Old 06-14-2012, 04:43 PM   #15
Longhorn248
Hook 'em
Longhorn248's Avatar
Originally Posted by robotvoice View Post
Actually....because HID bulbs give off about 2-3 times the amount of light as a halogen bulb, it's very import to have your lights adjusted properly as to not blind other drivers and having a leveling device is essential for this. With a couple people in the back of the car/full tank of gas/cargo in the trunk (or any combination of these) the beam patter will raise up quite a bit and you will need the ability to adjust your headlights on the fly instead of having to pop the hood every time you need to make an adjustment.
Some cars have auto-levelers for their HID headlights which gets rid of the manual adjuster wheel but this also increases the cost of the lights as well.
I guess I just don't haul enough stuff around in the back of my cars to make that an issue, but you make a good point.
Longhorn248 is offline   Reply With Quote
Old 06-14-2012, 04:55 PM   #16
RRnold
2 wheel member
RRnold's Avatar
Drives: JZA80, 997.1, Taco
Originally Posted by Jeff Lange View Post
Headlights get adjusted manually even on cars that have auto-leveling. You need to be able to set where "base" level is before it starts to adjust it.
I'm sure the BRZ is probably the same.
Jeff
+1
I was going to mention the same thing. Can you adjust the headlight alignment screws on the actual housing first then dial in the headlight aim on the dash.
Old 06-14-2012, 04:57 PM   #17
NYC BRZ
AutoX Addict
NYC BRZ's Avatar
Drives: 08 Pontiac G8 GT,13 GBS BRZ Limited
Definitely adjust the headlight level. I picked mine up last night and drove 100 miles home. 75 of which were in complete darkness through PA and NJ. The level helps big time. I actually had mine on 1 or 2 most of the way.
2013 BRZ Limited- GBS - 6MT -VIN #0937
~~NYR SCCA # 18 C Street R (CSR)~~
"But there’s no mistaking the noise. This car is loud, and not in a particularly nice way. There’s no crisp exhaust note, no induction wheezing. It’s just the sound of petrol exploding in a metal box." - Jeremy Clarkson
NYC BRZ is offline   Reply With Quote
The Following User Says Thank You to NYC BRZ For This Useful Post:
KB_BRZ (01-10-2017)
Old 06-15-2012, 09:46 AM   #18
billysangi
I adjusted the settings as suggested with the "wheel". All is fine now. I can actually see where I am going.
Thanks for the info
billysangi is offline   Reply With Quote
Old 06-15-2012, 09:57 AM   #19
Tbxgz
Tbxgz's Avatar
Drives: 2013 BRZ Limited 6MT
IDK if this helps but I found this as well:
Tbxgz is offline   Reply With Quote
The Following 3 Users Say Thank You to Tbxgz For This Useful Post:
chaoskaze (11-11-2015), Fly Guy (06-18-2012), tCsonfrs (01-10-2017)
Old 06-15-2012, 02:27 PM   #20
#87
I usually post drunk
#87's Avatar
This is great in theory but every ***git has their HIDs aimed up or shitty HID in halogen housing blinding everyone anyway.
/rant
#87 is offline   Reply With Quote
The Following User Says Thank You to #87 For This Useful Post:
blu_ (06-17-2012)
Old 06-17-2012, 01:00 AM   #21
robotvoice
Drives: 07 STI
/rant
Your frustrations, while they are valid, should really be aimed at those who run cheap HID kits and not just every car on the road with HID headlights. The cheap HID kits people use in halogen headlights give off so much glare that no amount of aiming will keep them from blinding other drivers. Cars that are equipped with HID headlight from the factory won't blind you on the road unless the driver has either manually adjusted them too high or not lowered them down with the adjustment knob with cargo/passengers in the back of the car.
robotvoice is offline   Reply With Quote
The Following User Says Thank You to robotvoice For This Useful Post:
blu_ (06-17-2012)
Old 06-17-2012, 01:26 AM   #22
Sony
Sony's Avatar
Drives: 2013 Subaru BRZ MT Limited
^^ +1
Don't blame the HID lamps for something that is really the fault of the driver/owner.
