#337 |
/scion
Drives: '13 86 M/T
Thanks for the reply. I still like the OFT option and may choose to go about it in stages. Install OFT with e85 tune>buy ECA2>build fuel lines>and read e% off the Zeitronix gauge. Just to clarify, the ECA2 will work independent of a complete flex fuel kit with plumbing and plug n play harnesses, correct? Meaning I can run an ECA2 and wire it all up per Zeitronix instructions and still read e% .
#338 |
Drives: '13 SSM BRZ Limited 6MT
I'm looking to adjust the cranking values but according to RomRiader I have more tables than what I've seen in the forum. I have Cranking Fuel IPW A to J, whereas all the pictures I"ve seen are from A to E only. Do I change all the tables on my end or just tables A to E?
#339 | |
Drives: FT86
just make sure no weird values in the tables. you could up the vales in the remaining tables by the same percentage increases over stock if your kean. |
| The Following User Says Thank You to steve99 For This Useful Post: | tracerit (11-06-2015) |
#340 |
Drives: Subaru BRZ Limited
How often are you guys changing your oil and which type of oil are you running with E85? I've heard instead of 3-5k miles we should be changing the oil closer to 2k when running E85
#341 |
Drives: FT86
use an oil thats SN or GF5 rated or one thats specifly states its E85 compateble. You can half the change interval if you want but if your NA and your not running rich and getting fuel dilution you can likely go the normal intervals with an e85 compatable oil
| The Following User Says Thank You to steve99 For This Useful Post: | JDsThatGuy (11-08-2015) |
#342 |
Drives: Scion FRS
An alternative to messing with the tables for cold start is to crank once for a short interval then turn off and wait 3-4 seconds and crank again. The fuel injected at the port in the first cranking will evaporate enough to start the car at the second crank.
#343 | |
Drives: FT86
High E content guys can add a bit of petrol though, but editing the tables is a better option . |
#344 |
Drives: Asphalt FR-S MT
And on a side note, if I remember correctly, we are maxing out power at like E50-60 or something so no biggie not getting exactly E85. Anything extra is just gravy
#345 |
Drives: 2014 Subaru BRZ
Hi Steve,
First time posting and thank you for your information. What is the difference between the OFT branch and Alpha branch on Github when flashing OFT or modified OFT tunes? I am using the E85 Stage 2 maps but will be editing my map to copy over the new cranking values from Wayno's thread. I don't remember where I got the definition file when I was tuning last time. Alpha branch definition for B00C: https://github.com/TD-D/SubaruDefs/b...Z/ZA1JB00C.xml OFT branch definition for B00C: https://github.com/TD-D/SubaruDefs/b...C/ZA1JB00C.xml Everything in these two files is the same except for the addition of two tables in the OFT branch's file. Their names are 1. Engine Load Limit B Maximum (RPM) and 2. Engine Load Limit C (Maximum) (RPM). I suspect that I should be using the definition from the OFT branch given that there is a patch for LC/FFS, but I do recall using the definition from the Alpha branch when I flashed and still having the LC/FFS feature when driving. Diff: https://gist.github.com/perryh/cc710783b829eb698fb4 Thank you! |
#346 | |
Drives: FT86
unless you want to edit those two specific additional tables it does not matter. always check some tables in the rom before you flash and make sure the values and axis look ok, also if you going to edit lc\ffs make sure the rom has the patch see the romraider tips link its still valid for ecuflash. ignore this weird icon thing cannot delete it on my phone
#347 | |
Drives: Scion FRS
Although most OEMs launching flex fuel vehicles can exploit the octane boost of E85 no one does because of the risk due to max rise of pressure being higher with engine running E85 at WOT. So when they calibrate spark they make sure that the peak pressures seen are reasonable to what is obtained on premium fuel. This is because most hardware design is done to certain specification and in most cases it is limited to the pressures and temperatures that would be normally seen using regular gas. The durability team will normally not allow the E85 calibration team to reach its full potential since the HW in most cases could fail. It appears that Toyota/Subaru might have intentionally strengthened the GT86 platform expecting mods. But only time will tell. |
#348 | |
Drives: Scion FRS
In our cases this might not be a big deal because as you said E50-60 is good enough and E85 is a bonus |
#349 |
Love using E85 so far. Propel in the bay area offers a gallon for $2.20-2.30 currently.
#350 |
Drives: 2013 Scion FRS
e85
I did this correctly as you have stated but after about 20 miles on e85 tune driving under 3500 rpm i get check engine light and p0171 too lean code. also after about 40 miles the ltft is still around 35% and hasnt gone down. I currently have 02 spacers on my headers could this be causing the problem? i read that it is either 02 sensor/ maf sensor failure or leak in exhaust/intake? but could it be my spacers?
| Stock FR-S Tune Just Done | Zach3794 | Engine, Exhaust, Transmission | 67 | 11-05-2017 02:01 PM |
| stock BR-Z, much detonation during shifts: tune? | elefunkd | Engine, Exhaust, Transmission | 69 | 07-26-2013 04:20 PM |
| Anyone have a stock tune from Visconti? | Bleevin | CANADA | 3 | 07-03-2013 01:01 AM |
| My Initial (all stock) BRZedit tune | mad_sb | Engine, Exhaust, Transmission | 6 | 02-16-2013 12:20 PM |
| Save stock tune with ecutek? | gdrider77 | Engine, Exhaust, Transmission | 7 | 01-06-2013 12:50 AM |
