camber Bolt and leaving the 16mm bolt up top. About me and my car's purpose: The car is a daily driver and when there's no traffic, I take corners on the more aggressive side. I also go on cruises where people go 8/10-9/10's. Also, I'm waiting on a supercharger which is one of the reasons I would like to get wider wheels/tires for the car. I live in California. I don't have to worry about snow as much and if it gets too cold, I don't have a problem taking my NC MX5 (I have Michelin Pilot AS3's on it). Thoughts? Thanks in advance =^_^= Last edited by SHWNBRZ; 11-25-2015 at 02:23 PM. |
| Tags |
| 17 wheels |
| Wheel Directory: ProDrive GC-012L 18x8.5 +48 | MarkMash | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 20 | 05-12-2013 03:55 PM |
| Is there a thread for 'people doing stupid things in their brand new car' thread? | Symbiont | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 36 | 02-18-2013 12:24 PM |
| Official wheel/tire fitment thread needed | empower-auto | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 06-22-2012 01:40 AM |
| The Wheel and Tire Fitting Thread | EvoFanatic | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 03-15-2012 03:05 PM |
| Are there any RWYB Wheel to Wheel road races? | LexusFman | Other Vehicles & General Automotive Discussions | 1 | 11-05-2011 12:28 PM |
