Old 11-09-2015, 04:59 PM   #15
orangespark
Drives: White Frs AT
Oh I meant, the reason why I never got a manual was down shifting during corners. I've driven manuals in the past for over 2 years, but most of the driving was accelerating and stopping at the red lights. This was my proper first car and I didn't want to kill the clutch on this trying to improve my skills for downshifting. I should have started with a civic or something and moved up.
orangespark is offline   Reply With Quote
Old 11-09-2015, 05:23 PM   #16
ottoyu34
ottoyu34's Avatar
Drives: Mazda3
Personally I take a different approach, I work with what I have and improve on my driving first. I am pretty sure the manual mode is a better than just leaving it in "D". If you are interested in having fun in corners than just straight line acceleration. There are plenty of performance driving events thru out the summer around Toronto, Ontario. Upgrade on driving mod, then dump the money on what you think is suitable. This platform is build for fun driving. If you like straight line speed or drag, this is not the car.
ottoyu34 is offline   Reply With Quote
The Following User Says Thank You to ottoyu34 For This Useful Post:
orangespark (11-09-2015)
Old 11-10-2015, 12:31 AM   #17
xuimod
Drives: 2007 MX-5 Miata, 2015 VW Golf GTI
280-300 whp or at crank?
If whp (which would be about 300-320hp at crank), it should be 5.3-5.5 sec's.
xuimod is offline   Reply With Quote
The Following User Says Thank You to xuimod For This Useful Post:
hmong337 (11-14-2015)
Old 11-10-2015, 01:20 AM   #18
mythhelios1
Drives: Scion FRS
A member running Phantom ESC with AT make ~225whp/220wtq already run 5.9s, so I think 300whp should run 5s easily
mythhelios1 is offline   Reply With Quote
Old 11-14-2015, 04:41 AM   #19
Cal3000
Drives: Panda FR-S
With a good set of tires, 300whp range will run in the 4s
[ame="https://www.youtube.com/watch?v=TkNsgI_7qpY"]300 whp brz 0-60 in 4.5 - YouTube[/ame]
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
242whp/197ft-lb on Mustang Dyno (91 octane water)
284whp/223ft-lb on Mustang Dyno (E85)
Cal3000 is offline   Reply With Quote
Old 11-14-2015, 07:32 AM   #20
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Yep good tires, tune and a 3.73 rear end would be great. I don't understand why no one makes a 3.73 kit and Im always looking for a m85 LSD at the salvage yards.
After going FI I feel the cars gears are way to fast now and I'm shifting more than anythiny. The 3.73 would give it longer gears and 2 gear should hit 60 without a problem. Currently, we gotta jump into 3rd to hit 60 and that kills our 0-60 time. Ya sure the rearend that ships with the car is good for stock but FI it's alot of work...
I would like to thank NO ONE for making a 3.73 swap
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
The Following User Says Thank You to GsxrMe For This Useful Post:
Summerwolf (11-17-2015)
Old 11-14-2015, 11:02 AM   #21
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
Buy the m85 or the parts from Toyota/Lexus. It's the same parts as the other Frs final drive "kits".
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
Old 11-14-2015, 01:54 PM   #22
GsxrMe
GsxrMe's Avatar
Is there a m85 rebuild kit I can buy to just convert my housing? I would love a url link.
2014 Subaru BRZ
Old 11-14-2015, 02:17 PM   #23
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Should be able to hit 12's and run mid to low 13's all day in the 1/4 with a good set of street tires. 0-60 is meaningless...
hmong337 is offline   Reply With Quote
The Following 2 Users Say Thank You to hmong337 For This Useful Post:
Dream20b (11-17-2015), wparsons (11-15-2015)
Old 11-14-2015, 05:56 PM   #24
spitfire481
Drives: 2JZ FRS
You have to get the parts from Toyota, plus the shims to get the lash correct
MoTeC
Build Thread
@spitfire481
Old 11-14-2015, 11:27 PM   #25
KR-S
Sporadic Member
KR-S's Avatar
Drives: 2016 Halo FR-S M/T
Originally Posted by orangespark View Post
0-60 to pull from mid-range beamers and cheap mustangs on the red light.
And taking selfies and adding hashtags for those Instagram followers while doing so.
The Following 2 Users Say Thank You to KR-S For This Useful Post:
orangespark (11-16-2015), wparsons (11-15-2015)
Old 11-15-2015, 08:55 AM   #26
GsxrMe
GsxrMe's Avatar
Is this the correct parts list for the M85 internal swap? It looks like its the same price to buy if used and beaten from ebay as it is to buy the parts new from the dealer. The image is below. I rebuilt a rear end for a friends 1990 Monte Carlo; so same concept I would think. Take you time, measure 50 times and a 6 pack of beer.
No wonder the damn M85 is hard to find. The tech is from 2005! Thank you Toyota and your old ass tech in my 2014 BRZ!
2014 Subaru BRZ
Old 11-15-2015, 01:37 PM   #27
KoolBRZ
KoolBRZ's Avatar
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
Get a 4.88 Final Drive
I wish I could. I do a lot of city driving and am distracted a lot of the time (eating, talking on the phone while driving). Can't afford two cars atm. Maybe down the road, I can try and push for a Wrx sti and just get better at multi-tasking with a manual.
and the linked 0-60 calculator is SIICK btw
Get a 4.88 Final Drive. This is the first step to getting a quicker AT. You'll be amazed at how much rubber you can leave on the road. Then invest in an OFT and switch to running E85. This gets you a bit closer to that 5 second mark. Then step up to a super-charged setup with a UEL header. A supercharger can provide better low-end torque than a turbo. On E85 super-charged, this should get you under 5 seconds with a decent UEL header and a 4.88 FD. All AT's should upgrade with a UEL instead of an EL header, since AT's need low-end torque more than MT's do. The UEL's short primary's provide better low-end torque, while the longer one's provide high-end power.
If I say yes, will that make you think I understand?
KoolBRZ is offline   Reply With Quote
The Following 2 Users Say Thank You to KoolBRZ For This Useful Post:
avishenoy1 (11-16-2015), orangespark (11-16-2015)
Old 11-16-2015, 12:36 PM   #28
orangespark
This is actually is really nice game plan. Thanks KoolBRZ and everyone else. I have an OFT already and was getting logs ready for Knock correction and MAF scaling.
I'll probably get the 4.88 Final Drive at the end of this winter and then hopefully once I'm more knowledgeable a super charger after my warranty is done.
fi times car
POST YOUR 1/4 MILE TIMES Quarter mile times NYCsubaruBRZ Tracking / Autocross / HPDE / Drifting 1 02-04-2014 06:59 AM
Boost Up Your Vehicle's Speed, Power, & Track Times at FR Sport! FRSport.com Forced Induction 0 01-24-2014 12:33 PM
***Blitz Advance Power Air Cleaner and SUS Power Core Intakes*** FT-86 SpeedFactory Engine, Exhaust, Transmission 1 10-07-2013 09:40 PM
[TRANSLATED] Joy Car! Japanese gravure idol Hitomi Yasueda examines the 86. sir_binkalot FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 38 06-15-2012 03:53 PM
General info on the 86 translated from Toyota Japan WTF Scion FR-S / Toyota 86 GT86 General Forum 14 02-24-2012 05:57 PM
