Old 10-24-2015, 03:10 PM   #29
phobos512
phobos512's Avatar
Drives: 2014 FR-S 6MT Whiteout
Originally Posted by JohnnyP View Post
I tend to keep a somewhat low profile most of the time, and it doesn't hurt that I live less than two miles from work so I'm usually riding my bike.
I think we Californians tend to make things sound worse then they are too. But I'm holding onto the stock exhaust just incase.
I spent 28 of 35 years as a Californian including modding cars so just because I now live someplace that has no emissions testing doesn't mean I don't know what it's like to live under their oft draconian rules
Matt | '14 FR-S 6MT Whiteout | '13 Sonata Hybrid | '11 CBR1000RR
phobos512 is offline   Reply With Quote
Old 10-25-2015, 03:54 AM   #30
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Originally Posted by sales@delicioustuning.com View Post
This tune is technically a Flash & Go, but with a few crucial differences that make it specially suited to perform at its best with this kit. A basic Flash & Go would make a bit less power on bottom and top than this would.
This tune is available now, and will be exactly what is sent out whenever someone orders a Flash & Go for an Edelbrock kit through our site.
Thanks again Zach. Another potentially dumb question: If you do upgrade the injectors to a larger size and install flexfuel, come time for smog inspection, would I have to uninstall/revert back to stock in order to flash back to CARB tune? Basically, will the CARB tune be able to recognize that the flex fuel and injectors are there and behave accordingly?
Old 10-25-2015, 06:05 AM   #31
Kodename47
Kodename47's Avatar
Drives: UK GT86
No, the injector scaling would be all off and the FlexFuel would probably throw a CEL.
.: Stealth 86 :.
Kodename 47 DJ:
Old 10-26-2015, 12:57 PM   #32
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Injector scaling will be way off, and flex fuel would mess things up a bit as well, most likely popping a rear o2 cel. You would need to take out injectors, plug back in rear o2 sensor to factory location, and then flash the CARB tune. Alternatively, if they're not doing a visual inspection, just run it and it'll most likely pass the sniffer.
Sincerely,
Zach
Old 11-14-2015, 07:53 PM   #33
DeliciousTuning
Thought some of you might be interested in our latest development on the Edelbrock eForce supercharger. We have started some pulley test and tunes and so far the 3.00in (15 PSI) pulley works great on 91 octane. Though you will be at the limit on stock injectors. More to come...
Cheers,
William Knose
Old 11-14-2015, 08:30 PM   #34
BigFatFlip
BigFatFlip's Avatar
My body is ready
Old 11-14-2015, 10:12 PM   #35
jmimac351
Chin Chief Instructor
jmimac351's Avatar
Drives: 2015 Ford F150 Aluminium Couch
The design of this blower setup is really slick. Very impressed with what Edelbrock did here. I've owned Terminator Mustangs in the past, with the air to water intercooler setup below the blower. This flips that upside down. The "Instant On" boost of a roots blower is memorable.
Is there any data about pre and post intercooler inlet air temps? The question is, how reliable might this setup be on a high compression BRZ motor in the summer in Florida at Sebring?
2015 Subaru BRZ
2008 NC Miata with 2.5 swap
Building 1963 289 Cobra Le Mans Replica
Cobra Replica Build Pics
Chin Chief Instructor www.ChinTrackDays.com
jmimac351 is offline   Reply With Quote
Old 11-15-2015, 01:05 AM   #36
DeliciousTuning
Post blower temps are ranging around 120F degrees at WOT, after a 4th gear dyno pull in about 80F degree Southern California weather. No reason the 15 PSI pulley was still making power.
Old 11-15-2015, 01:18 AM   #37
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
I'm curious if you guys have done any comparisons between the Edelbrock and the Cosworth. I'd like to know how they stack up.
MS, CSCS, TSAC-F, CPT
Old 11-16-2015, 05:40 PM   #38
DeliciousTuning
We have some exciting news for everyone regarding the Edelbrock kits! Last week we were able to get our tune for this kit dialed in even further, as well as test Edelbrock's upcoming 3"/15psi pulley! I'll let the dyno charts speak for themselves here.
All of these tests were done on 91 octane. With the 3" pulley, you will need larger injectors to support the flow! On 93 octane, you should be able to extract a bit more power out of the system, but not quite 300whp. We are eagerly looking forward to getting more time with the car and extract even more power with E85. Stay tuned!
Sincerely,
Zach
Old 11-18-2015, 02:52 AM   #39
JB86'd
JB86'd's Avatar
Drives: JAWS
Anybody need a kidney? Left nut?
JB86'd is offline   Reply With Quote
Old 11-18-2015, 09:38 AM   #40
wparsons
wparsons's Avatar
We have kits ready to go when yuo're ready
Any chance you've done any testing with this combined with the ace 4-2-1 header?
flickr
Old 11-18-2015, 10:31 AM   #41
NotSoJDM
NotSoJDM's Avatar
Drives: '13 BRZ | '04 E55
What kind of comparisons would you like to see? I have the Edelbrock on my car and I installed a Cosworth setup on another local car. It would be easy for me to get some back to back logs of the two cars if you're just looking for IAT data, etc...I don't have dyno info, but that can be arranged I'm sure with a little convincing
NotSoJDM is offline   Reply With Quote
Old 11-18-2015, 10:34 AM   #42
NotSoJDM
NotSoJDM's Avatar
I'm curious about this as well. I am running the ACE 4-2-1 with my Edelbrock setup and the Delicious FNG tune. It would be nice to see how well the ACE does in comparison to a traditional UEL on a FI setup.
It's really unfortunate that I don't have any of these guys like CSG, Moto-East Delicious, etc local to me. I have the car, the kit, and both UEL and EL headers. I just need someone that can tune them both so we can see how they pair up with this supercharger.....
FS: Delicious Tuning Flex Fuel kit (SoCal) J.C. Engine, Exhaust, Bolt-Ons 2 07-17-2015 09:27 PM
Delicious Tuning Flex Fuel Kit - Build exam2300 Software Tuning 16 06-16-2015 11:58 AM
Delicious Tuning Flex fuel kit themooseisloose Engine, Exhaust, Bolt-Ons 26 05-01-2015 12:46 PM
Delicious tuning flex fuel brz23 Great Lakes 2 03-06-2015 08:53 PM
Delicious tuning flex fuel brz23 Software Tuning 4 03-05-2015 01:28 PM
