Old 11-03-2015, 01:22 PM   #15
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
I will be switching all my studs when I get my new wheels. 17x9 +42. Hoping the ARP don't stick out too far. Any open ended lugs that look good and wont strip the ARP's?
Instagram: trevor.parque
Old 11-03-2015, 03:45 PM   #16
Gear_One_Performance
Gear_One_Performance's Avatar
Drives: 2014 BRZ SCCA STU endurance car
Kics makes a decent looking lug nut for that, as far as stripping the arp's we haven't had issues with the arps stripping on any open ended nut.
Gear_One_Performance is offline   Reply With Quote
Old 11-03-2015, 10:28 PM   #17
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Any lug nut can strip even ARP studs if you leave the threads contaminated.
When running open lug nuts, you should take care to clean the threads with a cloth towel at least once every 3 months or so.
-alex
Old 11-09-2015, 09:07 AM   #18
liquidsky44
liquidsky44's Avatar
Drives: AVO Turbo Subaru BRZ / Subaru WRX
Does anybody know what is the largest spacer i can run with the ARP studs?
AVO Turbo|Essex AP Sprint Kit|AVO Overpipe|HKS Hi-Power Spec L Catback|Cusco Engine Mounts|Whiteline Bushings|KW Clubsport|Defi Advance ZD|AEM Wideband Failsafe Gauge|Greddy ProFec Boost Controller|Tomei 2Way LSD|AEM Water/Meth Kit|PBM Angle Kit + Kunckles|Flatwell LCA|HKS Oil Cooler|Greddy High Cap. Diff Cooler|Sard ATF Oil Cooler|CSF Radiator|
liquidsky44 is offline   Reply With Quote
Old 11-09-2015, 10:07 AM   #19
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
Much larger than OEM thats for sure.
'13 WRB BRZ ~470whp // Instagram // YouTube
BRZoomTX is offline   Reply With Quote
Old 11-09-2015, 06:50 PM   #20
8R6
8R6's Avatar
Drives: FRS
i wouldnt go larger than 25mm spacers
8R6 is offline   Reply With Quote
The Following User Says Thank You to 8R6 For This Useful Post:
liquidsky44 (11-10-2015)
A warning about wheel studs post_break Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 41 05-05-2015 03:07 PM
WTB: ARP extended wheel studs mikep Canada Classifieds 2 05-22-2014 01:00 PM
non-extended wheel studs BadCompany235 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 05-14-2013 08:02 AM
broken wheel studs Matt Andrews Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 11-06-2012 12:47 AM
Small wheel studs PrinzJ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 10-10-2012 04:47 PM
