Old 09-29-2014, 11:42 PM   #99
Chad0724
Chad0724's Avatar
Drives: 2015 FR-S
This huge thread and not one dynograph?
:facepalm:
Chad0724 is offline   Reply With Quote
Old 10-13-2014, 10:57 AM   #100
thebear21
thebear21's Avatar
Drives: scion fr-s (RIP)
how do you get it back to a stock flash? aka taking away any flash on the vehicle?
thebear21 is offline   Reply With Quote
Old 10-13-2014, 05:41 PM   #101
steve99
Drives: FT86
Flashing a tune is like writing to a usb memory stick , if you want the stock tune back just flash the stock tune few minutes work . you can theotitly rewrite your ecu thousands of times.
this is ossible if you have the appropriate flashing device.
one thing that can stop you is some tuners lock their tunes so only they can write to the ecu.
OFT or Tactrix/ecuflash does not lock tunes
Ecutek or Brzedit tunes can be locked
Old 10-29-2014, 05:28 AM   #102
diodelphi
diodelphi's Avatar
Drives: 86
is there any book or pdf on web for learning ecutek tuning ?
it seems before that i need a reference for learning tuning basics.
I think dummy people like me will like to learn more about tuning brz with ecutek.
diodelphi is offline   Reply With Quote
Old 05-27-2015, 05:27 PM   #103
keonigt
Drives: 2022 BRZ
If I get a turbo kit with the ecu tek kit and a stage 1 map, can i local tuner tune the car with the ecutek?
I'm wondering if ecutek is just like the cobb accessport where a tuner could just make map for the car easily.
Thanks!
keonigt is offline   Reply With Quote
Old 06-06-2015, 08:53 PM   #104
Skept
Drives: Subaru BRZ
I plan on getting EcuTek for now, but will be going turbo at the end of the year. I have a tuner available. Which option would I have to purchase?
The "do it yourself tune"? Or would I be able to get the stage one tune for now and then later on my tuner can tune from there? The do-it-yourself tune doesn't come with RaceROM, but reading the description for the stage one tune; it seems to have some of the options.
I'm just a little lost when it comes to this, any clarity would be greatly appreciated.
Skept is offline   Reply With Quote
Old 10-29-2015, 05:02 PM   #105
Jonde875
Drives: GT86
Do I see my boost pressure from Ecutek Pro Ecu program or do I need boost gauge for that?
My tuner asks me to keep my boost pressure 0,2-0,3 bar when accelerating for data logs so any advice for that?
Jonde875 is offline   Reply With Quote
Old 10-29-2015, 05:10 PM   #106
Kodename47
Kodename47's Avatar
Drives: UK GT86
Yes, MAP (Manifold Absolute Pressure) is the parameter to log. It should be there by default. Boost to 0.2/0.3 Bar is a MAP of 1.2/1.3 Bar
Do you have a non-stock MAP sensor installed?
.: Stealth 86 :.
Kodename 47 DJ:
Old 10-29-2015, 05:14 PM   #107
Jonde875
Drives: GT86
I have 3 bar map sensor from fensport!
So it shows me reading like 0,2bar boost is 1,2bar on ecutek live data right?
Old 12-17-2015, 07:48 AM   #108
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
Could someone explain the difference between MAP and MAF and how they each relate to engine management/tuning? Are aftermarket replacements required for forced induction setups?
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
Old 12-17-2015, 10:45 AM   #109
Kodename47
Kodename47's Avatar
Drives: UK GT86
MAF = Mass AirFlow
MAP = Manifold Absolute Pressure
You don't need a replacement MAF and MAP is only really required if going turbo. You can replace the MAP to get boost readings, but it's not a requirement to tuning.
.: Stealth 86 :.
Kodename 47 DJ:
Old 02-18-2016, 11:33 AM   #110
Riftur
Riftur's Avatar
So now that a bunch of time has passed and people have tested a lot of tuning products. Does the unichip help a stock FR-S without voiding the warranty?
Riftur is offline   Reply With Quote
Old 02-18-2016, 01:07 PM   #111
AJPG
Drives: 22RE, FA20, 4G63
Hi
Been with the OFT, ecutek and currently with stand alone system..., if you ask me the best combination (for the money) was the OFT with intake, not fast but fun as it could be.
AJPG is offline   Reply With Quote
Old 02-18-2016, 03:35 PM   #112
steve99
Drives: FT86
UniChip is a piggyback ecu that needs a bit of wiring in as it needs power and conbection to various engine sensors. It works by "fooling" the standard ecu by altering the engine sensor inputs. Its quite limited in its adjustments compared to flash tuning the standard ecu.
If your conserned about warantee then your going to have to remove the unichipand wiring for every service. And its likely if they are rearly lookiung they will see where it was connected to cars wiring.
However they dont look for anything unless you have an engine issue.
Flash tuning like OFT ecutek brzedit works by re programming the stock ecu.
Many more adjustment and settings can be changed, it a much better system.
for basic mods the OFT will be your best option especially if you want to flash back to stock for dealer visits as you get tunes and device for $500
you could get an ecutek tune for about same money but you wont get the cable for that price to be able to flash roms yourself. also ecutek embeds licience info in ecu which can be detected even by ametures like myself.
Oft flashes back a 100% stock rom and is virtually undectable.
AFAIK no one has found or been nailed by dealer vie the existance of a flash counter
If your making hardware mods like headers then dealer will notice them straight away
see flashing reset learning link below
Riftur (02-19-2016)
DIY - Transmission / Diff Fluid Change Reference Guide F1point4 DIY (Do-It-Yourself) Guides 295 05-13-2023 02:34 AM
Ford Racing Suspension tuning guide? mines13 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 01-22-2013 01:00 PM
fact or fiction on this performance and tuning guide? davey90 AUSTRALIA 10 07-19-2012 07:45 PM
FR-S quick reference and warranty / maintenance guide is up pkny Scion FR-S / Toyota 86 GT86 General Forum 15 06-20-2012 11:33 PM
86/FRS/BRZ Tuning Guide ESBjiujitsu Engine, Exhaust, Transmission 18 05-30-2012 06:42 PM
