Old 11-14-2015, 12:46 AM   #15
Originally Posted by jsalaz03 View Post
Is there any way I can find out that its the throwout baring. Starting to think it is not the clutch
Well, I'll take an exception to @radroach 's theory about a bad throw out bearing causing a soft clutch feel.
I figure what he was feeling (after replacement) was a stronger pressure plate (if it was replaced) and/or a more aggressive clutch disk surface (cause it was new).
There is nothing about a throw out bearing to get "soft". It simple sits there, going round and round), until it's forced to push against the fingers of the pressure plate.
Ultramaroon (11-14-2015)
Old 11-14-2015, 01:00 AM   #16
This ^^^
The TOB has been the go to explanation for every weird feel, noise, vibration and everything else under the sun lately and although there certainly are enough documented issues with them they have also been found to not be the problem just as many times. People are overlooking the simple answers to usually minor problems because they become so convinced it is the bearing they don't even look at anything else. There is usually no mistaking a throw out bearing going bad because the squeal will start well before failure (usually) and you will know there is something up not just think there is.
humfrz (11-14-2015)
Old 11-14-2015, 01:03 AM   #17
^^^this^^^
Old 11-14-2015, 01:24 AM   #18
jsalaz03
Drives: 2014 Subaru BRZ Limited (MT)
Good you got it checked out at the dealer. That dealership must not sell many BRZs ....... if no one there had ever driven one.
Although the clutch fluid level is up to full ...... there could still be air in the lines ..... that could give it a spongy feel.
I don't believe your perceived "loss of power" has anything to do with the clutch. Are you still using premium (high test) gasoline .... ??
I don't think a bad throw out bearing would be contributing to a soft clutch pedal or any loss of power.
However, it should hold together until the expert checks it out next month.
I have used nothing but 93 octane fuel for my car. fortunate for me it's easy to come by in NJ. I'll bleed my clutch fluid soon, haven't yet gotten to that. It may just be some air like you said.
Is it strange that I've also notice a tiny bit MPG loss? It has gone from 25.1 to 23.4 , it's mostly because like I said early, i gotta give it a little more gas/rev it more to get it going.
Also my car isn't as loud after the clutch got softer. I have an Invidia N1 catback. I would set off car alarms driving through parking lots haha by accident.
Really hope the clutch bleed will do the trick.
If the expert tells my car is fine and it's all in my head, I might just get a ECUTEK tune sooner than I thought.
jsalaz03 is offline   Reply With Quote
The Following 2 Users Say Thank You to jsalaz03 For This Useful Post:
humfrz (11-14-2015), Tcoat (11-14-2015)
Old 11-14-2015, 07:11 AM   #19
Brndn704
Brndn704's Avatar
In all seriousness, it's probably the throw out bearing. They are so poorly designed for this car. I'm having the same issue(s).
Brndn704 is offline   Reply With Quote
The Following User Says Thank You to Brndn704 For This Useful Post:
Packofcrows (11-14-2015)
Old 11-14-2015, 10:21 AM   #20
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Working on getting pictures but my TOB had side with metal sticking out. Thats what made my clutch clunky, reverse and 1st seemed loose and car would slightly rev itself like if something was dragging. Brb checking texts i got while asleep.
Here's pic, notice issue on bottom right. Bit of metal sticking out. Also bearing seem warped to anyone?
Other side:
Dealer said, "the issue was that it was leaking grease."
LMAO
Old 11-15-2015, 08:49 AM   #21
jsalaz03
Other side:
LMAO
Wow so it might be the TOB. I've heard and seen from other sites that the BRZ's TOB can become a problem. I love the BRZ but damn sometimes I think I should have waited for a later model so they can work out the kinks
Did your dealer cover it?? and hows the car driving now?
Old 11-15-2015, 08:55 AM   #22
jsalaz03
Which issues? and have you done anything to try to fix it?
Old 11-15-2015, 11:38 AM   #23
Brndn704
Brndn704's Avatar
Squeaky clutch, clutch sounding like water through copper piping when engaged, etc. I haven't even gotten it fixed yet. I'll end up replacing the clutch/throwout bearing all together at one time.
Old 11-15-2015, 04:09 PM   #24
DANG ........ I just can't conjure up that sound .....
Old 11-16-2015, 03:24 PM   #25
Brndn704
Brndn704's Avatar
It's really hard to describe, thats honestly the best way I can. Hmm let me try this. So in between switching gears its like this:
Vrooooooooom PSHHHHHH Vroooooooooooooooom PSHHHHHHH Vrooooooooo.....
Old 11-16-2015, 04:23 PM   #26
hmmmmm.........maybe air trapped in the clutch lines...?? Valve not staying closed in the clutch master or slave cylinder ..... ??
Just guessing .....
Old 11-16-2015, 05:09 PM   #27
Squeaky screeching sound when it's cold?
Screech replaced with PSHHHHH when clutch pedal is depressed?
Old 11-16-2015, 05:33 PM   #28
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
First Post Please be gentle. Might need New clutch, suggestions plz?
Wait mine sounds like
Vroooom ktsh.
Vroooooooom ktsh
(Very short & distinct)
Sorry I just find this way to describe the sound too funny to not jump into the action.
But on serious note ....any insight? This happens if I'm trying to shift fast ....>___>
clutch adjustment, no worries, transmission
BOYCE's Hot Lava Gentle Beast BOYCE Member's Car Journals 155 03-30-2014 01:22 PM
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 12:22 PM
Clutch Masters Clutch Kits | Island Import Performance IslandImportPerformance Transmission and Driveline 1 07-20-2012 12:06 PM
Gentle Leader - "Docked!" (New England) DMViper New England 135 06-07-2012 08:35 PM
