Old 11-11-2015, 12:08 PM   #29
SoCal80six
SoCal80six's Avatar
Drives: Asphalt frs
Originally Posted by John Rambo View Post
I was running a FBM base kit @ 10psi on 91 octane for about 15k miles (Car is almost at 29k miles, turbo went in around 14k)... until last night, when the car decided it would be better off with another window.
I'm posting because I'm wondering what my options are from here on out in terms of cost. I've done some looking around the forums and a lot of people would build the motor for boost, and others say they would just fix it and maybe part out their FI kit and other mods. Others still would take this as an opportunity to do an engine swap? Shop said they can't take a look at the car until the 23rd so I've got some time to decide.
How much am I looking at to replace the block? How much am I looking at to get a built motor? And is it worth it considering so many people have posted about transmission issues with high power output? What about an engine swap? How much money am I looking at for a dope swap? Looking for any and all advice.
Thanks in advance.
Sucks man I know the feeling just blew mine not even 2 days ago smh. Had about 2k of boosted miles and decided to switch map to same exact map with less boost on e85 worked perfect the whole day put e85 in and boost started to spike. Was only set to 7.5 psi ended up hitting around 18 and 19psi around 17 when car gave out smh. Looking for best way to go about this also no visible damage don't to block what so ever though no oil, doesn't look like rod knocked out of block either still hoping for the best on it. Good luck though man let me know what you come up with definitely looking for some opinions on best route to go with it also.
Sent from my SM-N920T using Tapatalk
SoCal80six is offline   Reply With Quote
The Following User Says Thank You to SoCal80six For This Useful Post:
John Rambo (11-11-2015)
Old 11-11-2015, 12:22 PM   #30
John Rambo
John Rambo's Avatar
Drives: Turbo BRZ Limited 6MT
Originally Posted by GsxrMe View Post
What were you tapping oil for next to the AC? Did you install a different oil feed for the turbo? Fullblown doesn't tab oil there; they use a T fitting on the oil pressure barb.
I also see a catch can, do you have both left and right PCV valves venting to atmosphere to prevent crack case being boosted? Fullblown recommends vent to atmosphere on the kit no matter what.
I used this
I'm not sure how the catch can was installed. I can take a look at it later today. I had evasive do it.
John Rambo is offline   Reply With Quote
Old 11-11-2015, 12:45 PM   #31
Rampage
Senior Member/Old Fanboi
Rampage's Avatar
Drives: 2000 2ZZ-GE MR2 Spyder HT
Going with a built short block won't necessarily cause more power than the transmission can handle. Get a short block with forged components that is built for boost with a lower compression ratio. The power output is controlled by the amount of boost you chose to push through the engine.
The problem with these engines are they are not built for boost and the high compression does not play nice with boost so you are walking a knifes edge when trying to get a proper and safe tune. Then what happens in a lot of cases is the owner gets use to and bored with the power and decides to turn the boost up "just a bit". Sooner or later they will all blow.
If you are going to go boosted again then get a block that is built to handle it, get a good tune that is just a bit on the conservative side and then practice self restraint by leaving it alone outside of proper maintenance and periodic inspection..
So many modders have more cents than sense!
Rampage is offline   Reply With Quote
The Following 2 Users Say Thank You to Rampage For This Useful Post:
B-R-Z (12-04-2015), Tcoat (11-11-2015)
Old 11-11-2015, 01:03 PM   #32
FRS Johnny
FRS Johnny's Avatar
Drives: 2013 FR-S Whiteout MT
I bought the jdl catch can for the fbm kit. That still okay right?
https://jdlautodesign.net/shop/ft86-...ted-catch-can/
Is it necessary for another one for the crank case?
When in doubt, throttle out!
FRS Johnny is offline   Reply With Quote
Old 11-11-2015, 01:13 PM   #33
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
That catch can has two inlet ports, it is connected to both the PCV and the breather sides, so you're fine with that one, don't need anything else.
The Following 2 Users Say Thank You to Sportsguy83 For This Useful Post:
FRS Johnny (11-11-2015), JDLAutoDesign (11-11-2015)
Old 11-11-2015, 01:53 PM   #34
JDLAutoDesign
JDLAutoDesign's Avatar
Drives: 13 FRS
Correct both rear and front engine ports connect to the can and the upper can port connects to the turbo intake or OEM intake port.
