Old 11-04-2015, 03:40 PM   #3025
BRZ'13
BRZ'13's Avatar
Drives: subaru
Originally Posted by SPCorBUST View Post
The gains are with e85. It's a requirement along with a tune, I think. My dyno is 370, my 91 pump numbers were 290. (I think, I don't have it in front of me) I'm assuming that 93/94 would be marginally better.
Sent from my SM-G925T using Tapatalk
Ah i see. Ya i saw your dyno. Must pull like crazy. You had 290 on hbp with 91? Thats amazing. Im at 255 on 94 with the standard pulley. No e85 at pump here but you can buy drums of it
BRZ'13 is offline   Reply With Quote
Old 11-04-2015, 05:02 PM   #3026
SPCorBUST
SPCorBUST's Avatar
I had 275whp on 91 before the HBP, so the 91 gains were slim even with a tune. (~15whp) I think it was pulling a lot of timing up top, consequence of CA piss water.
If you can get away with getting drums to your place, I'd say do it. IMO the additional ~100whp is worth it. Run around making roughly the same horsepower as someone with a C38, but with the peace of mind that you're doing it with 11.5 psi instead of 15. Effects are marginal after E60 so you could blend it a bit to make it last longer, and I'm not sure about near you but its something like $2.40 a gallon near me.
Yes, it pulls like crazy. The car is just outright nasty now, but I think there's still a tad more left on the table. I'll be switching some things up to explore that soon though.
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
The Following 2 Users Say Thank You to SPCorBUST For This Useful Post:
BRZ'13 (11-04-2015), CSG Mike (11-04-2015)
Old 11-04-2015, 05:46 PM   #3027
CSG Mike
CSG Mike's Avatar
I really, really do not recommend running the high boost pulley with anything less than race fuel or Ethanol.
There are better ways to make more power, e.g. a header.
BRZ'13 (11-04-2015)
Old 11-04-2015, 09:58 PM   #3028
Jmonty
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
Originally Posted by Jmonty View Post
I seem to be getting more of a belt whine at or near idle? not sure what is going on?
Any thoughts @CSG Mike?
Jmonty is offline   Reply With Quote
Old 11-04-2015, 11:03 PM   #3029
BRZ'13
BRZ'13's Avatar
Drives: subaru
Would running 94 & ~105+ through flex fuel be ok? I dont want to run race fuel or e85 non stop as its crazy expensive here.
Old 11-05-2015, 01:38 PM   #3030
CSG Mike
CSG Mike's Avatar
Belt whine? You shouldn't ever be getting belt whine unless you have really worn (really, really old) belt that is stretched from age.
If you're local, I'd just tell you to stop by CSG so someone can take a quick look and listen to your car. I'd recommend you compare with other locals that have the kit, or check with your installer; they'll be able to best guide you.
Jmonty (11-05-2015)
Old 11-05-2015, 01:39 PM   #3031
CSG Mike
CSG Mike's Avatar
Yes, but if you're not running Ethanol, there's no reason to get a Flex Fuel kit. The Flex Fuel kits are only there to read ethanol content of the fuel.
BRZ'13 (11-05-2015)
Old 11-05-2015, 01:47 PM   #3032
Jmonty
Not Local in So Cal but I will check with the installer and get his thoughts it maybe just a tad bit loader?? It is a bit cooler
Old 11-05-2015, 02:32 PM   #3033
Xiao Li
Xiao Li's Avatar
Drives: '14 BRZ, '01 S2K
I had a loud whine during idle as well and rotrex is sending me a replacement. Hopefully this isn't the case for you but you can check out my video to compare if you'd like.
Xiao Li is offline   Reply With Quote
The Following User Says Thank You to Xiao Li For This Useful Post:
Jmonty (11-06-2015)
Old 11-05-2015, 03:03 PM   #3034
BRZ'13
BRZ'13's Avatar
Drives: subaru
Ah i see. For some reason i thought flex fuel adjusts the power/timing to the ethanol content currently being run through the system since its fairly inconsistent from the pumps.
Old 11-05-2015, 04:43 PM   #3035
CSG Mike
CSG Mike's Avatar
The Flex Fuel kit provides information to the ECU; if you have an appropriate tune, the ECU can then use that information to make adjustments.
Old 11-06-2015, 01:07 PM   #3036
Jmonty
It does sound something like that, need to get into my tuner
Old 11-06-2015, 01:23 PM   #3037
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Just curious, when did you order yours?
Jmonty and I ordered ours not too far off from each other and both have the noise.
The Following User Says Thank You to Andrew025 For This Useful Post:
Jmonty (11-06-2015)
Old 11-06-2015, 09:34 PM   #3038
BRZ'13
BRZ'13's Avatar
Drives: subaru
Anyone have hesitation problems around 3-4k rpm? Under light/moderate throttle i notice a very noticiable hesitation/stumble. Notice it most when car is cold
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
