#253 |
Drives: Exige S 240
A thousand times this.
| The Following User Says Thank You to Guillaume For This Useful Post: | Ultramaroon (11-17-2015) |
#254 |
Drives: 15 FR-S Firestorm MT
@Ultramaroon wish you would just come over and do this for me. I'm too chicken to mess it up.
I've lowered the clutch pedal and pulled the spring, but still lacking the feel that I'm looking for. Feels like an on off switch which makes it tough to be consistently smooth.
Diode Dynamics Tail as Turn, LEDs, HIDs | Yospeed Custom Plaque and Frame | Suntek Carbon Tint | Spyder Smoked Side Markers | GrimmSpeed License Plate Relocator and Hood Struts | Five:AD Spoiler | JDM Armrest | Beat-Sonic Backup Cam | Moddiction Anvil 2 | Invidia N2 |
#255 |
The Fail Boat
Drives: CWP S.B.
DIY - Swap clutch slave cylinder and hydraulic line for improved feel and con...
^ can't agree more, this looks really promising but I'm just a chicken... Haha I got use to only pushing like 30% of the total clutch travel... Don't know why they design it like this... I guess it's good that I don't really have to extend my leg like at all?? >_>
| The Following User Says Thank You to chaoskaze For This Useful Post: | Ultramaroon (11-17-2015) |
#256 | |
The worst issue would be to run your reservoir dry but you would literally have to leave the hydraulic line hanging down while you go and take a coffee break. It oozes out that slowly. Have you read the remove-your-spring thread lately? I was called out so I made one last speech and called it good. Don't want to alienate anybody.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | Joyride86 (11-17-2015) |
#257 | |
I do mostly city driving with the FR-S so clutch feel is important to me. Just today I over revved because I thought I hit the engagement point. Guess not lol. Other times I don't have any issue. I just want to be smooth consistently and your solution makes sense. Others guys that have done this confirmed it also. I'll give it a shot when spring comes around.
#258 | |
The root of the problem is that damn novocaine clutch.
| The Following 3 Users Say Thank You to Ultramaroon For This Useful Post: |
#259 | |
Drives: Whiteout FR-S
Will keep testing, cold weather already making it hard to shift so hard to tell if due to clutch adjustment or just weather.
2013 Ford Focus St
2013 Scion FR-S 2007 Honda Civic Si 2003 Acura RSX Type-S 1998 Ford Escort ZX2 |
#260 | |
All bets are off when the trans is cold. Still, it's a good opportunity to work on rhythm. When upshifting, get through neutral as quickly as possible (no pause) and immediately apply gentle pressure to the target synchro. If you're quick enough, it will sink into gear like butter. If you miss the opportunity, double-clutch and try again. You'll soon realize force is never required.
#261 | |
Was checking this out today and noticed that at full rest it appears to be touching those clips which is a good sign. Curious, when you touch the pedal with your fingers does this move at all for you? Or is there some free play before this cylinder starts to move?
2013 Ford Focus St
#262 |
Sorry not clear on what "this" is but I'll do my best. We'll get there after some back and forth.
![]() First thing we need to establish is whether or not you still have the assist spring installed. I only reviewed this page and I don't see it mentioned. If it is still installed and your cruise switch allows it, there will be some slop before push-rod begins to move. Is this the case? Let's discuss. Also regarding the clunk and notchiness, I'm concerned that the throwout bearing might be hanging up on the snout. I've felt this on @Chen's car and made the connection after delving into this thread. edit: aaand I just realized you've posted to the same thread.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | Tt3Sheppard (11-22-2015) |
#263 | |
This actually might answer my question. http://www.ft86club.com/forums/showp...&postcount=640 In regards to the TOB I believe mine is on it's last legs. When the car is off I push the clutch pedal in 100% and move it between 90-100% I can hear and feel a crunch/squeak. Weather has been in the 35-40F range so maybe related. I've posted in a few other threads as well seems small group of people with similar issues.
2013 Ford Focus St
| The Following User Says Thank You to Tt3Sheppard For This Useful Post: | Ultramaroon (11-22-2015) |
#264 |
In this context, the slop you feel is not actually slop. With the master plunger fully retracted, they hydraulic system is open to the reservoir. You can prove this to yourself by pulling the end of the clutch fork forward to depress the slave plunger. Where does the excess fluid go? Back into the reservoir. The master plunger closes that port/valve in the very first bit of travel as it is depressed.
This is the key to self-adjustment. As the clutch wears, the pressure plate gradually moves closer to the flywheel. The clutch fingers move in the opposite direction, lifting the TOB away from the flywheel, which results in a tiny bit of that motion you just verified by compressing the plunger. If the master plunger is not allowed to fully retract, the system can't adjust itself because the hydraulic fluid has nowhere to go. Force on the TOB is never relieved and, in the worst case, the clutch itself eventually begins to slip.
| The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | jcw99 (11-22-2015), Tt3Sheppard (11-22-2015) |
#265 |
Drives: swp mt '14 brz premium
I was just reviewing that stuff in one of my textbooks about the role of the check valve in the clutch master cylinder and your explanation is better than the book's. I've been looking for my binder with my notes from manual transmission and driveline class for the last week and still haven't run across it.
| The Following User Says Thank You to jcw99 For This Useful Post: | Ultramaroon (11-22-2015) |
#266 |
Very informative. I did notice fluid going into the reservoir when I pulled the clutch fork forward.
2013 Ford Focus St
| Tags |
| clutch line, slave cylinder |
| Clutch Engagement Improved! | enjoyminutemaid | Engine, Exhaust, Transmission | 53 | 11-07-2018 06:31 PM |
| Can steering feel, tactility, be improved? Without sacrificing adjustability? | Trettiosjuan | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 101 | 08-16-2016 08:14 PM |
| Aftermarket Clutch Master and Slave? | Yruyur | Engine, Exhaust, Transmission | 5 | 07-27-2013 10:22 AM |
| Hate the feel of the clutch | FRSGeek | Engine, Exhaust, Transmission | 18 | 07-10-2013 01:24 PM |
| Clutch feel? | Shit Luck | Engine, Exhaust, Transmission | 5 | 04-21-2013 05:32 PM |
