Old 11-09-2015, 12:27 AM   #1
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Anyone taken apart the (BRZ) DRL's yet?
Anyone taken apart the BRZ DRL yet?
As the title states. Has anyone taken apart the BRZ's led daylight running lamps yet? Painted the insides? The only pictures I can find are of people that have put on smoke/yellow lens overlays.
Curious to know if they come apart like the headlamps.
Old 11-09-2015, 02:09 AM   #2
DIM
I know @Jive Turkey has.
DIM is offline   Reply With Quote
Old 11-09-2015, 03:16 AM   #3
aegisdrgn
aegisdrgn's Avatar
Drives: Scion FR-S 10 Series #2263
I think he means the bottom strip, not the boomerang?
aegisdrgn is offline   Reply With Quote
Old 11-09-2015, 05:55 AM   #4
tracerit
Drives: '13 SSM BRZ Limited 6MT
I wish there were an aftermarket LED strip that extends further and is just a straight line rather than the LED dots. For that Porsche Cayman look.
tracerit is offline   Reply With Quote
Old 11-09-2015, 10:32 PM   #5
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Correct Sir
Old 11-10-2015, 03:52 PM   #6
RedStickBRZ
Drives: 2013 world rally blue subaru brz
I took them apart when I pulled the bumper to blackout headlights/ add color changing headlights and demon eyes. I wanted to add rgb led strips to the drls so essentially they'd run as drls but I would have the ability to color match them with my halos. The lights are on a board and to it looked the only way to do it was to completely destroy the stock led board by either just sticking the rgb led strip to it and wiring that up or by pulling the board completely and just sticking the led strip in the openings left in the reflector. None of this was up to my standards as far as looking like it came that way so I decided against it
RedStickBRZ is offline   Reply With Quote
The Following User Says Thank You to RedStickBRZ For This Useful Post:
Kiske (11-11-2015)
Old 11-12-2015, 07:55 PM   #7
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
just paint them really well man...mine have been painted 2 years now and look mint, i also redid my headlights and did yellow blinkers this time around for a complete clean yellow look.
hope this helps:
photo of when i just did them:
more can be seen on my instagram @comrad
Jive Turkey is offline   Reply With Quote
The Following User Says Thank You to Jive Turkey For This Useful Post:
PandaSPUR (01-17-2016)
Old 11-14-2015, 01:16 AM   #8
akidnamedguiza
akidnamedguiza's Avatar
Drives: 2013 Subaru BRZ
hope this helps:
Let me start by saying beautiful car! Tastefully modded!
What did you use to make the turn signals look yellow? film or was it a spray?
akidnamedguiza is offline   Reply With Quote
Old 11-14-2015, 02:50 PM   #9
Jive Turkey
the tuna, no crust.
i used duplicolor metalcast yellow to paint the blinker and krylon fusion black paint for the rest of the headlight. metalcast is great if you want to paint and red out your tailights as well! can get it from autozone. be very careful though because if you put too many coats of yellow it goes from being hte color i have, to almost amber and you'll have to sand it down and start over (ask me how i know )
i tried to Lamin-X the DRL first but the countours are so tight it didn't stick after a few day and lifted off. Painting is really the only way to go, the trick is to wetsand and take your time and to make sure you have a very good UV clear coat on it so that it doesn't fade and chip to shit.
Thank you for the compliments, if you have any questions do not hesitate to ask!
Old 01-16-2016, 11:52 PM   #10
teehan
teehan's Avatar
Drives: 2015 WRB BRZ
Thinking about doing this to my BRZ. Have you noticed a change in the effectiveness of the highbeams/lowbeams? I love the look but would prefer not to compromise my lighting ability.
Thanks for the help! You have beautiful car!
teehan is offline   Reply With Quote
Old 01-17-2016, 12:12 AM   #11
ryoma
ryoma's Avatar
the DRL's will not affect your headlight output. if anything, it will just illuminate the foreground of your light output (the area closest to the bumper) if you have the always on module from diode dynamics. if you don't, the DRL's turn off when you have your lowbeams on.
Old 01-17-2016, 12:27 AM   #12
swarb
@Jive Turkey Did you paint from the inside or outside? Did you use clear coat? What kind?
Old 01-17-2016, 02:39 AM   #13
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
@Jive Turkey I kept staring at your car today knowing something was different other than the yellow fogs and DRLs. Couldn't figure out what at the time. Now I know lol, very nice!
Old 01-21-2016, 12:13 AM   #14
Jive Turkey
the tuna, no crust.
BRZ has bi-xenon lights. you aren't doing anything at all to mess with light output since you're not touching the projector.
the DRL's actually are quite yellow and very noticeable when its not daylight.
duplicolor metal cast with a UV resistant clear coat on top of that. make sure its UV safe and won't fade. then i just hit it with as many coats as i could afford while the car was down. the longer you let it cure between coats-the harder it will come out.
BE CAREFUL with the yellow paint though, its takes only one or two extra sprays to turn it from the right shade-to a darker more orange ugly shade. ask me how i know LOL
haha thanks man-it was pretty ugly when you saw it though...
