#715 | |
Drives: '13 BRZ
Maybe I can rig a thermometer setup; air temp directly by the fender vent and air temp somewhere else outside of the car which doesn't see direct air flow. I have no idea how I'd manage something like that to be accurate, but I think that is going to be the only real test. |
#716 |
Drives: Turbo BRZ Limited 6MT
Very curious to see what your custom grille looks like. I wish my car didn't get to 215F coolant just cruising on the freeway when it's hotter than 95 out but it's a street car and I can't have the crash beam visible like that
#717 |
Drives: 2013 FR-S Whiteout MT
Paint the bar black and it will blend right in. No one will notice it
When in doubt, throttle out!
#719 |
Junior
Drives: a car
Can we get that beatrush skid plate stickied? Because hot* damn thats alot cheaper than a vented hood.
No pun intended*
#720 |
Some say.....
Drives: 2007 Subaru Impreza 2.5i
I don't remember who did it or where the thread is, but I swear that someone had done that themselves to the OE skid pan.
#721 |
Drives: FR-S black. Buell XB12s 25th anniv.
I was just planning on putting a couple extra holes in the oem pan. Does the vented one actually pull that much more air out? As much as a vented hood would?
He who shall be last shall be sideways and smiling
#722 |
Drives: 22RE, FA20, 4G63
#723 |
Round 3 Racing
Drives: Scion FR-S race car
Any new brilliant ideas in the last 6 months? We've been battling heat issues on a JRSC powered race car. Rules prohibit us from running hood vents, fender vents, or making any holes in the body work. I'm curious if anyone has come up with something new.
#724 |
Drives: 2013 frs; 1988 porsche 944s - > 948
quick help
i've ran multiple searches and read about a dozen pages so far on this thread for heat control and haven't found anything to the effect of cooling a FI car after general use. beyond that standard minute or two cool down i'd like to have something set up similar to my old porsche 944s where even after you turn the car off the radiator fans kick in for at least 60 to 90 seconds. Whether this could actually be done with an ecu trick with an oft (most likely not) or some clever wiring changes and an additional relay; i think it could really help with solving some bad heat soak.
anyone know if this has already been done? my attempts at some forum search tool strings all failed on this but perhaps i don't have the right search phrase? |
#725 |
Drives: 2013 DGM BRZ, 2020 C8 Corvette
popping the hood open should help.
My DGM BRZ vid: https://www.youtube.com/watch?v=0OL9OhxexAA
My car journal thread: http://www.ft86club.com/forums/showthread.php?t=43402 |
#726 | |
#727 | |
If you want to turn off the car with peace of mind use a gauge to read coolant and oil temperature. |
#728 | |
| any serious benefit Heat Tapes? | Djen | Engine, Exhaust, Transmission | 22 | 02-18-2014 03:20 PM |
| Heat bad for your car? Ways to cool it? | BushMan | Scion FR-S / Toyota 86 GT86 General Forum | 35 | 08-01-2013 10:15 PM |
| Misfire with heat? | bigjake | Issues | Warranty | Recalls / TSB | 2 | 04-28-2013 09:02 PM |
| Do I Need a Heat Shield? | arleewa | Engine, Exhaust, Transmission | 1 | 01-08-2013 06:37 AM |
| Overpipe Heat question | Amadeus | Engine, Exhaust, Transmission | 5 | 12-19-2012 01:18 AM |
