Old 11-09-2015, 11:38 PM   #1
Rifle
EX-86 Supercharged God
Rifle's Avatar
Drives: '16 Series.HyperBlue BRZ
Creaking during turning after coilovers?
I have some bad creaking, not like a rocking chair creak, more like grinding feeling after putting on my coils. I'm lowered on all 4 corners to about an inch of tire clearance from the body. I'm on 17x9 + 35s, w/ 255/40s.
Only happens when turning.
My first indication is that the tires are too wide and I'm rubbing against the perch, however, it just started to do this after the coils.. and I've had the tires on with no problem with oem.. - and sounded even worse in the rain (which makes me think it's not rub...).
Anyone have any sort of idea?
Tein Street Basis, -0.1 deg camber on the fronts. Stock everything else.
Sprintex 210 Supercharged HyperBlue BRZ "HI MOM"
295WHP/220TQ
Rifle is offline   Reply With Quote
Old 11-10-2015, 12:17 AM   #2
whataboutbob
AutoX-10/10ths every run
It is common for coil overs to groan on the front when turning. You probably need thrust bearings.
http://www.summitracing.com/search/p...hrust-bearings
Build thread:Here
Old 11-10-2015, 12:18 AM   #3
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
Also, check to see if your end links are hitting the control arm.
jawn is offline   Reply With Quote
Old 11-10-2015, 11:04 AM   #4
Gear_One_Performance
Gear_One_Performance's Avatar
Drives: 2014 BRZ SCCA STU endurance car
Before buying anything the first thing I would do is check with the car settled on the ground that you're not hitting anything with the wheel in full lock in each direction.
Gear_One_Performance is offline   Reply With Quote
Old 11-10-2015, 11:34 AM   #5
asdf
Loading...████████] 99%
asdf's Avatar
Drives: #0517
Only -.1 camber? Are you not poking? I would think it is rubbing, how low are you?
asdf is offline   Reply With Quote
Old 11-10-2015, 11:56 AM   #6
Rifle
Rifle's Avatar
Finger gap on all 4 corners. -.1 in the front, 2.5ish in the rears (stock LCAs)
295WHP/220TQ
Old 11-10-2015, 12:07 PM   #7
Rifle
Rifle's Avatar
No rub or grind when parked and moving wheel. Clears the perches with no problem. Problem exists when driving and turning.
295WHP/220TQ
Old 11-10-2015, 12:10 PM   #8
Rifle
Rifle's Avatar
Triple post, but also doesn't do it low speeds when turning. 10-15+.
295WHP/220TQ
Old 11-10-2015, 12:51 PM   #9
wparsons
wparsons's Avatar
It's the springs for sure, thrust bearings will fix the issue.
flickr
Popping, Crunching and Creaking Noise MyEvilMonkeys Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 07-22-2020 12:50 PM
Clutch clicking/creaking Bg8780 Issues | Warranty | Recalls / TSB 4 03-24-2015 11:27 PM
Help! New Fortune Auto 500's creaking right rear. mothespaceman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 11-15-2014 04:59 PM
Seats creaking Wes Issues | Warranty | Recalls / TSB 28 06-15-2014 06:19 PM
TC turning back on after turning it off Xdragonxb0i Issues | Warranty | Recalls / TSB 2 02-01-2013 04:19 PM
