Old 11-11-2015, 12:53 AM   #1
mscamp02
Drives: 2013 FRS
install issue, cant break crank loose
So, I cant break my crank loose to save my life. I have it locked in 6th gear so its not free spinning but even with about 2.5 ft of tubing I can't get enough torque to break the bolt loose. It just has a really bad spongy feeling and still very very difficulty, turns the crank. Not sure how else to go about it.
mscamp02 is offline   Reply With Quote
Old 11-11-2015, 01:15 AM   #2
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Haven't tried it on this car but, sometimes you can wedge the breaker bar against the floor or frame and bump the starter a bit. MAke sure everything spins the way you need it to before hand though. Also make sure your using a 6 point socket, a 12 point may round it.
Old 11-11-2015, 01:50 AM   #3
mscamp02
Drives: 2013 FRS
ended up having to jam a large screw driver in between the pully and the block in order to prevent that spongy creep.
Thanks.
No crank no start issue *KID* Issues | Warranty | Recalls / TSB 3 09-29-2014 07:22 AM
Issue with Beatsonic Sharkfin (loose after application 2 months out) iaclimber4 Cosmetic Modification (Interior/Exterior/Lighting) 11 06-22-2014 02:31 AM
Unable to loosen crank pulley, even with 6 foot break bar! tbertran Engine, Exhaust, Transmission 36 05-20-2014 02:34 PM
aFe Install, keep or loose noise generator jflogerzi Engine, Exhaust, Transmission 6 01-19-2013 07:50 PM
Correlation between CEL issue and break-in habits switchlanez Issues | Warranty | Recalls / TSB 8 10-17-2012 11:40 AM
