Old 03-06-2015, 03:46 PM   #29
WORKS
WORKS's Avatar
Drives: WORKS CARB Legal Turbo BRZ
WORKS lug nuts
Over the years we've enjoyed the lightweight aspect of several different brands, but have been turned off when they don't last very long, required special tools or the special tool fails with repeated use. These were designed with track use in mind first, but also work for daily driving street cars. We have been selling them for over 6 years and have been used on countless street, track and race cars (such as USTCC racecars).
Billet machined from very durable 7075 Aircraft Aluminum that will not gall or bind like other unknown materials most lug nuts are made of. Then they go through a bead blasting and Type III Hard Anodization process which gives them their satin black finish, corrosion resistance and long-term durability.
WORKS is offline   Reply With Quote
Old 03-06-2015, 04:39 PM   #30
Dezoris
Dezoris's Avatar
Muteki SR48 open, on OEM and ARPs.
Old 03-09-2015, 02:49 AM   #31
Joe-G
Canada Eh!
Joe-G's Avatar
Drives: '13 FRS
Kics Kyokugen chromoly open ended here. Been really good so far.I dont think I would ever use an aluminum nut unless its from a reputable manufacturer. Even then, they might last long, but they wont look too pretty after multiple abuse.
Joe-G is offline   Reply With Quote
Old 03-09-2015, 05:13 AM   #32
fatalelement
fatalelement's Avatar
Drives: 2015 FR-S (Halo)
Originally Posted by 1ofaKind View Post
Amuse Titan lugnuts, best lugs and lightest lug nuts on the market.
Lol you can buy a set of basic wheels for less than those lugs, Powerhouse Amuse is gettin' real loose with that markup hahaha
Sent from my HTC One_M8 using Tapatalk
fatalelement is offline   Reply With Quote
Old 11-09-2015, 07:18 AM   #33
travisb
travisb's Avatar
Drives: N/A
I just purchased Muteki 32905B SR Series Black 12mm x 1.25mm SR48 Open End Lug Nut Set and ARP wheel studs. I got these because I broke a couple studs changing my wheels back and forth for autox.
Will these lugs work on my stock wheels as well? If not, what are some open end lugs that will work on the stock wheels?
2014 BRZ, SWP, OFT, Kosei K4R 17x7 with ZII SS
travisb is offline   Reply With Quote
Old 11-09-2015, 09:24 AM   #34
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Gorilla here, they look and work great.
Old 11-09-2015, 09:34 AM   #35
wparsons
wparsons's Avatar
SR48's are fine on stock wheels, I run them all winter for my snows.
flickr
travisb (11-09-2015)
Old 11-09-2015, 11:42 AM   #36
CatDaddysBBQ
Drives: '13 FR-S
I use the OEM ones on my OEM wheels with winter tires, and a set of Gorillas for the fair-weather wheels.
CatDaddysBBQ is offline   Reply With Quote
Old 11-10-2015, 11:17 AM   #37
Gear_One_Performance
Gear_One_Performance's Avatar
Drives: 2014 BRZ SCCA STU endurance car
Cheap gorilla steel open ended nuts on ARP studs, They can take a beating and work well for us doing quick tire changes in pit stops.
Gear_One_Performance is offline   Reply With Quote
Old 11-10-2015, 12:33 PM   #38
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
No rust issues?
smg1138 is offline   Reply With Quote
Old 11-10-2015, 12:43 PM   #39
wparsons
wparsons's Avatar
Originally Posted by smg1138 View Post
No rust issues?
Not really. They have a tiny bit of surface rust on the outer surface, but nothing on the threads.
flickr
smg1138 (11-10-2015)
Old 11-11-2015, 03:18 AM   #40
owenxguo
owenxguo's Avatar
Drives: MY13 BRZ
taiwan brand aluminum lugs, so far so good on both my BRZ and s2000 race cars, I am surprised, I guess torque setting is important.
owenxguo is offline   Reply With Quote
Old 11-11-2015, 11:12 AM   #41
Sleepless
Sleepless's Avatar
Drives: 2016 FR-S
+1 on Gorilla
Sleepless is offline   Reply With Quote
How do you guys running 18x9.5 in the front do it? ysr50guy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 05-04-2014 01:49 PM
Closed Project Kick Revo Lug Nuts (closed) ARP Extended Lugs Sportsguy83 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 02-25-2014 10:46 AM
BRZ stock lugs and lock nuts w/ key scion dad Wheels and Tires 0 09-15-2013 09:46 PM
what upgraded pads are you guys running? ft86me Suspension | Chassis | Brakes -- Sponsored by 949 Racing 28 07-18-2013 12:22 PM
Stock Wheels and Gorrilla spline Lugs Nuts USMC -FRS Wheels and Tires 3 02-21-2013 01:32 PM
