| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#1583 |
Country Boy 4 Life
I Love all the Pictures, Specs, and Constructive conversation on how to make MEATY Tires fit! Thanks to all that have done so.
#1584 |
Drives: Supercharged Car
Any LCA's or top hats*? I have the same coils but rubbing on 225's in the front =/
#1585 | |
Drives: 2015 BRZ
I may end up going a little more aggressive (-2.0) but I drive alot and want to keep even tire wear. Here is a before and after shot
#1586 |
Drives: 2015 BRZ
#1587 |
Drives: 2015 BRZ
#1588 |
Drives: A Blue One
Anybody know how to get rid of the rubbing at the front with the steering wheel turned all the way? My tires are rubbing the inside of the wheel-well when my steering wheel locks all the way to one side. Im guessing spacers, but can someone verify with me the minimal size they went with and what brand used?
Suspension: Stance SS Coilovers Tire Specs: 265/35/18 Michelin PSS Wheels: 18x9.5 +38 Camber: -2.8 L&R Height: 1 Finger gap clearance from fender, no fender mods @Lust what did you end up doing to eliminate the issue? Last edited by BPM; 11-13-2015 at 03:30 AM. |
#1589 | |
Drives: 13' Scion FRS
That before and after picture speaks for itself. Thank you so much! |
#1590 | |
001 of 012
Drives: MY12 NZDM Subaru BRZ "BRZ001"
Consider getting steering stops. @nzer had to - he runs 265/35.
BRZ001: Peace Love and Wheelies @metabrz on IG
#1591 | |
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
I had minor steering stops put in that restrict the lock until just before rubbing. Don't even notice the minor change in turning circle. I was going to put 5mm spacers in but went for steering stops instead to avoid any fender rubbing. Was the perfect solution for me. 5mm spacers for you would change you to +30 offset and that's quite a bit of poke. It'd be illegal here as you'd need to run too much camber to get the wheels withing the fender line. Not sure on the rules where you are.
My fully loaded TRD86
http://www.ft86club.com/forums/showt...760#post582760 |
#1592 |
Drives: A Blue One
Any recommendations on steering stops used/fabricated? I will be looking into this option as well.
Thanks! |
#1593 | |
Perhaps ask an alignment place.
#1594 |
#1595 | |
Drives: 2017 Subaru BRZ
I am seriously considering going down in tire size to a 255/35 but we will see. I also got another alignment. Now running -2 up front and -3 in the back. Going to go back yet again to lower it some more and get another alignment. Probably will end up running -2.5 in the front and -2 in the rear with a little bit of toe in. |
#1596 |
Question guys.. Probably the best spot since you guys actually have the meaty tires I'm looking into..
Spec: Lowering springs dropped just under 1" Camber -1.5f -1r I'm looking at 18x9.5 +38 wheels and want to probably go 265 tires.. Will that wheel and tire combo fit stock struts? Will it work with my camber too? I'm probably going to end up getting coils before the wheels, cause winter, but just in case I was wondering if that'll work. I don't mind adding a tiny bit more camber, -.5 more front and back but that's about it. I had 18x9.5+40 with 255 on the rear (staggered set up) and it fit with no issues I wouldn't see the 265 interfering with anything back there mainly I'm thinking about the front. Thanks
| Winter Tire Review Thread (Please contribute) | pastuch | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 344 | 03-13-2024 05:49 PM |
| Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 | ScionFR-S | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 97 | 09-09-2015 06:32 PM |
| Meaty rubber on flush spoke rims? | red_comet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 16 | 06-14-2013 12:21 PM |
| Official wheel/tire fitment thread needed | empower-auto | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 06-22-2012 01:40 AM |
| The Wheel and Tire Fitting Thread | EvoFanatic | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 03-15-2012 03:05 PM |
