Old 10-28-2015, 12:37 PM   #1
jackblack21
Drives: red scion frs
How many cars rate HP at the Crank?
One thing that really bugged me was finding out that the real HP of my FR-s is about 174 not 200.
How many cars are rated by the company at the crank? I feel it's kinda fraudulent.
jackblack21 is offline   Reply With Quote
Old 10-28-2015, 12:37 PM   #2
raven1231
all and it's not fraudulent at all...they don't claim WHP...
The Following 11 Users Say Thank You to raven1231 For This Useful Post:
DAEMANO (10-29-2015), El Guapo (10-28-2015), FRSBRZGT86FAN (10-29-2015), kch (10-28-2015), meWant (10-28-2015), Rampage (10-28-2015), ravisraval (10-29-2015), soulreapersteve (10-28-2015), strat61caster (10-28-2015), TRD-X (10-28-2015), why? (10-31-2015)
Old 10-28-2015, 12:38 PM   #3
kch
Senior Misanthrope
kch's Avatar
Why does the number bother you? The car still feels the same, doesn't it?
Edit: it's also a more consistent measurement of power.
The Following 3 Users Say Thank You to kch For This Useful Post:
8R6 (10-28-2015), DAEMANO (10-29-2015), raven1231 (10-28-2015)
Old 10-28-2015, 12:39 PM   #4
raven1231
Car club bro
The Following 2 Users Say Thank You to raven1231 For This Useful Post:
funwheeldrive (10-28-2015), soulreapersteve (10-28-2015)
Old 10-28-2015, 12:42 PM   #5
Toyarzee
Shibby!
Toyarzee's Avatar
Drives: '14 White FR-S, '01 turbo mini taco
Must be the first car you've owned and taken note of the power rating figures. There's several good reasons they do this and it's covered in several threads... fraudulent? No...
Toyarzee is offline   Reply With Quote
The Following User Says Thank You to Toyarzee For This Useful Post:
Old 10-28-2015, 12:43 PM   #6
DarkSunrise
DarkSunrise's Avatar
Uhh pretty much every manufacturer? I can't think of any that advertise horsepower to the wheels.
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
why? (10-31-2015)
Old 10-28-2015, 12:44 PM   #7
jackblack21
all right... if that's the standard. Seems the hp and torque at the wheel is what matters.
Old 10-28-2015, 12:46 PM   #8
Toyarzee
Shibby!
Toyarzee's Avatar
It all matters and is all relevant, both figures tell you different stories
Old 10-28-2015, 12:59 PM   #9
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
it's call horse power war for a reason, if u are in that game you brought the wrong car.
The Following User Says Thank You to chaoskaze For This Useful Post:
Old 10-28-2015, 01:04 PM   #10
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
I thought everyone knew all OEM's rated crank HP, unless they state otherwise. But lets say a camaro has 300WHP and a Stang had 310HP people will buy the Stang although the camaro makes way more power.
Old 10-28-2015, 01:44 PM   #11
Fishbed77
Fishbed77's Avatar
Drives: 2013 FR-S 6MT Whiteout
Ultimately yes. But crank HP is a more consistent way for manufacturers to rate engines.
WHP has so many variables (tires, wheel size, weight over the axle, temperature, coefficient of friction of the surface, etc.) that it becomes practically impossible for a manufacturer to provide an accurate number.
Fishbed77 is offline   Reply With Quote
The Following User Says Thank You to Fishbed77 For This Useful Post:
Old 10-28-2015, 01:49 PM   #12
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
You down with SAE? Yeah, you know me.
jawn is offline   Reply With Quote
The Following 12 Users Say Thank You to jawn For This Useful Post:
86kahl (10-28-2015), 8R6 (10-28-2015), cdrazic93 (10-28-2015), DAEMANO (10-29-2015), FRSBRZGT86FAN (10-29-2015), GotBRZ1691 (10-28-2015), malave7567 (10-28-2015), reni (10-29-2015), roddy (10-28-2015), soulreapersteve (10-28-2015), Tcoat (10-28-2015), vividracing (10-28-2015)
Old 10-28-2015, 01:51 PM   #13
malave7567
malave7567's Avatar
Drives: (formerly) 2013 Raven FR-S
Car manufacturers follow SAE standards to measure the crank HP of an engine. Especially once SAE tightened the rules in 2005 or 2006, the numbers from manufacturers are much more consistent. It's much harder to pass an "underrated" or "overrated" engines through with the newer regulations. Also, all accessories that are standard equipment on the engine must now be on engine for the test (ex., no leaving out the power steering pump for the test to help boost HP figures).
That said, WHP is the one we care about. However, crank HP can be consistently measured in a very controlled environment (the engine is out of the car). WHP can have a lot of variables, as previously mentioned already in the thread.
Car and Driver article on the subject: http://www.caranddriver.com/columns/...olution-column
malave7567 is offline   Reply With Quote
Old 10-28-2015, 05:50 PM   #14
Yep, back in the day, I sort of felt "robbed" when they went from gross HP to net HP .....
http://ateupwithmotor.com/terms-tech...et-horsepower/
roddy (10-28-2015)
Second time crank seal leak possible crank walk kiichiro Engine, Exhaust, Transmission 13 09-19-2018 05:57 AM
BRZ vs FRS Manufacturing Rate Stigmaru BRZ First-Gen (2012+) — General Topics 18 12-12-2016 03:53 PM
Rate your mods! l0aded Scion FR-S / Toyota 86 GT86 General Forum 32 05-13-2013 04:23 PM
If our cars pick up 8 wheel hp how much is that at the crank? pr086 Scion FR-S / Toyota 86 GT86 General Forum 10 01-18-2013 05:56 PM
Interest Rate? Maps316 BRZ First-Gen (2012+) — General Topics 35 08-26-2012 02:45 AM
