Old 11-11-2015, 12:52 AM   #1
Darryljr11
Sideways and Smiling!
Darryljr11's Avatar
Drives: Scion FR-S
Anyone with a built motor using a GTX3071R?
Just curious on owners opinions and results with this turbo
Element Tuning 10:1 Pro Comp Long Block, Ptuning SS GT3076R turbo kit, Exedy Stage 2 Clutch, and a bunch of other stuff
Darryljr11 is offline   Reply With Quote
Old 11-11-2015, 09:23 AM   #2
nelsmar
I am... But your post is lacking any details to construct a proper answer.
Your built motor and my built motor are going to be different... And Yield different results. Maybe you should ask your tuner for a recommendation of a turbo to match the power goals you want?
My flickr - Canibeat
Local magazine scout
Old 11-11-2015, 10:50 PM   #3
Darryljr11
Darryljr11's Avatar
Drives: Scion FR-S
Im just curious if anyone is running this instead of the GTx3076r. To me that turbo is too laggy and i just wanted to know what those running the GTX3071r think of it.
Old 11-12-2015, 05:25 AM   #4
Northwest86
Drives: Velocity Orange 86 GT
I've got a GTX3067r and the response is like a supercharger. But thats due to a well designed setup and about 30cm from the turbo to the intake. I'd be more interested in manifold and intercooler setup.
Northwest86 is offline   Reply With Quote
Old 11-12-2015, 08:22 AM   #5
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
I have no lag at all with a non build motor. I am up in the air with CR I'm going to use on my build. I used 9.5:1 on my turbo Busa and it's like a 600cc bike before boost and then snap.... to 16psi on 93 and it's nasty when on boost. I'm personally not sure if I want that. I may do rods, springs, retainers and find a good high CR piston and just run e85.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 11-12-2015, 10:03 AM   #6
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
We did a 3076 gtx last month. If you build it to rev high it's an awesome ride. GTX3071r should do close to the same as the dyno below but about 200 rpm earlier spool, though the 3076 still has some reserve.
[ame]https://m.youtube.com/watch?v=1ux7a9F0EK4[/ame]
Xero-Limit is offline   Reply With Quote
The Following 2 Users Say Thank You to Xero-Limit For This Useful Post:
Darryljr11 (11-14-2015), DustinS (06-21-2016)
Who has a built motor? Fabron757 Forced Induction 77 11-19-2020 10:04 PM
10.5:1 Built Motor. alexisfire02 Engine, Exhaust, Bolt-Ons 16 03-24-2015 10:06 AM
IN: 05 GTO (built motor and rearmount turbo) Subi-Subi-Ruu Cars for Sale/Trade 4 12-14-2014 08:59 PM
which built motor? Fabron757 Forced Induction 82 11-26-2013 10:08 AM
Built motor over 600hp Fabron757 Forced Induction 19 11-02-2013 04:54 PM
