Old 11-02-2015, 12:08 PM   #715
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
Originally Posted by ofuts View Post
When i touch the hood after a drive, middle of the hood is cool, sides and corners are hot, especially around headlamp and top of fenders. That makes me think hot air circulated in the engine bay finds an air flow through sides, starting near headlamps and go through a closed line out of the engine bay, and gets out from the corners of the black plastic (they are flexible and cut. they are olso relatively hotter after a drive) next to the windshield.
But the reason center of the hood is colder might be because of the woven spongy heat shield kind of thing under the hood.
I really dont want to get a vented hood because they look too aggressive. So considering fender garnish vents these days again but want to make sure if they will be effective enough.
I know fender garnish vents efficiency had been discussed many times before, and that there is no low pressure area there so it is not so effective. But never read anything related to that "hot line".
It might be close to a vented hood in terms of efficiency if there really is an air flow at the sides and can be directed out of these fender garnishes with a small duct.
Anyone has an idea about that?
My fender heat extractors work well enough at idle that it wouldn't matter how well they work when moving. They are an improvement over stock and that is what really counts. Heat literally pours out of them.
Maybe I can rig a thermometer setup; air temp directly by the fender vent and air temp somewhere else outside of the car which doesn't see direct air flow. I have no idea how I'd manage something like that to be accurate, but I think that is going to be the only real test.
'13 WRB BRZ ~470whp // Instagram // YouTube
BRZoomTX is offline   Reply With Quote
Old 11-02-2015, 12:46 PM   #716
John Rambo
John Rambo's Avatar
Drives: Turbo BRZ Limited 6MT
Originally Posted by Kiske View Post
My project over this summer has been focus on cooling my setup so...
Very curious to see what your custom grille looks like. I wish my car didn't get to 215F coolant just cruising on the freeway when it's hotter than 95 out but it's a street car and I can't have the crash beam visible like that
John Rambo is offline   Reply With Quote
Old 11-02-2015, 02:51 PM   #717
FRS Johnny
FRS Johnny's Avatar
Drives: 2013 FR-S Whiteout MT
Paint the bar black and it will blend right in. No one will notice it
When in doubt, throttle out!
FRS Johnny is offline   Reply With Quote
Old 11-04-2015, 11:48 AM   #718
Hostile_Kittens
Hostile_Kittens's Avatar
Drives: 2015 Subaru BRZ
Check this out.
$220 shipped from Japan. A weak yen is a good thing for us.
Hostile_Kittens is offline   Reply With Quote
The Following User Says Thank You to Hostile_Kittens For This Useful Post:
Lonewolf (05-25-2016)
Old 11-04-2015, 01:22 PM   #719
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Can we get that beatrush skid plate stickied? Because hot* damn thats alot cheaper than a vented hood.
No pun intended*
Old 11-04-2015, 01:35 PM   #720
BatStig
Some say.....
BatStig's Avatar
Drives: 2007 Subaru Impreza 2.5i
I don't remember who did it or where the thread is, but I swear that someone had done that themselves to the OE skid pan.
BatStig is offline   Reply With Quote
Old 11-04-2015, 05:52 PM   #721
AppleSauce
Drives: FR-S black. Buell XB12s 25th anniv.
I was just planning on putting a couple extra holes in the oem pan. Does the vented one actually pull that much more air out? As much as a vented hood would?
He who shall be last shall be sideways and smiling
AppleSauce is offline   Reply With Quote
Old 11-04-2015, 05:54 PM   #722
AJPG
Drives: 22RE, FA20, 4G63
Yes, but it wasn't pretty 😂
AJPG is offline   Reply With Quote
Old 05-19-2016, 03:40 PM   #723
bem75
Round 3 Racing
bem75's Avatar
Drives: Scion FR-S race car
Any new brilliant ideas in the last 6 months? We've been battling heat issues on a JRSC powered race car. Rules prohibit us from running hood vents, fender vents, or making any holes in the body work. I'm curious if anyone has come up with something new.
bem75 is offline   Reply With Quote
Old 06-01-2016, 08:50 PM   #724
Gutterboy
Drives: 2013 frs; 1988 porsche 944s - > 948
quick help
i've ran multiple searches and read about a dozen pages so far on this thread for heat control and haven't found anything to the effect of cooling a FI car after general use. beyond that standard minute or two cool down i'd like to have something set up similar to my old porsche 944s where even after you turn the car off the radiator fans kick in for at least 60 to 90 seconds. Whether this could actually be done with an ecu trick with an oft (most likely not) or some clever wiring changes and an additional relay; i think it could really help with solving some bad heat soak.
anyone know if this has already been done? my attempts at some forum search tool strings all failed on this but perhaps i don't have the right search phrase?
Gutterboy is offline   Reply With Quote
Old 06-01-2016, 10:04 PM   #725
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
popping the hood open should help.
shiumai is offline   Reply With Quote
Old 06-02-2016, 12:11 PM   #726
CSG Mike
CSG Mike's Avatar
General rule of thumb is, if your cooling fans are off, you're okay to turn the car off.
Old 06-02-2016, 12:45 PM   #727
AJPG
Generalizations more often than not are wrong... Assuming the car have turbo and was use hard the last couple of minutes the heat of the turbo would need a couple of fan cycles before returning to normal operating temperatures.
If you want to turn off the car with peace of mind use a gauge to read coolant and oil temperature.
Old 06-02-2016, 12:48 PM   #728
AJPG
Get a gauge and observe your oil and coolant temperatures first.
any serious benefit Heat Tapes? Djen Engine, Exhaust, Transmission 22 02-18-2014 03:20 PM
Heat bad for your car? Ways to cool it? BushMan Scion FR-S / Toyota 86 GT86 General Forum 35 08-01-2013 10:15 PM
Misfire with heat? bigjake Issues | Warranty | Recalls / TSB 2 04-28-2013 09:02 PM
Do I Need a Heat Shield? arleewa Engine, Exhaust, Transmission 1 01-08-2013 06:37 AM
Overpipe Heat question Amadeus Engine, Exhaust, Transmission 5 12-19-2012 01:18 AM