JDLAutoDesign is offline   Reply With Quote
The Following 2 Users Say Thank You to JDLAutoDesign For This Useful Post:
FRS Johnny (11-11-2015), Sportsguy83 (11-11-2015)
Old 11-11-2015, 03:02 PM   #35
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
I'm only obsessed with the PCV to atmosphere/Turbo inlet because of pervious turbo hayabusa hickups. I was having so many damn issues with the crankcase not releasing boost and it cost me, rods, je pistons, case and head work.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 11-11-2015, 04:28 PM   #36
wparsons
wparsons's Avatar
High compression isn't the problem, not at all.
You're right that the issue is people turning up the boost, but it's because they're doing so without adjusting the rest of the tune for it.
The same thing will happen with a built block, it's just stronger so the threshold is higher.
With a lower c/r you need to run a lot more boost to make the same power, you get more lag and less off boost power. More boost = more heat, so you might need better intercooling.
flickr
The Following 3 Users Say Thank You to wparsons For This Useful Post:
DAEMANO (11-16-2015), SoCal80six (11-11-2015), Sportsguy83 (11-12-2015)
Old 11-11-2015, 04:50 PM   #37
Rampage
Rampage's Avatar
I disagree with this in at least one sense although I will refrain from entering into a long winded debate with you or anyone else on the subject. High compression increases the likelihood of detonation therefore the need for higher octane fuel, direct injection (in part) and tuning measures that must be used to control it. It definitely lowers your margin for error when going forced induction.
Yes, heat is also a factor (and a factor related to high compression).
The Following User Says Thank You to Rampage For This Useful Post:
johan (11-12-2015)
Old 11-12-2015, 01:31 PM   #38
John Rambo
John Rambo's Avatar
Trying to weigh the costs of a brand new shortblock from toyota/subaru or a junkyard complete motor. With labor for each respective option, anyone wanna chime in here?
Old 11-12-2015, 02:55 PM   #39
Scott@HKSUSA
Scott@HKSUSA's Avatar
Drives: 2013 FR-S, HKS V2 S/C
Static compression ratio vs. dynamic compression ratio.
Variable cam timing plays a huge role in this as it allows one to control cylinder pressure throughout the rev range. You could run a 15:1 engine on pump gas with 12 psi of boost if you allow the cams to bleed off enough cylinder pressure. Which is why it's not hard to find a boosted 12:1 Honda K, or Toyota 2ZZ, or FA20.
But without variable cams, you'd have to degree your cams for the minimum amount of overlap that keeps the engine from detonating. And that takes a lot of time and testing. Which is why you don't see a lot of boosted 12:1 Honda B's. Or KA24's. Or 4G63's. Or SBC's. Etc.
But to your point, if I was starting a FA20 build for boost from scratch I'd certainly pick a lower than stock C/R. The window for MBT is simply a lot wider and easier to find the lower you go.
Scott@HKSUSA is offline   Reply With Quote
The Following 7 Users Say Thank You to Scott@HKSUSA For This Useful Post:
DAEMANO (11-16-2015), DriftinFRS (11-12-2015), Kris86 (10-16-2017), Paulo86 (12-22-2015), raven1231 (11-12-2015), RIP.S2000 (11-18-2015), wparsons (11-12-2015)
Old 11-12-2015, 03:27 PM   #40
Dr Speed
Drives: Red
Do you monitor your active A/F ratio's on a guage with regular driving??
Dr Speed is offline   Reply With Quote
Old 11-16-2015, 10:32 PM   #41
John Rambo
John Rambo's Avatar
I have a p3 gauge so either I'd usually switch it between afr, boost, and coolant/oil temps on an average drive.
Old 11-16-2015, 11:27 PM   #42
stugray
Drives: 2013 GBS BRZ Limited
With a lower c/r you need to run a lot more boost to make the same power, you get more lag and less off boost power. ...
But with low CR and boost, you have a greater margin for error.
If it quits running right, you lose hp.
With high static CR and boost, you have very little margin for error.
If it quits running right, it blows up.
Similar to that old racing tuning adage: 'You can run rich all day long, but you can only run lean once.'
Help! New Car Engine Blew Up. What are my rights? Obsidiank Scion FR-S / Toyota 86 GT86 General Forum 53 12-11-2014 11:43 AM
so my motor blew up on dyno today jdl kit gtx3071 kingkai23 Forced Induction 62 07-24-2014 09:09 PM
So my engine blew up.... alliedcam1 Engine, Exhaust, Transmission 57 12-28-2013 02:50 PM
What would You do if your motor blew? TyperRspec789 Forced Induction 58 07-02-2013 10:54 PM
Coverage of Subaru BRZ Debut at Re-Mix Night at Tokyo Night Club and Music Video mockngbrd BRZ First-Gen (2012+) — General Topics 36 01-04-2012 06:15 PM
