Old 11-09-2015, 06:50 PM   #1
OBLCDio
Drives: 2013 Scion FRS 10 Series
Exhaust Work?
I'm looking to expand upon the Invidia catback I have on my FRS by adding an Invida Front Pipe, Tomei Overpipe, Tomei UEL Headers, and using Heatwrap to keep the oil pan safe. However I don't know where I'd get all of this work done properly. Any suggestions for those of us who don't live within two hours of a tuner shop? I'm in the Columbus area.
Thanks.
OBLCDio is offline   Reply With Quote
Old 11-09-2015, 06:51 PM   #2
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
Those are all easy to do yourself if you don't mind doing manual labor.
Other than that no idea.
Freeman is offline   Reply With Quote
Old 11-09-2015, 08:20 PM   #3
OBLCDio
If I had access to a lift and the proper tools? No. Wouldn't mind doing it. I'm sure I could do it, but I don't have either so I'm kinda stuck.
Old 11-09-2015, 08:23 PM   #4
MuseChaser
Feeling like thinking....
MuseChaser's Avatar
A low-profile floor jack and four jack stands, and Bob's your uncle. A creeper is icing on the cake. Compared to a real lift, of course, all other options completely suck.
Barry
MuseChaser is offline   Reply With Quote
Old 11-09-2015, 08:43 PM   #5
steve99
Drives: FT86
Thanks.
ceramic heat coating is better than heat wraps
Old 11-09-2015, 09:41 PM   #6
OBLCDio
Now is it safe to assume that this would be a "bonded" or "applied" coating to the metal?
Would a basic muffler shop know how to do this stuff? Or even my Dealer if I brought them the parts?
Old 11-09-2015, 09:48 PM   #7
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
I'd take the parts to be coated to a specific shop meant for that. As for doing the installation yourself, just rent the tools/ equipment, or purchase it as you may need it later. Especially if you get the mod bug like I did.
MS, CSCS, TSAC-F, CPT
Old 11-09-2015, 10:06 PM   #8
OBLCDio
What tools do I need? Like specifics besides the jack?
Old 11-09-2015, 10:27 PM   #9
Cole
Not a troll
Cole's Avatar
Wrenches and screwdrivers and shit.
Take a look at the DIY section, all your questions have an answer there.
Cole is offline   Reply With Quote
Old 11-09-2015, 11:05 PM   #10
Hostile_Kittens
Hostile_Kittens's Avatar
Drives: 2015 Subaru BRZ
http://www.jet-hot.com/
They're doing my header. $375 for a header and overpipe, inside and out.
Hostile_Kittens is offline   Reply With Quote
Old 11-09-2015, 11:06 PM   #11
weederr33
weederr33's Avatar
10mm, 14mm, 12mm, and uh... I believe those are the main sizes to take off the exhaust, and under panel if you're going after the headers. Wrenches or sockets work, but that depends on which piece you're changing.
Old 11-09-2015, 11:14 PM   #12
OBLCDio
Thanks. Will do.
Old 11-10-2015, 01:34 AM   #13
Thanks.
I'd suggest you check in with your local sub-forum for a referral.
Any good muffler/auto shop should be able to make the install.
Since you asked what tools you would need ...... I'd recommend you have a shop do the work.
Notten wrong with that, just drop off the car, go across the street for a breakfast sandwich, come back and have a cup of coffee and read a car magazine or the paper, pay and drive off.
OR, you can buy/borrow a jack, jack stands and some tools. Slide under there, on the cold concrete floor, twist off a couple of bolts, skin up your knuckles, bang up your elbows, worry about under/over tightening the bolts ...... then wonder why in the hell you didn't just have it done.
I've done it both ways ...... and found plan A to be more fun .....
jawn (11-10-2015), Ultramaroon (11-10-2015)
Old 11-10-2015, 01:46 AM   #14
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
I think you might have better luck here:
http://www.ft86club.com/forums/showthread.php?t=28832
But yeah, any exhaust shop should be able to do it.
jawn is offline   Reply With Quote
Exhaust work in the SF Peninsula sw20kosh Northern California 7 04-30-2014 04:08 PM
WORK Emotion Wheels ** Winter Promotion || Free WORK Lugs or WORK Caps ** RavSpec Wheels and Tires 18 12-10-2013 06:19 PM
FS: JDM Subaru Exhaust Tips (will work on F-RS i believe) awlllwa Engine, Exhaust, Bolt-Ons 8 04-05-2013 03:06 PM
Work Emotion CR Kiwami Bronze 18x8.5 +47 18x9.5 +38 (5x100) w/tires + Work lug nuts serial gixxer Wheels and Tires 41 03-29-2013 04:14 AM