More light output is always better, but people who have poorly aimed headlamps or use poorly designed aftermarket kits are the true problem. More light on the road itself had saved my ass more than once. Especially here in New England where hitting a deer is something to be feared. I have upgraded halogens in my truck and there have been several instances where I have avoided deer because I saw them early enough to slow down. If I was running my stock headlamps I may not have seen them in time, and more than once I have seen deer on the side of the road only to slow down and have one dart in front of me. If I hadn't slowed down I surely would have hit them and I wouldn't have slowed down if I didn't have the extra light from extra bright lamps. That being said, I am not running HID's in Halogen housings and my halogens are aimed properly as to not blind other drivers.
Also, one of the other biggest things is DON'T RUN YOUR FOG LAMPS UNLESS IT'S FOGGY!!!!! Fog lamps are not aimed and easily blind oncoming drivers, they are basically like driving with your low beams and high beams on at the same time. There is a reason driving with your fog lamps on when it's not foggy is illegal in Australia and most European countries.
Dark Blue 2020 Subaru Forester Sport, Name: Apollo - God of Music
WRB 2013 Subaru BRZ Limited MT, Name: Zeus - Father of all God's and God of Sky and Thunder
Perrin Cat-Back, ECUTek Tune by Kaizen Tuning, Perrin Silicone Radiator Hoses, Perrin Master Cylinder Brace, Perrin True Cold Air Intake
Sony is offline   Reply With Quote
Old 06-17-2012, 01:47 AM   #23
blu_
blu_'s Avatar
Drives: SWP BRZ LTD
Pretty sure he was just pointing out the futility of the situation.
We already have:
One vendor marketing RHD HID's to kids because of "JDM yo". AND telling them there is no issue with the lighting angle for the US.
Several HID kits, which judging by the pictures posted have very poor cutoff and are blinding people driving toward them.
Being someone with poor night vision, it really pisses me off when I see that stuff.
blu_ is offline   Reply With Quote
The Following User Says Thank You to blu_ For This Useful Post:
OrbitalEllipses (06-17-2012)
Old 06-17-2012, 07:30 AM   #24
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Again, this is an owner's fault, not the fault of the lights. FOG lights are supposed to be aimed at the GROUND about 25ft in front of the car. They are supposed to reflect off of the wet pavement to illuminate signs ahead of the car without reflecting back off of the fog ahead. Properly aimed fog lights are not blinding to oncoming cars because they just aren't aimed high enough.
Now DRIVING lights are a different matter. Those are supposed to supplement highbeams, not low beams and should only be on when the brights are on. As such, they are aimed higher and can blind oncoming traffic.
The Following User Says Thank You to Draco-REX For This Useful Post:
Bristecom (12-31-2016)
Old 06-18-2012, 08:53 AM   #25
robotvoice
Drives: 07 STI
We already have:
It's really unfortunate that the community here is already being flooded with crappy HID products and misleading information. I hope people will take the time to get educated about HID tech before wasting money on a cheap kit and blinding other drivers on the road.
Old 06-18-2012, 09:32 AM   #26
Sushi Boy
Drives: Japanese
^^ +1
another good reason why i will be getting a BRZ instead of the other...
Sushi Boy is offline   Reply With Quote
Old 11-11-2015, 07:51 PM   #27
Sgtfluffy16
Drives: White BRZ Limited
I will be doing manual adjustment of mine. They are still too low even at the 0 setting.
Sgtfluffy16 is offline   Reply With Quote
Old 11-11-2015, 07:57 PM   #28
Probably one of the funniest totally out of date threads ever to be resurrected for no apparent reason.
jbailey8748 (03-25-2016), pfaffendorn (02-20-2016)
Idle issue? yayforaddison Issues | Warranty | Recalls / TSB 891 07-14-2016 10:42 AM
Starting issue Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 33 08-15-2013 07:40 AM
MT Gear Indicator Issue civicdrivr Scion FR-S / Toyota 86 GT86 General Forum 28 05-21-2012 11:40 PM
First 86 issue and advice Mr.Eightsix Scion FR-S / Toyota 86 GT86 General Forum 34 05-19-2012 11:49 AM
Headrest issue? Sport-Tech Scion FR-S / Toyota 86 GT86 General Forum 11 12-01-2011 03:48 PM
