Old 10-26-2015, 04:35 AM   #141
350matt
Drives: toyota mr2/ Toyota GT86
bear in mind the stock oil temp sensor reads gallery temp and most documentation abotu oil temp is all about sump temps
gallery temps will usually be about 10-12 deg higher than the sump
and you want oil to be at 100 deg C in the sump so 110 in teh gallery is fine
a good full ester synthetic will break down at about 155-160deg C so we're reading it at the hottest point
so I'd go up to the thicker oil for FI but thats it
for a street car in most climates I'd say no cooler is required
350matt is offline   Reply With Quote
The Following User Says Thank You to 350matt For This Useful Post:
ofuts (10-26-2015)
Old 10-26-2015, 01:17 PM   #142
ofuts
Drives: 2013 Toyota 86 MT
Hey Matt, thanks for the reply, nice to know about that 10C difference info. Do you mean oil pan by "sump"?
Yes, i would have no problem if i were seeing 110C at oil sandwich plate (i guess it is right after gallery so temps should be nearly same), but i am seeing 130C after 3 laps with oil cooler. My problem is that i can not track the car, daily driving is no problem, i want to do at least 10 laps back to back.
I am using Motul 0W40 which is ester synthetic. I will try Motul 300V 5W30 next weekend, but i guess it will not help.
I already ordered an obd2 port adapter to and will monitor oil temps via iphone app, it is good to know i need to add 10C to my readings from obd2 for comparison.
ofuts is offline   Reply With Quote
Old 10-26-2015, 06:49 PM   #143
350matt
yes oil pan = sump
and you said you need to add 10 degrees?
the gallery temp ( where the sensor is ) will be hotter than the sump
so take 10 degrees off to get the sump / oil pan temperature
110 degrees via OB2 oil gallery = 100 degree in the sump
and changing the oil a heavier grade won't make much difference to temperature, but it will mean that the thicker oil maintains more of a bearing wedge at temperature
Old 10-27-2015, 07:54 PM   #144
learnerspermit
learnerspermit's Avatar
Drives: C-17A
Originally Posted by swift996 View Post
I disconnected mine for the winter. I just bought two plugs with o-rings and put them on the lines. Took the adapter off below the oil filter and was good to go. It takes 5 minutes. I recommend for those in the cold states. My oil would get to 160F and the thermostatic plate would open and it would instantly cool to 155F and close. Essentially repeating that cycle over and over. I could never get my oil temps warm enough. I'm in the DC area, we had a bad winter but anything here and north, I'd recommend.
Do you purge the oil out or just disconnet and cap the lines to the cooler itself with the current oil left in?
learnerspermit is offline   Reply With Quote
Old 10-31-2015, 10:08 AM   #145
ofuts
I got my obd2 port today and compared oem sensor reading with innovate readings: oem was reading 56C when mtx-d was reading 65C, at the end of some sprited driving oem was reading around 100-101C while mtx was reading 115-117,5C. If i consider gap increases linearly i was at around 113C after 3 laps which is not too bad, so i am a bit relieved but need to see at the track again to be sure.
Old 11-05-2015, 01:02 PM   #146
swift996
swift996's Avatar
I just left it in the lines.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Oil cooler needed? Don't know? See some results inside Sportsguy83 Engine, Exhaust, Transmission 159 03-15-2015 06:27 PM
Perrin Oil Cooler - Impressions, Pics, and Data swift996 Engine, Exhaust, Transmission 36 04-29-2014 10:03 AM
Robispec Radiator/oil cooler NEW $800 or trade for NEW FB oil cooler kit. mike the snake Engine, Exhaust, Bolt-Ons 1 01-31-2014 06:46 PM
Car/Ambient temperature to log data gdrider77 Software Tuning 6 01-19-2014 09:49 AM
