Southern California SoCal
Old 10-27-2015, 10:01 AM   #29
ExxelDistributions
ExxelDistributions's Avatar
Drives: 2014 FR-S 6MT Monogram Series
Originally Posted by ronboogieon View Post
I recently smogged our 09 mazda3 and it was able to pass with a non-CARB aftermarket second cat. Maybe its because it looked stock or the place I went to didn't do visual check.
Wondering if the Berk Hi-flow cat on the BRZ will pass? Anyone try yet?
Some techs might not go into details and check everything one by one and see if the aftermarket part has a label on it. That's just your luck.
Originally Posted by jaorocks1 View Post
So let's say I gutted my stock header and front pipe... and run my e85 tune it will still pass? :O
Don't think so. Not sure if a tune gets the CEL off and all readiness monitors ready or not. But if a tune does turn the CEL off and the monitors stay incomplete then no it wont pass.
ExxelDistributions is offline   Reply With Quote
Old 10-27-2015, 11:21 AM   #30
Phantobe
Phantobe's Avatar
Drives: 14 Ultramarine FR-S
A tune can/will (specifically Open Flash Tune) turn off the CEL for running a catless setup. So it should pass right? I assume you had a typo in your second line.
2014 Ultramarine Scion FR-S
2000 Integra LS - SOLD
Phantobe is offline   Reply With Quote
Old 10-27-2015, 12:27 PM   #31
ExxelDistributions
not a typo. what I was saying is if the CEL is off but the readiness monitors are incomplete then it will still fail.
Old 10-27-2015, 02:16 PM   #32
Phantobe
Phantobe's Avatar
So pretty much stock header with no cat is gonna fail even if you have a tune that gets rid of the CEL.
Lol damn I thought I found a work around
Old 10-27-2015, 02:26 PM   #33
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
they do visual inspections in CA? seems like you guys get stiffed with all these tests.
Old 10-27-2015, 02:29 PM   #34
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Howbout silicon inlet tubes?
Originally Posted by humfrz
I'm old and lazy
Old 10-27-2015, 03:01 PM   #35
8R6
8R6's Avatar
Drives: FRS
you'll fail the visual test. that is, if the tech goes by the book, which these days the chances are he will.
8R6 is offline   Reply With Quote
The Following User Says Thank You to 8R6 For This Useful Post:
Clipdat (10-27-2015)
Old 10-27-2015, 03:10 PM   #36
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Man I am so happy I live in Alberta!
Old 10-27-2015, 03:11 PM   #37
Clipdat
Proud of BOXER
Clipdat's Avatar
Guess I will have to swap back to the OEM inlet tube, complete with retarded noise generator. So stupid.
I'm old and lazy
Old 10-27-2015, 03:13 PM   #38
ExxelDistributions
Yes we check to make sure all components are in place.
since its not the original it has to have a CARB Label on it.
Most techs now days do go by the book. reason being is because the state has been coming down on us all and watching us like a hawk. They shut down 4 shops locally here for not following the book so I dont most places will close their eyes on it
The Following 3 Users Say Thank You to ExxelDistributions For This Useful Post:
8R6 (10-27-2015), Clipdat (10-27-2015), NyC Zn6 (10-27-2015)
Old 10-27-2015, 03:16 PM   #39
8R6
8R6's Avatar
Drives: FRS
yeap. my dads has had his smog shop for the past 30yrs. trust me, i totally understand what you guys are going thru in having to deal with the BAR and the rest of this communist state lol
Old 10-27-2015, 03:43 PM   #40
ExxelDistributions
exactly lol!
Old 10-27-2015, 09:47 PM   #41
cycleboy
Drives: 2013 Scion FR-S - Argento
Unless someone tried it for a test, I doubt it. We're exempt for 6 years, so the 2012's won't require it until 2019. I wonder if you get a fix it ticket for being too loud if they could force you to get a smog check early? Seems unlikely.
I thought about doing that type of mod since I wouldn't have to undo it for at least another 5 years or so. It'd suck after that to have to reset everything every other year though.
cycleboy is offline   Reply With Quote
Old 10-27-2015, 09:57 PM   #42
ExxelDistributions
The state has been talking about changing the 6 year rule to either 3-4 years. Nothing is set for sure. But they are discussing it with shops. Also its mostly for the out of state guys. Us CA guys don't need smog for 6 years but no matter how old a car is out of state requires smog regardless
Smog check for out of state people? goshem Southern California 4 09-25-2015 06:20 PM
CA Smog Check?? JG Southern California 22 06-08-2015 11:05 AM
WARNING!!!! Monday 1/26 CHP SMOG check in Orange County-Cross streets-Lambert/Idaho continuecrushing Southern California 13 01-26-2015 11:19 PM
Need advice on passing smog in California rmak321 Northern California 7 07-12-2014 12:52 AM
Smog check and visual inspection help Corradooo Northern California 24 05-19-2014 11:57 PM
