Old 11-09-2015, 05:53 PM   #1
celek
Resident Gear Head
celek's Avatar
Flow bench tested heads?
Has anyone bench tested these heads?
I need numbers, fixes.... INFO!!!
Or do I have to find someone to test mine.
Where to go?
celek is offline   Reply With Quote
Old 11-09-2015, 05:58 PM   #2
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
I think fullblown tested some... Hazy memory says it was 255cfm and when they ported then it was 305cfm?
It's in the description to their stage 2 head package.
http://fullblownmotorsports.com/full...2-head-package
Freeman is offline   Reply With Quote
Old 11-09-2015, 06:00 PM   #3
swarb
People who have done this rarely share the info as they are usually shops that paid money for the r&d.
You can search google for places to test in your area.
The Following 2 Users Say Thank You to swarb For This Useful Post:
celek (11-09-2015), CSG Mike (11-11-2015)
Old 11-09-2015, 06:05 PM   #4
celek
Resident Gear Head
celek's Avatar
I know this just trying to get some info. I spent an hour with TWM Induction on ITBs it all comes down to flow rates across the entire spectrum of the lift.
Old 11-09-2015, 07:16 PM   #5
Calum
That Guy
Drives: 2013 asphalt FRS MT
@Tim Radley has tested them.
Dig through his posts, there's not many, I can't remember if he posted numbers or not. IIRC, he ended up using epoxy to fill some areas in an effort to increase flow velocity.
The Following User Says Thank You to Calum For This Useful Post:
celek (11-09-2015)
Old 11-09-2015, 07:41 PM   #6
celek
Resident Gear Head
celek's Avatar
I messaged him on FB but its bed time for him
Old 11-11-2015, 10:16 AM   #7
celek
Resident Gear Head
celek's Avatar
Update, Local Technical College (OTC) in Cleveland for Auto Performance has a Flow Bench... Looks like I will be getting some good number's luckily I know someone on the board of directors there.
Old 11-11-2015, 10:48 AM   #8
Calum
That Guy
Is this going to cost you anything?
Old 11-11-2015, 11:00 AM   #9
Jeff@Racer X Fab
Drives: Subaru BRZ, Toyota MR2 Turbo
I have seen two sets of flow numbers on this forum. Both were right around 270 to 280 CFM intake and 170 to 180 CFM exhaust.
Tim, already posted the info:
Jeff@Racer X Fab is offline   Reply With Quote
The Following User Says Thank You to Jeff@Racer X Fab For This Useful Post:
celek (11-11-2015)
Old 11-11-2015, 11:14 AM   #10
celek
Resident Gear Head
celek's Avatar
Thats only 1 cylinder though the exhaust ports are goofy on this head. I want to know all of them
The Following User Says Thank You to celek For This Useful Post:
Hyper4mance2k (11-11-2015)
Old 11-11-2015, 10:25 PM   #11
CSG Mike
CSG Mike's Avatar
I have numbers for both stock and built heads. What exactly are you trying to get done?
Hawk77FT (11-11-2015)
Old 01-13-2016, 11:06 PM   #12
wizzo
Drives: 2014 Toyota 86
Hey everyone, was in touch with nastyportflow out of Malaysia. They have worked on FA20 heads, and had stock and ported heads on the flow bench.
At 28" testing cylinder 1:
Stock -> Intake=265.5 Exhaust=174.9
After port work -> Intake=294.2 Exhaust 211.5
Seem like stock s2k numbers which sounds good to me
wizzo is offline   Reply With Quote
Our Stage 2 E85 OTS map tested on stock car Shiv@Openflash Software Tuning 103 05-03-2019 07:41 PM
FS: gently tested TapTurn flasher scottmcphee Exterior Parts (Aero, Lighting, Etc.) 7 09-02-2013 11:14 PM
AVO Inlet Kit tested at Drift Office AVOturboworld Engine, Exhaust, Transmission 26 10-02-2012 04:21 PM
Scuderia Ferrari fires up V6 turbo on test bench quik1987 Other Vehicles & General Automotive Discussions 0 08-28-2012 06:31 PM
