#1821 | |
btr.life
Drives: 2022 GR86
| The Following User Says Thank You to justinco For This Useful Post: | Shark_Bait88 (11-11-2015) |
#1822 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
Lol. It rides better where I'm set at anyway so I don't mind. Was kinda bouncy set soft.
#1823 |
Drives: Many
Putting it at 8 clicks fixed like 90% of the noises, so you guys were right. Still slightly annoying, but so it goes.
Ride quality still excellent lol. |
#1824 |
Drives: 2013 Firestorm FR-S
STX parts have begun to arrive.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
#1825 |
Drives: '22 BRZ
So, I'm curious what the thinking is with pretty much being required to have an aftermarket front bar to be competitive in STX... Just because it speeds up transitions that much for slaloms, chicago boxes, etc?
The reason I ask... I put big swaybars on my GTI and it definitely helped that aspect but it made the car ride like crap on the street. I want to avoid that at all costs for the BRZ as it will be my sole car... I'd also like to avoid making the car understeer like it does stock when I go back to the track (possibly camber related issues there though as I'm still stock alignment) so avoiding the addition of a fat front bar will help there too. |
| The Following User Says Thank You to DocWalt For This Useful Post: | strat61caster (11-12-2015) |
#1826 | |
Drives: '13 FRS - STX
I'm in the same boat, trying to decide where to go to be very competitive without too much sacrifice to DD/HPDE. Based on what you're looking at an adjustable sway bar may do the trick? It would be cool if you could go between softer than stock to compensate for front stiff springs and then ratchet it up to very stiff for your slalom heavy tight courses. It seems like the hardcore guys aren't running big bars, sure there are a couple but the smallest whiteline bar and Strano seem to be getting the most praise and they're the mildest bars out there. Heh maybe I'm wrong, pretty much all the setup advice here boils to ~400 lbs/in spring rates, small bias to your preference, slightly stiffer front bar. It will be an interesting journey. ![]() ![]() Edit: Came across this thread last night, an interesting interpretation of how to setup this chassis: http://www.ft86club.com/forums/showthread.php?t=10643 |
#1827 | |
Drives: '22 BRZ
I'm already going softer than the normal ~400lbs/in spring rate (I'm going with 6k f/r at least for the first half of '16), so I may be able to get away with the normal Whiteline or Strano front bar, then maybe the Whiteline adjustable rear for balance. As it is, I've essentially never driven the car even close to CS prep, but I was reasonably competitive locally in STX with just a header and tune. Obviously Simmons and Slevin destroyed me, but it was fun to see what the Prius tires could do
#1828 |
Drives: 2013 Raven FR-S
Hey, I have a pretty similar question. I just recently installed RCE Tarmac 2's in my FRS. I'm currently still running the Whiteline 20mm adjustable sway bar up front and the stock bar in rear. With RCE's recommended damping settings, it understeered pretty bad at my last AutoX event. I haven't had a chance to mess around with damper settings yet, but I'm wondering if I should put the stock swaybar back in front? It seems like with the stiffer spring rate of the T2's, the stock bars would be enough, but I'm not sure. Or would it be better to put a stiffer bar in rear to balance things out? Kind of confused which way to go at this point.
#1829 | |
My car can actually use more camber up front (I believe I'm approximately at -3 degrees) but I actually run out of grip in the rear when I go up higher than my current setting, I believe this is because I'm still at OEM camber in the rear (less than -1.5 degrees). So I'm compromising my grip to retain balance. LCA's will be installed over the winter to prove this out. |
#1830 | |
#1831 |
( ͡° ͜ʖ ͡°)
Drives: '13 Whiteout FR-S A/T
@strat61caster my research is telling me that a Strano or similar front stiffness such as Hotchkis, White line 20mm is DD friendly yet more competitive than OEM
Sent from my A0001 using Tapatalk |
| The Following 2 Users Say Thank You to drewbot For This Useful Post: | DocWalt (11-17-2015), strat61caster (11-12-2015) |
#1832 |
I'd try more front camber before spending money on bars, it's common to hear numbers around -3 degrees or greater, you'd simply be adding front grip to reduce understeer. Unless of course you've been measuring tire temperatures and you're confident that with your setup more camber would reduce grip. But definitely try the stock bar too, who knows it may work better with your setup as well!
IMO I've been bouncing back and forth on camber plate adjustment on the fly, the only fear here is screwing up the toe but I haven't seen any adverse affects other than a hot inner edge while street driving with high camber. The geometry seems to be rather insensitive to camber changes affecting other measurements. Hopefully I'll get some tools this winter and actually prove this out and plot out some curves... |
#1833 | |
APEXHNTR
Drives: 10 Series FR-S #1867
The rear is a whole different story. Balancing act.
2013 Sc10n FR-S 10 Series #1867 of 2500 in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer] |
| The Following User Says Thank You to Silver Ignition For This Useful Post: | strat61caster (11-13-2015) |
#1834 |
Any ideas to combat inside rear wheel lift?
I am on feal coilovers 7k/7k, everything else pretty stock. 2.9 camber all around, I know that is too much in the rear. 0 toe front. tiny bit toe in rear. Front bar? Increase shock stiffness front? and softer rear? |
| Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 03:12 PM |
| SCCA sway bar rules | gmookher | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 09-01-2012 07:48 PM |
| Suggestion for vendor rules... | Tainen | Site Announcements / Questions / Issues | 31 | 08-15-2012 02:53 PM |
| Rules for posting in this section | Hachiroku | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 06-25-2012 12:02 PM |
