Old 10-18-2015, 12:39 AM   #141
retrofit
Drives: Toyota 86
Originally Posted by xwd View Post
Standard pulley?
Edit (I'm making a correction):
I've measured the pulley and it is 95mm so that would make it the standard pulley as mentioned further above.
How much boost is that around 8PSI?
Don't know the exact boost figures but wouldn't imagine anything high since Harrop are selling this as a reliable/safe kit.
retrofit is offline   Reply With Quote
Old 10-18-2015, 12:52 AM   #142
retrofit
Drives: Toyota 86
Originally Posted by kbye View Post
@retrofit do you mind taking some pictures of the water pump location? Where would you check the coolant levels? I don't see an overflow bottle in any pictures. tia
There's no overflow bottle in this kit.
I was told by Harrop the coolant is filled by undoing the two bolts circled in green in one of the photos below.
The water pump seems to be hidden quite well, I've taken a photo of where I think it is roughly located (i.e. where the coolant line runs down to the heat exchanger).
The Following 2 Users Say Thank You to retrofit For This Useful Post:
kbye (10-18-2015), SPCorBUST (10-18-2015)
Old 11-03-2015, 04:51 AM   #143
86 South Africa
POWER!!!!!!!!!!!!!!!!!!!!
Drives: White Toyota 86 (Scion FRs)
Originally Posted by jiaim View Post
From Harrop's FB :
New sun rising // pricing and pre-orders launch next week //
Harrop vs Edelbrock here we come
This is what I'm waiting to see... I am sure they will be quite similar in terms of peak power and torque - so it will come down to the tuning options versus price (and maybe a little brand favouritism)!... and for me... shipping cos we don't have Harrop dealers locally. (there is an edelbrock guy here).
86 South Africa is offline   Reply With Quote
Old 11-04-2015, 04:51 AM   #144
86 South Africa
Originally Posted by Blood View Post
Did you happen to get boost pressure numbers for each of the pulleys? I sent them an email about it this past week but haven't received a reply.
Wanna share the shipping costs?
(Are there import duties etc to the States? We have to add 20% here )
Old 11-05-2015, 10:07 AM   #145
xwd
The shipping cost to the US was about $200 from what they told me.
I'm not sure if duty fees would apply to it in the US or not. If it did most duty fees in the US are fairly low, like 2-3%.
The Following User Says Thank You to xwd For This Useful Post:
86 South Africa (04-06-2016)
Old 11-20-2015, 08:49 PM   #146
Blood
Drives: 2018 STI
I had this kit installed on my car a couple weeks ago by @moto-mike
I opted for the 90mm pulley (5mm smaller than stock) which runs ~10 psi. My car has an AT and the following mods: P&L catted EL header, Perrin overpipe, Perrin catted frontpipe, Perrin catback, Perrin drop-in filter. Along with the supercharger I had a Perrin oil cooler, Radium PCV side oil catch can and the moto-east flex fuel kit installed.
It made 270 whp on 93 octane pump gas (3rd gear pull) and 291 whp on E70 (4th gear pull).
Blood is offline   Reply With Quote
The Following 8 Users Say Thank You to Blood For This Useful Post:
CxG (04-18-2016), DocWalt (03-30-2016), Freeman (11-20-2015), Irace86 (07-22-2016), retrofit (11-20-2015), stoked_on_spool (11-30-2015), Toyota86.ir (02-09-2016), Xero-Limit (11-20-2015)
Old 11-20-2015, 08:51 PM   #147
retrofit
Drives: Toyota 86
Nice to see another owner
Old 11-20-2015, 08:54 PM   #148
retrofit
Drives: Toyota 86
Btw, what strut bar are you using?
Old 11-20-2015, 09:01 PM   #149
Blood
Drives: 2018 STI
It is a Cusco Type OS. There's still a decent amount of space (1.5 inches or so) between the highest point of the blower and the bottom of the strut tower bar.
The Following 2 Users Say Thank You to Blood For This Useful Post:
CxG (04-18-2016), retrofit (11-20-2015)
Old 11-20-2015, 09:38 PM   #150
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Man, that kit mounts low compared to my Cossy.
MS, CSCS, TSAC-F, CPT
Old 11-20-2015, 10:49 PM   #151
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
After driving the car above with this kit, I have to say it was quite impressive for pump gas, and even better on e85.
We are in the process of importing the kit and will have it added to the online store in not too long. While many of the SC kits out there are good in their own right, this setup is pretty unique and has a lot of good points that you'd only appreciate when you're working on it (uses stock airbox, easy to assemble, dual laminova cores...) For the price its at given today's exchange rate, it is very competitive with Edelbrock and the rest.
Xero-Limit is offline   Reply With Quote
The Following 5 Users Say Thank You to Xero-Limit For This Useful Post:
86 South Africa (04-06-2016), ATL BRZ (11-23-2015), Calum (11-21-2015), CxG (04-18-2016), retrofit (11-24-2015)
Old 11-20-2015, 11:01 PM   #152
FT&6
FT&6's Avatar
Drives: FRS Raven 6AT
OH MAN! Def looking forward to this kit. That flat curve is just .
FT&6 is offline   Reply With Quote
Old 11-22-2015, 03:21 PM   #153
xwd
Looks clean didn't know they were using Laminova cores instead of traditional AWIC cores. Keeps the packaging quite a bit smaller.
Old 11-22-2015, 09:31 PM   #154
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
Originally Posted by calmtigers View Post
What wing is that on their car??
I was wondering the same: http://www.topstage.com/product-category/toyota/
The Following User Says Thank You to switchlanez For This Useful Post:
calmtigers (11-22-2015)
Color difference between Satin White Pearl (Pre-2015) and Halo White (Post-2015)? LucidMomentum Scion FR-S / Toyota 86 GT86 General Forum 3 10-15-2014 11:29 AM
To build something better in our own self image Rocket.BRZ Off-Topic Lounge [WARNING: NO POLITICS] 29 07-07-2014 04:56 PM
Nissan to enter 2015 24 Hours of Le Mans + 2015 FIA WEC mav1178 Other Vehicles & General Automotive Discussions 1 05-23-2014 10:47 PM
looking for silhouette frs image subaruferrucci FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 0 01-29-2013 06:00 PM
Image resizing blalor Site Announcements / Questions / Issues 28 11-03-2012 08:46 PM
