go_a_way1
Old 11-09-2015, 03:22 PM   #3053
Xuningshen
Drives: Subaru BRZ
Originally Posted by axelthrasher View Post
I cleaned my maf about 100 miles ago. Didn't throw another cel until this latest start/idle issue. I am very meticulous about everything that I do, so I know all connections were tight after maf clean.
Honestly, I switched from the JR carb tune to Delicious' Flash and go tune v16.xx.
I was having funky fuel trim/idle issues at low rpm with my radium pcv catch can attached. Another time I was out in the desert and I got that P0172 dirty maf code.
Been much happier with the performance after switching to speed density. Although low/partial throttle response isn't as fine as a MAF tune, its definitely acceptable for daily driving. Alot smoother than the carb tune when you're having those issues.
2014 WRB BRZ
Xuningshen is offline   Reply With Quote
The Following User Says Thank You to Xuningshen For This Useful Post:
Old 11-09-2015, 08:26 PM   #3054
axelthrasher
Drives: BRZ, 2 WRXs, 818S, motorcycles, etc
I'm honestly thinking of having it pro tuned... but I don't want to pay for a tune without headers, catless, fuel pump, injectors, and 12lb pulley. The only thing is I'm not sure if this is a tune issue, ecu issue, or something else...
axelthrasher is offline   Reply With Quote
Old 11-10-2015, 12:48 PM   #3055
Xiao Li
Xiao Li's Avatar
Drives: '14 BRZ, '01 S2K
Quick question for everyone, what color is the fluid in your reservoir? Out of the bottle it's like a nice translucent WRB, but in the can it's like a pastel Tiffany green for me. Just trying to see if that's normal.
Xiao Li is offline   Reply With Quote
Old 11-11-2015, 03:00 PM   #3056
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
The codes you're experiencing aren't a tune issue. The combination of a low circuit maf code plus an iat code are a direct and very clear result of something going bad in either:
A) Wiring between MAF and ECU
B) MAF itself is fried
If the issue is intermittent, this would point more towards a wiring issue. If the issue is permanent and the car is simply refusing to run with these codes, this would indicate a failed maf sensor. Keep in mind, sometimes it's not just a matter of making sure things are tight. Pins in connectors can get bent or corroded and cause issues like this as well; sometimes even overtightening the maf sensor can cause it to crack and break.
Sincerely,
Zach
The Following User Says Thank You to DeliciousTuning For This Useful Post:
CSG Mike (11-11-2015)
Old 11-11-2015, 06:42 PM   #3057
axelthrasher
Sincerely,
Zach
When I had called Jackson in the past, I was told that the alternator can interfere with MAF readings/signals - could this have something to do with it?
Old 11-11-2015, 07:09 PM   #3058
DeliciousTuning
If the wires are being run too close to the alternator it could cause some interference, but typically these aren't the codes you would be receiving. Especially in combination with each other! Usually, signal interference like that would just cause the readings to be skewed. A circuit low input code suggests that the ecu is not getting any voltage reading from the maf at all.
Sincerely,
Zach
Jackson Racing (11-12-2015)
Old 11-12-2015, 04:59 PM   #3059
axelthrasher
Sincerely,
Zach
I will monitor this closely, hopefully I don't receive this code again... but at least if I do - I will have a good idea where to start insofar as diagnosing the issue.
The Following 2 Users Say Thank You to axelthrasher For This Useful Post:
enivid (11-14-2015)
Old 11-14-2015, 01:37 PM   #3060
twag4
Drives: frs
I will say that the Ace Type A header with 350 over pipe really wakes up the midrange with this supercharger. That is all.
twag4 is offline   Reply With Quote
The Following 2 Users Say Thank You to twag4 For This Useful Post:
CSG Mike (11-15-2015), DeliciousTuning (11-14-2015)
Old 11-14-2015, 07:58 PM   #3061
DeliciousTuning
Agreed, we see an clear power increase as low as 2000 RPM's with the Ace Headers while also making the throttle more snappy.
Cheers,
William Knose
The Following 3 Users Say Thank You to DeliciousTuning For This Useful Post:
CSG Mike (11-15-2015), Jmonty (11-22-2015), twag4 (11-14-2015)
Old 11-14-2015, 08:44 PM   #3062
twag4
Drives: frs
Cheers,
William Knose
I am on a flash and go tune, so that makes a lot of sense!
Old 11-20-2015, 03:44 PM   #3063
Jackson Racing
Jackson Racing's Avatar
Drives: JR FR-S,
For those that may have the RPM stumble...
My car is bone stock except for the JR SC kit, using the JR tune on 93 octane. I get periods of the powerband where it feels off or it is just missing...
I have had the P0172 (System Too Rich Bank 1) and P1170 (Port Injector Fuel Performance) twice in a month. Car was sluggish, felt like it retarded all timing and threw a lot of fuel at it. Cleared the codes, went back to normal.
Talked to Jackson Racing a while back about this issue - they said clean MAF and try to keep the harness extension away from the alternator, that it can cause interference. Did both.
Yesterday was cruising on the highway at about 65-75. Car started feeling strange again... this time I pulled of the road, shut it off. Started the car back up, and it died right away. Popped hood, made sure all throttle body connections, ecu connections, and maf connections were snug. Also ensure battery (positive and negative) were tight, no issues on anything. Started the car again, same thing. Started again, revved it (2-3k) to keep it running and it would stay running, then back to idle it died out. Did this 2-3 times. Let it sit for 5-10 mins and then it started and acted normal.
Now, for the CEL I received during this start/idle issue. P0102 (Mass or Volume Air Flow Circuit Low Input) and P0113 (Intake Air Temperature Circuit High Input).
Anyone experience this before? Any idea on what is actually going on with it?
If you run into this any further, let us know. Email us at tech@jacksonracing.com.
Make sure that the extension harness is intact. I've only seen the IAT and MAF low input codes like yours when the harness gets chopped in half. I only see the harness get chopped in half when the harness is installed laying on the belt and the belt cuts through the harness.
-Oscar Jr.
Jackson Racing is offline   Reply With Quote
Old 11-21-2015, 10:24 AM   #3064
Utopia Be
Drives: BRZ 6MT
Is there some one who got Jackson Racing supercharger kit, and have not yet installed it???
I want some one to help me with the mounting bracket...
The problem is that i already have the Rotrex unit... I got Greddy intercooler and a work place to create very good piping.
But all i need is JRSC Mounting bracket... I have mailed them and got no response...
Maybe some one can just draw the bracket on paper, and send me this paper (even scaned a4 list) and than i can CNC it my self...
Im ready to pay for this $$$
And of course ifsomeone is selling this bracket lol!
I will buy it!!!
Utopia Be is offline   Reply With Quote
Old 11-21-2015, 02:28 PM   #3065
axelthrasher
-Oscar Jr.
No issue with the harness being damaged visually. Never came near a belt - I inspected it to be sure of that. Not sure what this issue was, but it hasn't come back... yet...
Old 11-23-2015, 01:14 PM   #3066
rosol16
Not A Member
rosol16's Avatar
Drives: 2014 Mustang GT
After reading through the first 25 pages and seeing no real issues with this kits I'm just gonna ask anyway. Has anyone had any real issues with this kit doing the DIY and included tune?
rosol16 is offline   Reply With Quote
The Following User Says Thank You to rosol16 For This Useful Post:
CSG Mike (11-23-2015)
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 05:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 10:04 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 04:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 05:14 PM
