#43 |
Drives: 2014 GT86
Common failure? What makes you think so? One thing is how reliable is or isn't some overmoded car (or it's engine), another thing how long lasts not abused and almost stock one.
| The Following User Says Thank You to churchx For This Useful Post: | Ultramaroon (10-25-2015) |
#44 | |
Drives: 2013 GBS BRZ Limited
For Rod bearings to fail it typically means abuse (high HP, or knocking) or oil starvation. So a pulley solution would not change the failure rates of those two failure modes. If we were experiencing MAIN bearing failures, then a fluid vs lightened vs OEM pulley could play a role in reducing the failures. |
#45 | |
#46 |
Drives: 2015 Subaru BRZ Limited
My car does vibrate a ton when I revv it up a lot. I would definitely consider this product. The reviewer took the time to look at it in a methodical manner which makes reading it up on things a whole lot easier. I think mayber the car hits a harmonic at 5k rpm, maybe.
| The Following User Says Thank You to Tekno Virus For This Useful Post: | chaoskaze (10-28-2015) |
#47 |
Is there an installation procedure for this product?
#48 |
Drives: Whiteout Scion FR-S
I would assume that it is no different than any other crank pulley. It would probably be a good idea to replace the retaining bolt and the o-ring with new parts at the same time. Try this thread:
Aftermarket Crank Pulley Install
My cars always dress formally. They all wear black tires.
| The Following User Says Thank You to Black Tire For This Useful Post: | Tekno Virus (11-19-2015) |
#49 |
Drives: 2015 Steel FR-S MT
Not only a good pairing with aftermarket cranks and built engines, but also a good pairing with lightened flywheels.
On the EJ's, lightened flywheels and lightweight crank pulleys used to eat up bearings like no tomorrow. Still a little sad that we didn't see the HP gains the F20/F22 motors got from these but then they do rev much higher.
17x9 RPF1 wrapped in 245/40 RE-71R = Mo Low Required
| The Following User Says Thank You to Naco For This Useful Post: | CSG Mike (11-19-2015) |
#50 | |
Engineering Student
Drives: Scion FR-S 2015
I also want to add that in any physics questions, pulley weight is neglected.
There’s no time to stop for gas, we’re already late
| Perrin Lightweight Crank Pulley (RED) | JarredH | Canada Classifieds | 1 | 08-12-2015 07:05 AM |
| Lightweight crank pulley | Vlady | Engine, Exhaust, Transmission | 112 | 01-09-2014 09:28 PM |
| Lightweight Crank Pulley | Vlady | Want-To-Buy Requests | 3 | 01-02-2014 11:31 AM |
| Perrin Lightweight Crank Pulley | protpibe | Engine, Exhaust, Bolt-Ons | 4 | 12-04-2013 07:46 PM |
| FS: AgencyPower Lightweight Crank Pulley | Firestorm_86 | Engine, Exhaust, Bolt-Ons | 0 | 11-22-2013 04:13 PM |
