Old 11-17-2015, 02:17 PM   #1
ChrisP
ECU update to fix idle problems?
I bought my frs about a month ago and have been experiencing the idle fluctuation probalems like a lot of other members. I thought i read in earlier posts that there was an ecu update to fix the problem, but when i droped by my local toyota dealer in kirkland washington they said that there wasn't an update to fix it yet, but they were working on it. Is there or isn't there an update to fix the problem?
ChrisP is offline   Reply With Quote
Old 11-17-2015, 02:30 PM   #2
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
Does it happen with A/C off? If so, then it might be this.
Check the VIN to see if yours fall into this.
The Following User Says Thank You to Sigh-on-Rice For This Useful Post:
ChrisP (11-17-2015)
Old 11-18-2015, 02:54 PM   #3
B T
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
my 2015 suffers from idling issues with A/C on, almost stalls when unit kicks on.
B T is offline   Reply With Quote
The Following User Says Thank You to B T For This Useful Post:
ChrisP (11-19-2015)
idle problems and afr swing Frs300 Issues | Warranty | Recalls / TSB 4 01-29-2016 12:14 AM
Idle dip but going FI mscamp02 Forced Induction 16 11-09-2015 03:16 PM
idle problems and afr swing Frs300 Engine, Exhaust, Transmission 2 08-16-2015 12:03 PM
Transmission problems, oil leaks and detonation problems.. turboviper Issues | Warranty | Recalls / TSB 4 06-18-2014 04:01 PM
I know its been covered but 10 series idle problems :( Aceler8 Issues | Warranty | Recalls / TSB 17 09-11-2013 12:08 PM
