Old 09-07-2015, 01:48 PM   #43
neilr
Drives: 2018 Cayman, 2013 FR-S
Originally Posted by GrimmSpeed View Post
GrimmSpeed DIY Guide Series
Exhaust System/Exhaust Manifold Removal and Replacement
Updated 6/7/12
8. Next, we’ll remove the muffler from the car. The muffler is held on by two (2) 14mm bolts and four (4) rubber hangers, one on each corner of the muffler. Start by removing the bolts and then remove the muffler from its hangers, one at a time. I find that twisting the rubber hanger off of the muffler is the best way to get it started. Be ready when you’ve got it loose, as the muffler is a bit heavy.
Quick question about the muffler connection to the midpipe. Is there supposed to be a gasket between the two? I'm reverting to stock, and didn't install the replacement exhaust myself, so I don't know how it was originally setup. If there's not supposed to be a gasket, isn't leaking a concern?
neilr is offline   Reply With Quote
Old 09-07-2015, 02:04 PM   #44
phobos512
phobos512's Avatar
Drives: 2014 FR-S 6MT Whiteout
Yes, there is a gasket that goes in there.
Matt | '14 FR-S 6MT Whiteout | '13 Sonata Hybrid | '11 CBR1000RR
phobos512 is offline   Reply With Quote
Old 09-11-2015, 03:16 PM   #45
itsjustdavep
itsjustdavep's Avatar
Drives: Asphalt Scion FR-S
question about the muffler to midpipe bolts... lol. i accidentally stripped the head on the bottom one... can i just pick up areplacement at walmart or lowes?
2013 Asphalt HRI Tuned-K&N DropIn-Tomei UEL-Tomei OP-Invidia FP-Nameless Muffled Trackpipe...and corn
itsjustdavep is offline   Reply With Quote
Old 09-11-2015, 04:33 PM   #46
phobos512
phobos512's Avatar
Get some Grade 5 or 8 machine bolts from Lowes or Fastenal. I had to hacksaw mine apart when I put the Nameless muffled track pipe on because the stock bolts rusted so much.
Old 09-12-2015, 10:28 PM   #47
isolato
Drives: 2015 Subaru BRZ; 2001 Mazda Miata
Talking Great DIY!
Updated 6/7/12
Click here to download this DIY in a printable .PDF format
- Matt
This DIY was super-helpful for me last week when I installed a new header. Thanks a bunch!
isolato is offline   Reply With Quote
Old 09-13-2015, 11:50 PM   #48
itsjustdavep
i did the same thing, with the same part. i got the old bolt off but i do need to replace it here soon
Old 11-04-2015, 11:54 PM   #49
Gutterboy
Drives: 2013 frs; 1988 porsche 944s - > 948
quick question on aftermarket overpipe
any possibility of re-using the factory heat sheilds on an aftermarket overpipe?
seems like there would be some heat on the aftermarket overpipe to try to mitigate but maybe its larger size makes this impossible?
thanks in advance
Gutterboy is offline   Reply With Quote
Old 11-05-2015, 09:07 AM   #50
phobos512
phobos512's Avatar
thanks in advance
No, they're quite specific to the bends and bobs of the stock piece. Most aftermarket parts are also larger diameter.
Old 11-05-2015, 01:50 PM   #51
kch
Senior Misanthrope
kch's Avatar
thanks in advance
If you're concerned about heat, a ceramic coating would be your best alternative.
Old 11-05-2015, 09:25 PM   #52
Gutterboy
This all makes sense that those heat shields can't be Re used but what performance could be sacrificed by presenting a source of heat with a bigger overpipe. From what I have seen there isn't much gains in an overpipe swap, the big win is in the header. Could the be any truth to having best performance with stock overpipe and heat shield with after market header to prevent heat leaching that would be presented from an aftermarket overpipe?
Just asking for discussion and experience here
Old 11-11-2015, 10:30 PM   #53
AznKirby
Are you 20/20?
AznKirby's Avatar
Drives: Hopes and dreams
Thanks for this! It helped a lot, although install wasn't that hard. Heh.
2014 FR-S Monogram
2005 Acura RSX Type-S
IG: @MonKehC
Exhaust tip removal Draco-REX Cosmetic Modification (Interior/Exterior/Lighting) 97 05-27-2017 06:50 PM
T1R exhaust for the FRS/BRZ ! AJ PwR Engine, Exhaust, Transmission 57 06-22-2013 11:39 PM
AVO Exhaust Blaaaack-BRZ Engine, Exhaust, Transmission 22 10-17-2012 12:28 AM
HKS Exhaust 01s0uljah Engine, Exhaust, Transmission 1 05-18-2012 10:15 AM
Exhaust system: dual or single KiingDavid Engine, Exhaust, Transmission 162 05-04-2012 02:33 AM
