Old 11-07-2015, 01:03 PM   #15
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
Post
Originally Posted by mushyho View Post
I need some help regarding these fogs. Just received them last week. Tried to install them during the weekend but the notches dont line up with the plugs compared to the OE bulb. Am I doing something wrong?
Haven't purchased these yet, but plan to eventually get the yellow XML2. Did you go yellow?
Chad86 is offline   Reply With Quote
Old 11-07-2015, 02:00 PM   #16
Ammunition
Ammunition's Avatar
Drives: 2014 Scion FR-S
I've had these fog lights installed for over a year now, and I've been very happy with them. The installation was very easy, straight-forward, plug-and-play.
You'll probably have to contact Didoe Dynamics if you're having an issue. I have the Diode Dynamics fog light kit for my FR-S, which utilizes an H11 bulb - IIRC the OEM fog light kit utilizes a different bulb size? I believe the XML2 bulbs only come in an H11 sizing, but I could be wrong as it's been awhile since I purchased mine - but that is what mine are, and therefore they might not be compatible with your OEM kit.
Ammunition is offline   Reply With Quote
The Following User Says Thank You to Ammunition For This Useful Post:
Chad86 (11-07-2015)
Old 11-28-2015, 01:00 AM   #17
Chad86
Chad86's Avatar
Drives: Toyota GT86
@Diode Dynamics can you confirm if there are any fitment issues on the FR-S or any problems with cutoff on the stock housing.
What is the color temp on the yellow version?
Thanks.
Old 12-02-2015, 03:00 PM   #18
demasrv
demasrv's Avatar
Drives: 2013 Rally Blue BRZ
Smile I just installed these in yellow!
These were super easy to install and they are VERY bright. The ones I purchased are yellow. I had drunk-ordered them and wasn't sure if they would be worth the $120 but the quality is outstanding. Thanks @Diode Dynamics for a great product. I'll be purchasing the kit to replace interior lights.
I would suggest that when installing, be careful with the plastic clips on the bulb housing. On one of my lights one of the clips broke so only one clip is holding it in. I was afraid this wouldn't be good enough but after hours of spirited driving they're holding just fine.
demasrv is offline   Reply With Quote
The Following User Says Thank You to demasrv For This Useful Post:
Chad86 (12-02-2015)
Old 12-02-2015, 03:30 PM   #19
jelly
Drives: looking for one.. :(
I would suggest that when installing, be careful with the plastic clips on the bub housing. On one of my lights one of the clips broke so only one clip is holding it in. I was afraid this wouldn't be good enough but after hours of spirited driving they're holding just fine.
So those are the yellow LEDs? The pictures and comments for the yellow made it seem like a very green light. In your photos it looks pretty pale yellow though. Thanks for posting!
Sent from my SM-N910W8 using Tapatalk
jelly is offline   Reply With Quote
Old 12-02-2015, 04:16 PM   #20
demasrv
demasrv's Avatar
Yup! Those are the yellows and they definitely look yellow. Really the pictures don't do justice to how bright these are. They look great.
Chad86 (12-02-2015)
Old 05-15-2016, 01:40 PM   #21
Alltezza
Alltezza's Avatar
Drives: WRB Limited BRZ
Don't mean to bring back a dead thread but I'm not really digging the yellow LEDs because they look greenish. I want that GOLD yellow JDM look.
Could I just grab a pair of 5K the pure white one and put a tint on them to make it as gold yellow as possible? Has anyone tried that?
Alltezza is offline   Reply With Quote
Old 05-15-2016, 02:34 PM   #22
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
It's going to be tough to get a perfect yellow from an LED, you'd have to tint the lens yellow then use a bright 5k white one .
Old 05-15-2016, 08:28 PM   #23
Ammunition
Ammunition's Avatar
I doubt that an overlay on it's own would produce the color that you're seeking, and it may interfere with the light output.
If you want a golden 'JDM' look, then you'll probably want to purchase a JDM bulb; if you're a quantity over quality type of person, then you'll probably need to go with another solution such as the film you suggested, as importing a product can be expensive.
Before I changed the look of my lighting, I also wanted a brilliant golden fog light bulb. I ended up finding a Japanese brand that seemed to be what I wanted, and I was able to order it through the help of Japanparts as they are willing to make a purchase for you (through a Japanese website, shop, etc - you provide them with the link of the exact item - they charge a small fee for this service, and will do international shipping; the caveat being that if anything is wrong, defective, or undesirable about the item - they can't help you as they are really just facilitating the purchasing process for you.)
Here is an image of the exact product I bought - http://i.imgur.com/qXd9rDh.jpg
Here is what it looked like on my car when I had them installed -
http://i.imgur.com/Hhx7jpJ.jpg
http://i.imgur.com/i2pc0LO.jpg
They were very good bulbs and I was very happy with them, despite the fact that they ended up being a bit expensive. This brand in particular even included a tiny allen key that allowed you to rotate the LED for optimal light output, instead of the being stuck with the LED chips on the side, sitting at a random angle inside of the fog light housing (this was something that always bothered me about the Diode Dynamics bulbs that later switched to.)
So yes - you do have options to achieve the look that you want, if it's worth it to you (quality will vary from brand to brand, but for reference the bulbs that I had were rated at 2500K.)
Old 05-15-2016, 09:06 PM   #24
Alltezza
Alltezza's Avatar
Damn thats EXACTLY the color I want....
The only other option I looked at but its very expensive because the BRZ's fog light housing needs to be changed to glass.
Are the 3000K HID conversion, but I honestly don't know how it would work since the bulbs are PSX24W.....would I need a PSX24W to H11 converter/adaptor or something
Old 05-15-2016, 09:44 PM   #25
Ammunition
Ammunition's Avatar
The same company (Junack) also makes that same bulb in a PSX24W - (here is a pic for reference - http://cdn.mkimg.carview.co.jp/minka...t=300133d89af8)
I just purchased the H11 version because I had the Diode Dynamics fog light kit, which utilizes an H11 bulb instead of the standard PSX24W - should be plug and play.
Old 05-16-2016, 12:29 AM   #26
ryoma
ryoma's Avatar
you might also be interested in the TRS fog lights: https://www.theretrofitsource.com/mo...1#.VzlMJWgrKHs
add $15 for the yellow tint. it's the whole housing so you'll get a pretty nice light output since the lens are made for the bulb.
Old 05-16-2016, 11:03 AM   #27
Diode Dynamics
Diode Dynamics's Avatar
We offer a direct replacement LED housing for the BRZ as well:
Nick C.
John C.
Diode Dynamics
Old 10-14-2016, 07:08 PM   #28
j_motion
Drives: 14 BRZ Red premium
Does th DRL on the brz turn off the moment you turn on the fog light ?
j_motion is offline   Reply With Quote
Fog Light Install Diode Dynamics snakey Cosmetic Modification (Interior/Exterior/Lighting) 16 12-09-2015 04:34 PM
Diode Dynamics Reverse LED review BlackyRose Cosmetic Modification (Interior/Exterior/Lighting) 0 09-03-2014 09:55 AM
Diode Dynamics Review Chimera User/Vendor/Sponsor Reviews, Feedback, Comments 9 05-19-2014 10:18 PM
Diode Dynamics Stage 2 LED DRL Review BlackyRose Cosmetic Modification (Interior/Exterior/Lighting) 1 05-14-2014 10:52 AM
DIODE DYNAMICS ACRYLIC REVIEW BlackyRose Cosmetic Modification (Interior/Exterior/Lighting) 6 07-04-2013 10:42 AM
