Old 11-15-2015, 03:37 AM   #1
Roto88
Drives: White BRZ Limited
Unhappy Vehicle shipped to Germany now Radio/usb dont work.
I recently moved to Germany. I shipped my vehicle from Dallas and it took about a month a half to arrive here. Along the way the battery lost charge and it had to be jumped once, maybe more. The problem is that now the radio or the USB charge port don't work. I checked the fuse under the dash labeled radio, plus some other ones and they all seem fine.
I checked the wiring diagram for the car and I think these two parts share a relay but I'm not 100% or where to find said relay. I'm not very good with electronics or schematics so I was wondering if some of the more experienced members here can point me in the right direction.
Any input welcome!
Roto88 is offline   Reply With Quote
Old 11-15-2015, 05:39 AM   #2
P3tras
Drives: Subaru BRZ '13 WRB
That is very odd... AUX wire has some extra harness, but USB from dash connects directly to radio - no fuses, relays and etc (unless they are inside the head-unit).
P3tras is offline   Reply With Quote
Old 11-15-2015, 07:56 AM   #3
Guru Woodman
Guru Woodman's Avatar
Drives: 2015 BRZ Sport Tech CWP
On a side note, you frequency in your radio will be off too. In Europe they use even number frequencies like FM 106, NA has uneven, like FM 107. So you might want to swap your head unit anyway if you are planning on using that BRZ for a longer period of time. I think there are units that do all frequency ranges so you can keep it if you even decide to ship it back again.
Was shipping expensive? I have been thinking of doing an extended Europe Road trip and shipping instead of renting a car.
Guru Woodman is offline   Reply With Quote
Old 11-15-2015, 11:48 AM   #4
Roto88
I didn't pay it was free because im in the military.
It might be and internal relay or fuse because I havent been able to find any other problem. I will have to put in a claim with the legal office even though since the shipping company wont cove it even though the head unit worked fine when I dropped it off.
Old 11-15-2015, 11:55 AM   #5
White64Goat
or if you move to Australia, you have to turn the head unit upside down.........
Old 11-16-2015, 07:52 AM   #6
P3tras
Pretty sure that stock headunit covers all frequency ranges. My BRZ was shipped from US to EU and stock head-unit played radio without any issues. But I changed it anyway
Old 11-16-2015, 09:08 AM   #7
Roto88
Took it to a local shop, all he did was check the fuses I had already checked and came to the same conclusion I did but didnt want to go any further because its a Subaru and he doesnt have the wiring diagrams for it.
So now I have to take it to a Subaru or Toyota dealer. I want to take it apart myself to see if there is power going to the unit but I need a repair estimate so i can file a claim to get my money back.
Old 11-16-2015, 04:52 PM   #8
ravisraval
Drives: 2013 FRS
Curious - how much did shipping cost?
ravisraval is offline   Reply With Quote
Old 11-16-2015, 04:57 PM   #9
Old 11-16-2015, 05:05 PM   #10
As silly as this sounds, disconnect the battery for about a minute then hook it back up. It is possible that the drain and then the boost scrambled the radio enough it didn't power up but a straight up disconnect and reconnect may just do it. Long shot but worth a try.
Old 11-16-2015, 05:23 PM   #11
86Tony
Drives: 2015 AOZORA EDITION
Def worth a try
86Tony is offline   Reply With Quote
Old 11-16-2015, 07:07 PM   #12
SteveGrillo
Drives: Brz
Good idea folks. This wouldn't surprise me at all.
Steve
SteveGrillo is offline   Reply With Quote
Old 11-17-2015, 04:14 AM   #13
P3tras
The boat was ~$1000 USD. But it was shipped in container with ~4 other cars and there was some damage from shipping. Side bellow doors was bent, I think they didn't lower forklift enough when trying to lift the car.
But for cars that are running fine, there is "roll on/off" shipping method. Basically your car is driven inside the boat instead of being "packed" in container. I would assume that damage is much less likely using such shipping method and it is slightly cheaper as well.
Old 11-17-2015, 04:28 AM   #14
ravisraval
Drives: 2013 FRS
Wasn't directed at OP.
P3tras $1000 isn't too bad. I'm considering moving to Europe within the next few years, but I'm nervous about shipping damage.
radio, usb
2015 frs perfect pioneer radio $220 shipped BULLETFRS Audio/Visual, Electronics, Infotainment, NAV 4 04-30-2015 08:29 AM
Installed side markers now brake/turning/sidemarkets lights dont work! HELP! Danny Issues | Warranty | Recalls / TSB 10 11-28-2013 11:33 PM
door speakers dont work subaruferrucci Issues | Warranty | Recalls / TSB 8 08-04-2013 09:51 AM
Trade bespoke and 425 shipped for stock frs radio. Hops Normal Audio/Visual, Electronics, Infotainment, NAV 2 05-29-2013 11:31 PM
would this work for sat radio? lbroskee Electronics | Audio | NAV | Infotainment 2 01-13-2013 12:21 AM
