Old 11-05-2015, 11:42 AM   #1
cmihaylov
Changing climate control to Celsius
I tried searching for this but couldn't find an answer. If there is a thread on this please excuse me. So my question is, is there a way to change the climate control on the BRZ Limited to read in Celsius instead of Fahrenheit (like on all the other BRZs not sold in the US). Could this be done through TechStream?
Thank you!
cmihaylov is offline   Reply With Quote
The Following User Says Thank You to cmihaylov For This Useful Post:
funwheeldrive (11-05-2015)
Old 11-05-2015, 04:17 PM   #2
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
I think its based on the region the twins are sold. Just like how we get the mph and others receive kmh. Pretty sure you would have to change the whole unit.
Old 11-05-2015, 04:28 PM   #3
Ramn
Ramn's Avatar
Drives: 2015 GTI
You can press a button to change between Mi and Km.
I think you can change ECU settings to get this done; I'm still searching.
Ramn is offline   Reply With Quote
Old 11-05-2015, 04:33 PM   #4
NyC Zn6
NyC Zn6's Avatar
I was referring to the analog gauge not the digital.
Old 11-05-2015, 04:42 PM   #5
kch
Senior Misanthrope
kch's Avatar
...he was specifically asking about the dual control on the BRZ limited, so...
The Following User Says Thank You to kch For This Useful Post:
mav1178 (11-05-2015)
Old 11-05-2015, 05:58 PM   #6
P3tras
Drives: Subaru BRZ '13 WRB
You need to change instrumental cluster (dash) if you wish to have measurements in Celsius (been there, done that). It is also possible to reflash your current cluster (so it would have miles, but Celsius on climate controls). Techstream cannot help in this case.
P3tras is offline   Reply With Quote
Old 11-05-2015, 06:42 PM   #7
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
BRZ Limited = dual digital climate control.
There is nothing analog about what is on the BRZ Limited.
Source: I own one.
Edit: what @cmihaylov wants is this:
-alex
Old 11-05-2015, 06:45 PM   #8
NyC Zn6
NyC Zn6's Avatar
Source: I own one.
-alex
i have dual climate also l...i was referring to celsius being regional...If we had celsius in our cars we would also have kmh analog speedometer gauges. He would have to order one from Japan or a member overseas.
Old 11-05-2015, 07:42 PM   #9
cmihaylov
Why wouldn't they make an option to switch between the two? It's weird because I can see the little dot and the third digit as shown in the pictures above. I guess it is what it is then.
Old 11-06-2015, 06:04 AM   #10
azian_advanced
*****istrator
azian_advanced's Avatar
Drives: 2013 Scion FR-S 10-Series M/T
Order one from a Canadian wrecking yard.
SC10N FR-S #435 of 2500
azian_advanced is offline   Reply With Quote
Old 11-06-2015, 06:10 AM   #11
LWAA
Drives: Subaru BRZ
What good would that do? I'm in Canada and have °c in mine and km for the speed.
Sent from my iPhone
LWAA is offline   Reply With Quote
Old 11-06-2015, 09:51 AM   #12
azian_advanced
*****istrator
Sent from my iPhone
That was so the OP to have his climate control display in Celsius, instead of in Fahrenheit.
I also don't recall seeing it an option in TechStream.
Old 11-06-2015, 11:03 AM   #13
Shedd22
BAMF
Shedd22's Avatar
Drives: 2014 SWP BRZ
Not sure if it was said since I didn't read all the comments but reset the ECU (unplug battery for a bit). Upon restart it should ask what units you want everything in.
Shedd22 is offline   Reply With Quote
Old 11-06-2015, 12:58 PM   #14
cmihaylov
Interesting. Going to try this today. Thank you!
Anybody Use the Climate Control? carma143 BRZ First-Gen (2012+) — General Topics 32 11-07-2017 07:24 PM
FS: BRZ Dual Climate Control pleong Interior Parts (Incl. Lighting) 0 10-31-2015 04:18 PM
Climate Control Magiclow Cosmetic Modification (Interior/Exterior/Lighting) 3 10-05-2014 05:46 AM
Is there a way to turn on climate control without the AC being on? chenshuo BRZ First-Gen (2012+) — General Topics 48 01-27-2014 01:12 PM
Climate control Panel for the FRS. Mrqb22 Electronics | Audio | NAV | Infotainment 6 02-13-2013 08:03 PM
